  • 61
  • 62
  • 63(current)
  • 64
  • 65
  • 218
v17 LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-06-15, 19:38)asavah Wrote:
(2016-06-15, 15:50)f1vefour Wrote: Could you PM me how you created the bridge?
I'm not using LibreELEC,but I follow it's development closely.
My setup won't work here, sorry.
Thanks anyway, I was wondering since brctrl isn't included. It really should be since the Pi 3 has onboard WiFi now.
Hi..
#0614, 14-Jun-2016: RPi / RPi2
MCE Remote not work... Problem with new lirc?
(2016-06-15, 23:46)f1vefour Wrote: It really should be since the Pi 3 has onboard WiFi now.
This is where LibreELEC (a media center focused client) diverges from the more mainstream/general purpose distributions. If you want your RPi3 to be an access point as well as a media center client then LibreELEC is not your best option.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
New LibreELEC.tv Krypton build #0615: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.6.2 #1 Wed Jun 15 22:29:44 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jun 13 2016 13:25:19
Copyright (c) 2012 Broadcom
version 625ddc17506de68faffed80e656109b206905fc0 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160615222807-#0615-g820ca7d [Build #0615]
# vcdbg log msg 2>&1 | grep DTOK
002458.676: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (820ca7d8, changelog) and tip of XBMC master (12219485, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.6.y
  • Includes latest bcm2835-driver master (fdbca29d, ahead +1)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cdd1643c, ahead +28)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (32275717), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  1. Drop lirc bump added in #0614
Build Details:
  1. LibreELEC.tv:
    • wlan-firmware: bump to 0.0.32 (PR:448, 1 commit, 1 file changed)
    • osmc_rf: fix context menu button (PR:450, 1 commit, 1 file changed)
    • RPi: Refresh default config.txt, add licence and warning to distroconfig.txt (PR:442, 1 commit, 2 files changed)
    • splash: Stop blanking splash too early in RPi boot sequence (RFC) (PR:412, 1 commit, 3 files changed)
    • Package updates (PR:428, 31 commits, 36 files changed)
      • elfutils: update to 0.165
      • libftdi1: update to 1.3
      • swig: update to 3.0.9
      • giflib: update to 5.1.4
      • libjpeg-turbo: update to 1.5.0
      • fuse-exfat: update to 1.2.4
      • bluez: update to 5.40
      • libnftnl: update to 1.0.6
      • libgpg-error: update to 1.22
      • dbus: update to 1.11.2
      • libpng: update to 1.6.22
      • libevdev: update to 1.5.1
      • libusb-compat: update to 0.1.5
      • pciutils: update to 3.5.1
      • libxml2: update to 2.9.4
      • xf86-input-libinput: update to 0.19.0
      • libinput: update to 1.3.1
      • curl: update to 7.49.1
      • libmicrohttpd: update to 0.9.50
      • xkeyboard-config: update to 2.18
      • xf86-input-evdev: update to 2.10.3
      • libxslt: update to 1.1.29
      • libXfixes: update to 5.0.2
      • xcb-proto: update to 1.12
      • xproto: update to 7.0.29
      • mesa: update to 12.0.0-rc2
      • xf86-video-intel: update to b617f80
      • libirman: update to 0.5.2
      • libxcb: update to 1.12
      • libressl: update to 2.3.5
      • xf86-video-nvidia: update to 367.27
    • Revert "Merge pull request #136 from lrusak/modesetting" (PR:431, 1 commit, 3 files changed)
    • lirc: remove circular dependency on libirman (PR:454, 1 commit, 1 file changed)
  2. XBMC:
    • call SetVideoResolution before streams are Enabled (PR:9944, 1 commit, 1 file changed)
    • Fix tests (PR:9980, 3 commits, 3 files changed)
    • [upnp] fix TransportPlaySpeed state variable in CUPnPRenderer (PR:9927, 2 commits, 1 file changed)
    • [cmake] Allow building with Ninja generator (PR:9954, 1 commit, 5 files changed)
    • drop unused aml header (PR:9982, 2 commits, 2 files changed)
  3. newclock5:
    • New commits in this build:
      • rbp: Protect against invalid access when skin has no mouse pointers (ae80130d)
I like LibreELEC for the ro system data integrity, I just want to be able to connect the eth to the wifi.
*edit*
I can connect using just iptables.
Thanks for the direction. It didnt crash but instead just froze
Debug log at the following location http://pastebin.com/TRVjWpGT
(2016-06-16, 07:03)david1976aus Wrote: Thanks for the direction. It didnt crash but instead just froze
Nothing obvious from log except you have some network issues. e.g.:
12:14:36  17.430374 T:1753215904   ERROR: ## LibreELEC Addon ## oe::load_url(http://releases.libreelec.tv/releases.json) ## ERROR: (URLError(gaierror(-3, 'Temporary failure in name resolution'),))
Do you still get the hang if omxplayer is enabled? Does it affect all video files or just that one?
