(2016-08-04, 20:12)dantist Wrote: but it's really sad since Amazon was the main reason I switched to LibreELEC.
These are test builds - if you don't want to find problems, don't use these builds.
(2016-08-04, 20:12)dantist Wrote: I don't know if this has been mentioned yet, but since a couple of version (one user of the kodinerds-Forum said the last working one was July 17) I have massive audio-problems with the Amazon-plugin. It buffers a lot with the July 17-build, but with the latest one I can barely hear anything at all. The video runs without stuttering, but the Dolby Digital-icon on my AV-receiver is flickering on and off rapidly and you can hear almost nothing.
Unfortunately there are no errors in the debug log. The internet connection is fine and runs with a solid ~48MBit/s. Hardware is a Raspberry Pi 2.
I'm testing #0803, RPi3, Amazon Prime Instant, Amazon UK, Lucifer Pilot (tv series, S01E01) in 1080p over a 20Mbps connection, 2.1 PCM audio output (no passthrough).
Playback starts OK, audio in sync, no stuttering, but then after about 4-5 minutes playback will stutter badly and audio will be lost - is this what you are referring to?
This is a debug log:
http://sprunge.us/Gegj
The following might be relevant - these messages appear fairly frequently:
20:00:53 77085.320312 T:1557255072 INFO: CVideoPlayerVideo - Stillframe detected, switching to forced 23.976024 fps
20:00:57 77088.898438 T:1557255072 INFO: CVideoPlayerVideo - Stillframe left, switching to normal playback
Edit: The Stillframe messages do coincide with stutters (several dozen, sometimes hundreds, of skipped frames).
