2016-04-29, 15:14
please anyone upload /sys/class/drm/card0/error
(2016-04-29, 15:01)sunnyfunny Wrote:(2016-04-29, 13:32)b0mb Wrote: here is my log of GUI crash that happens with all builds after 21.04.
http://sprunge.us/WZEU
Same Problem on my NUC3700
@millhouse
can you switch back to Kernel which is used in builds before 21.04?
(2016-04-29, 07:14)fritsch Wrote:Quote:[ 2.057769] Hardware name: Shuttle Inc. XH61V/FH61V, BIOS 1.05 05/03/2013
[ 2.057771] Workqueue: events output_poll_execute
[ 2.057773] 0000000000000000 ffffffff812b6f16 ffff880119f57b98 0000000000000000
[ 2.057774] ffffffff8103a756 0000000000000000 ffff880119f57bf0 0000000000000000
[ 2.057775] 000000000000003c ffff8800d0c54e08 0000000000000001 ffffffff8103a7b5
[ 2.057775] Call Trace:
[ 2.057778] [<ffffffff812b6f16>] ? dump_stack+0x5a/0x6f
[ 2.057780] [<ffffffff8103a756>] ? __warn+0xc8/0xe1
[ 2.057781] [<ffffffff8103a7b5>] ? warn_slowpath_fmt+0x46/0x4e
[ 2.057783] [<ffffffff81848087>] ? _raw_spin_lock_irqsave+0xe/0x29
[ 2.057784] [<ffffffff81378fed>] ? drm_wait_one_vblank+0x123/0x13c
[ 2.057786] [<ffffffff810636ce>] ? wake_up_atomic_t+0x1f/0x1f
[ 2.057788] [<ffffffff814e01e7>] ? ironlake_crtc_enable+0xac9/0xb90
[ 2.057789] [<ffffffff814c56d7>] ? hsw_write64+0x5/0x5
[ 2.057790] [<ffffffff814dddbb>] ? intel_atomic_commit+0x5c2/0x101c
[ 2.057792] [<ffffffff8138ae6c>] ? drm_atomic_check_only+0x273/0x52a
[ 2.057794] [<ffffffff8137127d>] ? restore_fbdev_mode+0x109/0x223
[ 2.057795] [<ffffffff81372a3d>] ? drm_fb_helper_restore_fbdev_mode_unlocked+0x2b/0x5e
[ 2.057796] [<ffffffff81372aa6>] ? drm_fb_helper_set_par+0x36/0x41
[ 2.057797] [<ffffffff81372a0a>] ? drm_fb_helper_hotplug_event+0xab/0xb3
[ 2.057798] [<ffffffff81368cc1>] ? output_poll_execute+0x12b/0x15a
[ 2.057800] [<ffffffff8104b188>] ? process_one_work+0x139/0x1d4
[ 2.057801] [<ffffffff8104b6d3>] ? worker_thread+0x1d3/0x29e
[ 2.057802] [<ffffffff8104b500>] ? rescuer_thread+0x2b6/0x2b6
[ 2.057803] [<ffffffff8104f1ff>] ? kthread+0x95/0x9d
[ 2.057804] [<ffffffff81848382>] ? ret_from_fork+0x22/0x40
[ 2.057805] [<ffffffff8104f16a>] ? init_completion+0x1d/0x1d
[ 2.057808] ---[ end trace 8421c749f3f31a64 ]---
Kernel bug with your hardware. Post your Xorg.0.log please.
(2016-04-26, 01:46)Milhouse Wrote:(2016-04-25, 22:01)M4tt0 Wrote: Unfortunately, no success with any of the above builds. Am using a Logitech K400r wireless USB keyboard. Never had issues with that so far...
Now that you mention *USB* keyboard (rather than just "keyboard", which I assumed to mean on-screen keyboard - my bad), has this ever worked correctly with any earlier version of OpenELEC?
As far as I'm aware, OpenELEC has very limited OS localisation support, and this limited support hasn't really changed in LibreELEC.
There is a localisation change in Kodi in #0418 (PR9550, which isn't actually working as intended due to *ELEC's limited localisation support), but this change shouldn't have any effect on your USB keyboard.
(2016-04-29, 18:10)M4tt0 Wrote: @Milhouse: Gee, probably tested 10 different version until I arrived at the result.
The "wrong keyboard layout" problem for my external USB keyboard started with your OpenELEC (that is correct: OPEN) tesbuild 7.0 #1119. Debug log
All of your earlier OE builds in the "old" thread have another problem though. My USB keyboard does not work AT ALL. Debug log of latest version with this sympton here (OE 7.0 #1117).
This is contrasting my experience with my working production system which runs on the same HTPC, just from the internal SSD instead and does not have these problems.
Which leaves me to speculate that this might(!) be some kind of USB problem: On the test system external USB keyboard and USB HDD are attached (as the test system runs from there), whereas on the production system only the external USB keyboard is attached (as it runs from the internal SSD). Upstream problem with x-server? But any thoughts and advice appreciated.
(2016-04-29, 22:56)Roby77 Wrote: And also
A
- Left key of remote act as right key
# uname -a
Linux LibreELEC 4.6.0-rc5 #1 SMP Fri Apr 29 23:27:52 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160429232628-#0429b-gac8e298 [Build #0429b]
