TVDB are updating their site. Their site currently has a number of bugs that have broken the TVDB scraper and any add-on that relies on TVDB data. TVDB are working to rectify the problems.
  • 35
  • 36
  • 37(current)
  • 38
  • 39
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-05-20, 23:24)Milhouse Wrote: @Roby77 can you also test #0520 and see if that helps you with your displays that work only some of the time.
Thank you i will try and report in next days
(Maybe could be related this in the log repeated many times ?
7.606922] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "HDMI-A-1")
Edit: seems after ten play/stop that handshake from 24p to 50hz (gui) is really faster..or maybe is only placebo effect Big Grin
Edit2: no autorepeat doesn't work also for me, with 0509x was fine
Thanks both.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
About your patch for i915 a comment about the patch
.... there is no longer a several second hang on boot or when changing the screen resolution.
However, the HDMI output continues to be broken, and the log messages about the EDID checksum being invalid still appear.
This is exactly my problem sometimes
(2016-05-20, 22:03)ragnaroek Wrote: Hi,
I did some research with clean LibreElec builds, only the stock addons enabled,
the builds #0330 to #0403 are absolutely fine, no problems with my 100% CPU issue,
with #0405, I'm getting a kernel panic,
with #0406 to #0519, I have the 100% CPU issue, but only on systems with a Nvidia GPU,
no issues with the builds, on systems with a Intel IGPU, expect #0405.
Right with " DEBUG: ------ Window Init (VideoFullScreen.xml) ------ " one CPU core is fully locked at 100%,
on Nvidia systems, init a other window like DEBUG: ------ Window Init (MyVideoNav.xml) ------, immediately
drops the CPU usage to ~10% - 12%.
Was there a major change in Kodi, between f6264876 and ce28cb6, that could cause this?
I can reproduce this on all Kodi 17 installations, Arch, Suse, Ubuntu ..., from ce28cb6 on,
VideoFullScreen is causing my issue on Nvidia system, and no problems with Intel system.
I also cross checked this two of my mates, with the same result.
Or maybe I'm absolutely stupid and doing something wrong.
I found a posting on a German Kodi forum, that chap
is also digging in that issue.
Best regards
OK, I'm able to reproduce this on my Revo 3700 with ION2.
I do remember now that LE #0405 was built incorrectly using popcornmix linux and newclock5 commits on top of the normal x86 linux and kodi commits - this likely explains the kernel panic.
I've also reproduced the high-CPU load behaviour in OE: OE #0402 is "normal", while OE #0410 shows increased CPU loading on one CPU core.
OE #0402 watching a video, full screen:
Mem: 1074716K used, 965672K free, 206484K shrd, 68904K buff, 593148K cached
CPU0:  2.6% usr  3.0% sys  1.6% nic 92.8% idle  0.0% io  0.0% irq  0.0% sirq
CPU1:  6.4% usr  6.6% sys  0.0% nic 86.5% idle  0.0% io  0.0% irq  0.4% sirq
CPU2:  1.6% usr  0.8% sys  0.0% nic 96.9% idle  0.4% io  0.0% irq  0.2% sirq
CPU3:  8.1% usr  9.7% sys  0.0% nic 81.7% idle  0.0% io  0.0% irq  0.4% sirq
Load average: 0.79 0.46 0.18 2/189 1067
  PID  PPID USER     STAT   VSZ %VSZ CPU %CPU COMMAND
  845   839 root     S    2671m133.5   1 10.1 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
1065  1060 root     R     7732  0.3   1  0.0 top
  289     2 root     SW       0  0.0   1  0.0 [kworker/1:4]
  249     1 root     S <   212m 10.6   1  0.0 /usr/bin/pulseaudio --system
  444   442 root     S      99m  4.9   1  0.0 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /storage/.config/xorg.conf -ignoreABI
  468     1 root     S    29148  1.4   0  0.0 /usr/bin/smbd --configfile=/run/samba/smb.conf
  418     1 root     S    27144  1.3   1  0.0 /usr/bin/nmbd --configfile=/run/samba/smb.conf
  700     1 root     S    23836  1.1   0  0.0 /usr/bin/fluxbox
  471     1 root     S    19604  0.9   3  0.0 /usr/bin/wpa_supplicant -u
OE #0410 watching the same video, full screen:
Mem: 1055664K used, 984724K free, 208084K shrd, 67384K buff, 600168K cached
