cojms1
Junior Member
I won't be able to test again until tomorrow. Tests earlier showed the results I mentioned in the previous post (#0604 seemed fine at first glance). Maybe it was just less pronounced though.
Fairly big change to I2S/DMA driver in this update. If you use I2S audio then please test and report.
Aux_
Senior Member
Video settings, deinterlace video and deinterlace method Automatic works fine, no more video stops or freezes.
Thanks for the hard work guys!
[3x RPi3]#[ AV Receiver - Marantz NR1506 ]#[ TV Panasonic TX-50EXW784 ]#[ NAS - OMV 4.1.xx (Arrakis) @ NanoPI M4 ]#[ Nextcloud 17.0.3 @ ODROID C2 ]
2016-06-11, 01:56
(This post was last modified: 2016-06-11, 07:13 by smp1.)
I noticed an issue that is not present in stable 7.0.1 build:
During the first couple of seconds after the start of the video - there is a high number of skipped frames (usually around 30-70). The start of playback is much more smooth in Kodi 16. The issue seem to be limited to the files in TS, MPEG-PS and VOB containers. All MKVs I tested are ok.
Update: The problem is gone when "Sync Playback to Display" is enabled.
Tested on RPi3 connected with a LAN cable to an SMB shared folder on Win7 PC.
