  • 146
  • 147
  • 148(current)
  • 149
  • 150
  • 218
v17 LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-09-15, 21:26)pyrodex Wrote: @popcornmix When I test them out do you want me to revert and move to the next thing or keep it and test the next thing?
Yes, test each suggestion one at a time - so revert back before trying next test.
(2016-09-15, 15:39)MicTie Wrote:
(2016-09-15, 12:23)popcornmix Wrote:
(2016-09-15, 04:50)MicTie Wrote: Since about 1 week subtiltes are displayed until a new sub-title starts. Using .srt-subtitles
Identifying the exact build that introduced the problem would help narrow it down.
According to here is was build 907. I observed it the next day, but not sure if I did an update that day
We need to go back 0906 to confirm it was that build, I'm away till the weekend, but will test when back if no one else can do it.
New LibreELEC.tv Krypton build #0915: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.4 #1 Thu Sep 15 22:33:31 BST 2016 armv6l GNU/Linux
# vcgencmd version
Sep 14 2016 20:00:33
Copyright (c) 2012 Broadcom
version efa16f891edfcb0ba1aae15be195ad9d8b38d6be (tainted) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160915223035-#0915-gd875a87 [Build #0915]
# vcdbg log msg 2>&1 | grep DTOK
# Kernel device tree status: DISABLED
Based on tip of LibreELEC.tv master (d875a87d, changelog) and tip of XBMC master (44fb790d, changelog) with the following modifications: Build Highlights:
  1. New 4.7.4 kernel
  2. AE: fix mem leak in tempo filter
Build Details:
  1. XBMC:
    • [pvr][epg] fix division by zero in CGUIEPGGridContainer::GetLabel (PR:10464, 1 commit, 1 file changed)
    • Added 2 view modes with zoom that depends on AR (PR:10318, 1 commit, 11 files changed)
    • AESinkWASAPI: Move deprecated layout before first 7.1 layout (#16903) (PR:10466, 1 commit, 1 file changed)
    • [win32] Fix a possible leak and a micro-optimisation. (PR:10455, 2 commits, 1 file changed)
    • [win32] Fix some coverity issues. (PR:10456, 4 commits, 3 files changed)
    • [language] fix empty string comment after ec5b24d9ecd6a99939a52b4e32e2ece712b04bab (e51e752f)
  2. newclock5:
    • New commits in this build:
      • AE: fix mem leak in tempo filter (03b007c3)
  3. kernel 4.7.y:
      • config: Enable SERIAL_SC16IS7XX_SPI (581968eb)
      • config: Add CONFIG_IPVLAN module (1407c9e6)
      • config: Add CONFIG_VXLAN module (30bfac46)
      • enable gembird joypad support (18a7d434)
      • config: Remove CONFIG_TRIM_UNUSED_KSYMS (3e1b1adc)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: libdrm: update to 2d00869
    • Added: [env] patch: mesa: update to 12.1.0-devel
    • Added: [env] patch: linux: Enable DRM_AMD_POWERPLAY (power management), DRM_AMDGPU_CIK (pre-Polaris support) and DRM_AMD_ACP (audio co-pro)
    • Added: [env] PR:736: mesa: update to 12.0.3
    • Added: [env] PR:737: linux: update to linux-4.7.4
    • Added: [env] PR:738: scripts/mkimage: Add run mode, remember default selection, resize gpt partitions
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-09-15, 20:37)popcornmix Wrote:
(2016-09-15, 19:17)TVPL Wrote: Mid, treble clearly but bass hums...
I've checked again: Hias's update for Wolfson's wm5102 chipset, not for Digi+ with wm8804G and Milhouse's config is correctly (in overlay/hifiberry-digi.dtbo)
Are you using toslink connection? Is passthrough enabled?
What are you connected to? Have you ever had the hifiberry sounding good?
Sorry about late. I'm playing RPi2 in my car and connected following: HU(Head Unit) <-- HDMI <-- RPi2 & HiFi Digi+ --> S/PDIF --> Audison Bit Ten D --> Pioneer Amplifier --> Focal Speaker
- Pass through: disabled.
