ah ok i don't use tv but i notice also that in library arrow doesn't scroll anymore and i must use +/- channel button
Milhouse
Retired Team-Kodi Member
There'll be a new kernel (4.6-rc6) tonight. Don't know if it fixes either issue.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Yes hope too that new kernel fixes gpu hang
New build is still crashing on Braswell...
Gesendet von meinem LG-D855 mit Tapatalk
Milhouse
Please report if auto-repeat is still not working for some of you - the last build #0505 is a completely clean build just in case anything was left over from a libinput-era build.
If auto-repeat is still not working then it's either a kernel issue, or one of the other packages bumped in #0423.
