2019-02-05, 16:28
(2019-02-05, 13:31)Jcnc1996 Wrote: I found a bug, when I play a movie instead bistreaming outputs PCM when the movie is DTS-HD or what ever bistreaming format, I have to uncheck and check again every time i put a movie to fix the bug in audio settings ''Allow Bistreaming''. I have Intel UHD 630 Graphics. For everything else works perfect.@Jcnc1996, I don't think you found a bug, you found a local problem maybe? Nothing wrong with the output of the HD-Audio streams and yes, I tested this with a 7th generation Intel setup.
KodiSetup-v18.1-RC1-x64-MVC-WIP1
So you should look at your setup and Kodi 18 MVC configuration (settings)?