Can you try copying the video to pi (e.g. to sdcard or usb stick) and play from there?
If you ssh in before the hang is the ssh connection still active? What does "vcgencmd get_throttled" return at this point?
Hello,
Like mentioned in post #888 I also don't get any options in LibreELEC -> System. Only Network, Connections etc. shows options. The same seems to be the case with LibreELEC (Krypton) v7.90.002 ALPHA.
I don't have this issue in LibreELEC (Jarvis 16.1) v7.0.1 and all builds up to LibreELEC-RPi2.arm-8.0-Milhouse #0609. Later builds all have this issue.
Anyone have any clue? I have a RPi 3.
When does it auto updates?
i have 614 on it.
i have it set to auto update.
When does it check for updates? on shutdown/restart/bootup?
(2016-06-16, 21:02)Chivato Wrote: Hello,
Strange thing is i had it on 613 also but when i did a restart it worked again.
in a glimps i saw it showed something like failed to load .... something and when i check the system its blank but after a reboot it works again 614 also just works here.
I have restarted many times and installed different images to check which worked an which not. As mentioned all builds work up to #609. So I guess something has changed since then ...
(2016-05-25, 18:22)popcornmix Wrote:
(2016-05-25, 15:08)drdwridav Wrote: Here goes...
http://xbmclogs.com/puwy1f8gh
This is problem:
14:01:54  71.623474 T:1572184992    INFO: RTMPSockBuf_Fill, recv returned -1. GetSockError(): 11 (Resource temporarily unavailable)
14:01:54  71.623566 T:1572184992   ERROR: RTMP_ReadPacket, failed to read RTMP packet header
We are getting an error from network stack. Are you sure LE Jarvis is working on this stream currently?
There is always a chance that something is changed at the server end, so it's worth double checking the stream is still good.
If it does work in LE Jarvis, then it probably was working in an earlier Milhouse nightly build.
Worth testing a build from a couple of months back just to see.
Possibly LE has bumped a library which the new version is no longer supporting this stream. Narrowing down when this occurred would be helpful.
Just to report that recent builds have sorted the rtmp issue - now streaming fine. Great stuff!
Edit:
in a glimps i saw it showed something like addon isnt ready yet. And now i have the same problem again reset a few times etc but seeing a blank system page.
No idea really how to reproduced it. earlier today when i just updated to 614 it worked but then i did a restart and it stopped working.
Might have found the "problem" when the PI3 in my case is powered down totally and then i start it up i see the system settings. but if i do a reboot and then check its gone.
(2016-06-16, 21:28)Little_Kitty Wrote: When does it auto updates?
i have 614 on it.
I had thought the Settings add-on would auto-update custom builds but it turns out this isn't implemented yet so for now either update manually (select a build from Available Versions) or continue using Leopolds add-on until we can flesh out the Settings add-on.
New LibreELEC.tv Krypton build #0616: RPi / RPi2
# uname -a
Linux rpi512 4.6.2 #1 Thu Jun 16 21:06:17 BST 2016 armv6l GNU/Linux
# vcgencmd version
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160616210509-#0616-g3fb896a [Build #0616]
002473.693: Kernel trailer DTOK property says yes
Based on tip of LibreELEC.tv master (3fb896a3, changelog) and tip of XBMC master (b3a9c83c, changelog) with the following modifications:
Build Highlights:
  1. mmal_codec: Use EOS through codec to determine drain is complete
Build Details:
  1. LibreELEC.tv:
    • Virtual project updates (PR:455, 9 commits, 24 files changed)
  2. XBMC:
    • overlayrenderer: Avoid null access (PR:9983, 1 commit, 1 file changed)
    • [PVR][guiinfo] Fix 'ListItem.EndTime' for PVR recordings. (PR:9985, 1 commit, 1 file changed)
    • [depends/curl] enable IPv6 (PR:9777, 1 commit, 1 file changed)
    • Fix random problem importing premiered date (PR:9988, 1 commit, 1 file changed)
    • [xbmc][cleanup] Add missing vector includes (PR:9981, 1 commit, 169 files changed)
    • [lang] updated language files from Transifex (7ea67490)
    • [lang][skin.estuary] updated language files from Transifex (89242bdb)
    • [lang][skin.estouchy] updated language files from Transifex (856bf259)
  3. newclock5:
      • mmal_codec: Use EOS through codec to determine drain is complete (11878a30)
    • Commits no longer in build:
      • overlayrenderer: Avoid null access (f3d2bc90)
  • 61
  • 62
  • 63(current)
  • 64
  • 65
  • 218
LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)19
