2016-06-17, 07:10
no live tv playback on 0616 it remains on buffering.. reverted to 0615 and all fine.
(2016-06-17, 00:49)Milhouse Wrote:When set to manual update method and checking version it does not appear to instantly perform a check of latest available Nightly versions on internet?(2016-06-16, 21:28)Little_Kitty Wrote: When does it auto updates?I had thought the Settings add-on would auto-update custom builds but it turns out this isn't implemented yet so for now either update manually (select a build from Available Versions) or continue using Leopolds add-on until we can flesh out the Settings add-on.
i have 614 on it.
i have it set to auto update.
When does it check for updates? on shutdown/restart/bootup?
(2016-06-17, 07:50)Chivato Wrote: Updated to latest build and again no options in LibreELEC -> System. Back to build #609 and issue has gone. Also rebooted the device several times without any problem. No issues up to this build. So what could be the problem?
UPDATE!
Seems a power issue;
1. Onboard wifi enabled and Wifi USB stick removed -> works (but transfer rate for me is too low, usb stick with antenna gives better signal)
2. USB Wifi stick in usbport -> problem appears
3. Wifi disabled and only use LAN -> works
Hope this helps you guys fix the problem. Maybe it got something to do with the firmware update for Wifi?
(2016-06-14, 19:25)bill_orange Wrote:(2016-06-14, 17:57)tilu01 Wrote: some alsa problems :-)
just have crackling sound on all my external soundcards. (xone x:2, arcam rdac, native instruments audio4dj (recognized but no sound at all))
if i try to set the usb to mode 1.1 like in openelec (dwc_otg.fiq_split_enable=0 in cmdline.txt) i don't get any sound
raspberry pi 3
liberelec Build #0610
I don't know if this will help but here goes.
I am using a USB sound device on my Raspberry PI. When I go to Kodi's audio menu to select the audio output device, it offers me three USB devices. One is the SPIF output which I don't use. The remaining two USB sound devices have nearly identical labels. One produces sound with loud crackling and the remaining one works fine.
If you have not done so already, explore every device listed carefully. Triple check that you are plugged into line-out. I wasted about 20 min. on that one.
Bill
(2016-06-17, 14:37)tilu01 Wrote: and in cmdline.txt i added
dwc_otg.fiq_enable=0
dwc_otg.fiq_fsm_enable=1
dwc_otg.fiq_fsm_mask=0x3
(2016-06-17, 14:40)popcornmix Wrote:(2016-06-17, 14:37)tilu01 Wrote: and in cmdline.txt i added
Why exactly did you add these? They don't really make sense - if fiq_enable=0 then the other two setting will have no effect.
Are you saying fiq_enable=0 helps? I would have thought that would be more likely to make things worse.
(2016-06-17, 15:27)tilu01 Wrote: haven't tried it without the 2 last lines.
first i tried it with fiq_enable=1 and changed also the fsm_mask 0x7 etc. always crackling sound
and when i set fiq_enable=0 it worked :-)
if I have time I'll try it and a few other things, which were mentioned in the Volumio forum. they fixed it already and i'm trying to find out how :-),
(2016-06-17, 07:10)gendo Wrote: no live tv playback on 0616 it remains on buffering.. reverted to 0615 and all fine.
