2016-11-14, 02:36
(2016-11-14, 00:58)bill_orange Wrote: Your screen looks very much like mine with only incidental differences. I am not running a static IP. I seems to be that is unlikely to be the problem since I can connect, and play KODI remotely through the web interface. The only problem is having sound come out the local device (stream) from Kodi remotely.
I strikes me as unlikely to be the Choir front end or the browser since I am seeing the same behavior in Yatse.
Here is a log file.
http://sprunge.us/eYTj
Maybe there's a problem accessing local content via the virtual file system (vfs). Could you try some old builds to see if this is a recently introduced problem. If older builds behave differently (ie. they work) then identifying the first non-working build would be the next step.
