2016-07-07, 13:27
Is there a GUI updater yet for these builds like Leopolds for OE?
(2016-07-07, 13:27)nickrob84 Wrote: Is there a GUI updater yet for these builds like Leopolds for OE?
(2016-07-07, 14:15)Milhouse Wrote: @nickrob84 or see note #7 in the first post which details the custom urls to enter for the update facility accessed via the LE Settings addon. Once the url is entered and channel selected you should be able to manually upgrade to new (or older) versions. Automatic updating will come eventually, this is still a work in progress.
# uname -a
Linux rpi512 4.7.0-rc6 #1 Thu Jul 7 21:07:55 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 5 2016 21:33:41
Copyright (c) 2012 Broadcom
version 5a921d051b05efb2ce8abb0874cd44023d080d93 (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160707210601-#0707-g4cb4fca [Build #0707]
# vcdbg log msg 2>&1 | grep DTOK
002473.431: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
(2016-07-08, 01:29)smp1 Wrote: There's an odd issue I noticed with some mkv files. When I start the playback the display will switch to 60Hz and after a couple of seconds it switch to the correct 24Hz.
Stream #0:1: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 47 fps, 47 tbr, 1k tbn, 47.95 tbc (default)
