2016-05-03, 14:17
(This post was last modified: 2016-05-03, 16:44 by ElectricPim.)
How is a BT-keyboard supposed to work on a RPI3 and latest LE-builds?
I can enable bluetooth, and connect and trust the keyboard. It will ask for a pincode, for which there is no hint. But entering anything seems to work, the keyboard is marked as connected (lock icon).
But I expect it to work like a USB keyboard, while it doesn't seem to do anything. Should it work like a USB keyboard?
(BTW I can connect and use the keyboard in Raspbian on a RPI3, although it seems to lose connection after a while, when doing nothing)
Well, after updating to the latest build today, it all started working. It's showing a pincode to type, and it's is working like an USB keyboard.
I see a lock and a favorite star in the BT devices listing.
Is it possible to show Metadata as default instead of Plot in the info screen of the new skin.
`Not available` is not very informative IMHO.
Didn't anybody else notice that refreshrate switch from 60hz to 50hz is not working when watching live tv or am i really the only one?
I did a fresh install on my rpi2 with LE stable 16.1 from LE site then i update with #0502 build and still no refreshrate swith. (videoplayback is freezes)
When swithing from 60hz to 24hz videoplayback is fine..
If needed i can provide some logs.
2016-05-03, 16:42
(This post was last modified: 2016-05-03, 16:43 by ElectricPim.)
Happily reporting that in this latest build I am able to use DVB-T TV for the first time with TV-Headend 4.2 and a Dexatek Technology Ltd. DK mini DVB-T Dongle, software mpeg2 decoding. Running quite stable, although it rebooted once. RPI3
2016-05-03, 19:37
(This post was last modified: 2016-05-03, 19:56 by SkywalkerPD.)
Every item I start from my library starts the same movie...? When I check the file paths they are correct. I can't find out why this is happening. I'm running on the 0502 build, with Estuary skin. The skin is not the problem. I tried with another skin as well. Same problem.
Seems to be related to the following error...
ERROR: Unable to load /usr/lib/kodi/system/players/VideoPlayer/libdvdnav-arm.so, reason: /usr/lib/kodi/system/players/VideoPlayer/libdvdnav-arm.so: cannot open shared object file: No such file or directory
So it skips all the folders with DVD structure, and the first directory (after 24 with the above error) with an .mp4 file in it is played every time.
