Done, and retried the test build.
It's working now, thanks. I have to say, the new skin is insanely good!
Sorry if this has been asked many times (can't seem to locate a response using search) but when do you think DVD playback (which seems to have been "temporarily" disabled for an age) will get re-enabled in these test builds? What's it depending on?
Also, where is the best place to report issues that are (probably) new skin specific (e.g. wrong art showing while navigating different parts of the interface)?
Use another one - OpenWeatherMap Extended is working fine and available via addon search.
MONSTA
Senior Member
You didn't understand. Addon works fine. I'm talking about the status bar of the main screen.
where can j find Vsync option in latest build ?
2016-04-23, 09:37
(This post was last modified: 2016-04-23, 10:18 by Vimes.)
Edit, non issue for these builds.
Hi Milhouse.
First of all I would like to thank you for your great job, before with OpenELEC and now with LibreELEC builds. I´ve using then since a long time. ;-)
I have a question regarding the behaviour of the 3D files recognition. I have a LG TV and in case the mkv I'm going to play is SBS (Side by Side), I add "3D SBS" to the file name and KODI change automatically the GUI to 3D mode and trigger my TV into 3D mode also. Also when the movie is finished, both 3D modes in my TV and KODI are switch down automatically.
But in case that the movie is in TAB (top and bottom) if I add "3D TAB" to the file name, only KODI GUI is switched into 3D mode, but I have to manually change my TV into 3D mode using the remote control. Also when the movie is finished in this case, I have to manually switch off the 3D mode in my TV.
Is not well implemented the TAB mode reconigtion in KODI, or as least, as good as SBS mode or there is someting that I'm doing wrong?
Sorry by my english and regards from Spain.
Milhouse
Retired Team-Kodi Member
A) You are using a test build, report the problem in the test build thread
B) You have daily test builds available, if the problem suddenly started happening a few weeks ago then go back through the builds to identify the first build with the problem
C) Your log is not a debug log
D) Your log is garbled and appears to be two logs mixed together
I'm going to merge this thread into the test build thread.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