- Sound output through optical in Digi+ have the mid, treble, sound field and sound stage a bit better through HDMI, but more bass hums (with same preset in Bit Ten D)
- I heard that HiFi Dac sound better but don't try any more
(2016-09-15, 12:23)popcornmix Wrote: Identifying the exact build that introduced the problem would help narrow it down.
Tested clean Libreelec install and started updates from build 906 till 915.
On all updates there are no problems with divx with srt subs. Subs are only displayed when spoken and disappear when not spoken.
Even tested with Estausy mod skin (as suggested as source of the problem in one of the posts) with all dependencies installed and everything works as should.
Not tested any piracy addons.
Hope this helps.
Hi, I just upgraded Testbuilds for RPI2 from
LibreELEC-RPi2.arm-8.0-Milhouse-20160812210421-#0812-g54cf9f3.tar
to
LibreELEC-RPi2.arm-8.0-Milhouse-20160915223035-#0915-gd875a87.tar
Now listening to radio station there iSads the playlist of the radio station missing. Only time and radio station information is shown but not the actual title playing.
pr-boh
Sad
Does anyone know why mp3streams Addon isn´t work under millhouse image with kodi 17.
Get an Log Error anytime.
Do anyoneknow how to fix this?
Last night it looks like audio keep alive seems to be the winner with a few hours of testing but I won't call it yet. I will keep testing and reporting.
HTPC(s): All running LibreELEC
  • AMD 2200G APU on Gigabyte AB350N-Gaming WIFI-CF
  • RPI3 x2 | RPI2 x2
NAS: FreeNAS (Latest Stable) | NFS/CIFS
(2016-09-16, 14:52)eikman2k Wrote: Does anyone know why mp3streams Addon isn´t work under millhouse image with kodi 17.
Provide a debug log (wiki).
(2016-09-16, 12:38)pr-boh Wrote: Hi, I just upgraded Testbuilds for RPI2 from
to
pr-boh
Sad
+1 but this seems a general kodi problem not Milhouse build. With my android nightly I have the same problem but only the newer builds. The build from 20160905 is ok.
Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
I just tried build #0904 and it's working fine. So problem must have started #905 or #906 ... (using .srt subtitles, .mp4 movies, OMX player)
Issue : SRT subtitles staying on screen even after dialogue has finished....
Hi Milhouse,
I've checked back and the SRT subtitles breaks with build #0906.(mp4 movie and OMX)
Working fine on #0905..
Hope this helps narrow down the problem.
Kind Regards Bucky
I see further up someone else has done some tests without a problem.
So heres some info on my setup, using rbp3, with a WiFi dongle, remote control and 2 hard drives attached, the addons I'm using are YouTube, iPlayer, extended info script and backup.
I will start uninstalling the addons and see if it makes a difference, but I doubt it. ?
Update:
No difference with addons, and not required dependencies removed..
The SRT problem seems to be OMX specific, not seeing any issue with MMAL.
I can also confirm the problem starts with #0906.
Here's a 16MB sample (.avi and .srt) that demonstrates the issue: https://www.dropbox.com/s/nmr2n0akau4678...t.zip?dl=0
From the outset (with OMX enabled, MMAL disabled or enabled) subtitles remain on screen longer than they should, sometimes subtitles running into one another. Some subtitles don't appear at all (or appear very briefly/too late), for example the third subtitle, "the police who investigate crime..." isn't shown.
With MMAL enabled (and OMX disabled), subtitles appear normally.
That could be right. Tested it oke with MMAL indeed.
Edit:
OMX enabled now and run into problem.
Yep, sub's working fine with MMAL.
Only problems I have with MMAL, is it slows everything down for me.
Going thru the menus isn't smooth anymore, and it makes the video freeze every time I press a remote key and move menu.
Strange as I would have thought the pi3 was powerful enough for this.
All my movies are 720p with fairly low bitrates, so nothing too strenuous.
  • 146
  • 147
  • 148(current)
  • 149
  • 150
  • 218
LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)19
