2016-10-03, 23:30
New LibreELEC.tv Krypton build #1003: RPi / RPi2
(Supercedes previous build)
Based on tip of LibreELEC.tv master (d5988041, changelog) and tip of XBMC master (8d6e828a, changelog) with the following modifications:
# uname -a
Linux rpi512 4.7.6 #1 Mon Oct 3 21:04:53 BST 2016 armv6l GNU/Linux
# vcgencmd version
Sep 21 2016 13:17:10
Copyright (c) 2012 Broadcom
version 2eaf52cc53435b5ce67253af1487f9a4f9f96e2d (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161003210353-#1003-gd598804 [Build #1003]
# vcdbg log msg 2>&1 | grep DTOK
002388.918: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
- Includes latest bcm2835-driver master (91c30e01, ahead +1)
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (048e7737, ahead +59)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (9a14177d), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780, +3), pvr.demo (01c68c88), pvr.dvblink (e842db92, +4), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30, +4), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (845479b6, +10), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3, +7), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd, +8), pvr.vdr.vnsi (dd95edef, +2), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] kodi-100.17-dbupgrade-dynamic-splash-message.patch: use upstream alternative
- Exclude [env] kodi-999.99-PR10345.patch: closed upstream, no longer required
- Exclude [env] kodi-999.99-PR10501.patch: merged upstream
- Exclude [env] kodi-999.99-PR10502.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Exclude [env] pvr.dvblink-0001-PR54.patch: merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
- Include [env] patch: ffmpeg: update to ffmpeg-3.1.4-Krypton-Beta3
- Include [env] PR:752: linux: extra options for Baytrail and 32-bit EFI
- Include [env] PR:786: xf86-video-ati: add xorg-radeon.conf to enable dri3 and glamor
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:30: enable samba at wizard (LibreELEC-settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
- Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
- Include [pkg] PR:10594: [gui] smartplaylisteditor: convert spinners etc to regular buttons
- Revert [pkg] d44e0212: Untested: android MediaDRM (reverted: breaks linux build) (inputstream.mpd)
- Revert [pkg] 9a14177d: mediandk (reverted: breaks linux build) (inputstream.mpd)
- [PVR] Fix CPVRDirectory::GetDirectory not to return false in case PVR is not yet (compeletely started).
- LibreELEC.tv:
- XBMC:
- Remove home screen info mapping from remote.xml (PR:10585, 1 commit, 1 file changed)
- Amlogic: fixes to hardware decoding blacklist (PR:10597, 2 commits, 3 files changed)
- [PVR] Fix CPVRDirectory::GetDirectory not to return false in case PVR is not yet (compeletely started). (PR:10613, 1 commit, 1 file changed)
- Resolution: Don't let code assumption from before 2k break behaviour (PR:10610, 1 commit, 1 file changed)
- AESinkAUDIOTrack: Workarounds for AML chips in non AML mode (PR:10488, 5 commits, 3 files changed)
- inputstream.mpd:
- mediandk (9a14177d)
- Reverted: [pkg] 9a14177d: mediandk (reverted: breaks linux build) (inputstream.mpd)