CPU0: 26.8% usr 72.7% sys  0.0% nic  0.0% idle  0.0% io  0.0% irq  0.3% sirq
CPU1:  5.4% usr  4.6% sys  1.7% nic 87.7% idle  0.3% io  0.0% irq  0.0% sirq
CPU2:  0.8% usr  0.6% sys  0.0% nic 98.5% idle  0.0% io  0.0% irq  0.0% sirq
CPU3:  5.5% usr  2.1% sys  0.0% nic 92.3% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 1.22 0.55 0.21 5/187 997
  837   832 root     R    2675m133.7   0 28.6 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  412     1 avahi    S    19116  0.9   1  0.0 avahi-daemon: running [OpenELEC.local]
  990   987 root     R     7732  0.3   1  0.0 top
  149     2 root     SW       0  0.0   1  0.0 [jbd2/sda2-8]
  251     1 root     S <   212m 10.6   3  0.0 /usr/bin/pulseaudio --system
  424   422 root     S     113m  5.6   2  0.0 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /storage/.config/xorg.conf -ignoreABI
  598     1 root     S    29148  1.4   2  0.0 /usr/bin/smbd --configfile=/run/samba/smb.conf
  419     1 root     S    27144  1.3   2  0.0 /usr/bin/nmbd --configfile=/run/samba/smb.conf
  684     1 root     S    23836  1.1   2  0.0 /usr/bin/fluxbox
  493     1 root     S    19604  0.9   1  0.0 /usr/bin/wpa_supplicant -u
Build OE #0410 is also using the 340.96 nvidia driver, assuming this is even relevant.
More likely this is a fernetmenta VideoPlayer change, where an old nvidia "quirk" has been dropped which may now result in the CPU busy-waiting while rendering. The Render/Wait changes in LE #0404c and LE #0406 look likely candidates for this new behaviour - in OE #0410 this is merged as PR9542.
Since I'd already spent the time working out the changes in LE #0404c/#0405/#0406, here they are - perhaps FernetMenta can comment when he's available.
  • #0404c (compared with #0403):
    • LibreELEC:
      • build: Include git hash in /etc/os-release for release builds too (PR:87, 1 commit, 1 file changed)
      • RPi/RPi2: Linux 4.4.6 and Kodi Jarvis updates (PR:78, 2 commits, 4 files changed)
      • RPi: Stop enabling serial console in devel images (PR:84, 1 commit, 2 files changed)
      • console: enable cursor for textmode and RPi serial consoles (PR:85, 1 commit, 3 files changed)
      • u-boot: update to u-boot-imx6-408544d for imx6 project (PR:80, 1 commit, 3 files changed)
      • imx6: add second kernel 4.4 from xbian (PR:81, 1 commit, 8 files changed)
      • RBP: Update firmware to be in sync with kernel (PR:92, 1 commit, 2 files changed)
      • rtmpdump: cleanup download url (PR:82, 1 commit, 1 file changed)
      • libbdplus: Fix download URL (PR:93, 1 commit, 1 file changed)
      • imx6: add irqbalanced daemon for linux 4.4 (PR:94, 1 commit, 3 files changed)
      • v86d: Fix download url (PR:95, 1 commit, 1 file changed)
    • Kodi:
      • [DVDVideoCodecOpenMax] update after d5f63a8 (PR:9539, 1 commit, 2 files changed)
      • VideoPlayer: add method for requesting desired video resolution to de… (PR:9531, 1 commit, 12 files changed)
      • [json] - add support for tvshow status (PR:9537, 1 commit, 2 files changed)
      • [cmake] Add cmake parameter to BuildSetup.bat (PR:9529, 5 commits, 5 files changed)
      • [python] add mediatype to setinfo for music (PR:9396, 1 commit, 4 files changed)
      • [cmake] Fix android build (PR:9540, 2 commits, 1 file changed)
      • [gui] - remove go-to-root context menu buttons (PR:9536, 1 commit, 6 files changed)
      • [buildsystem][win32] Updated some more build files to vs2015 that was forgotten about (PR:9541, 1 commit, 4 files changed)
      • [json] fix params order for SetTVShowDetails (PR:9544, 1 commit, 1 file changed)
      • [adsp] rework to new system who already on PVR (PR:9483, 4 commits, 26 files changed)
      • VideoPlayer: inputstream, fix cp error (e9a6d59f)
      • [lang][skin.estuary] updated language files from Transifex (da74385e)
      • [lang][skin.estouchy] updated language files from Transifex (02e2e021)
    • FernetMenta (new additions):
      • VideoPlayer: drop WaitPresentTime (6ba07493)
    • Changes not merged upstream:
      • PR:178: xf86-video-nvidia-legacy: Change driver from 304.x to 340.x
  • #0405:
    • LibreELEC:
      • LibCEC patches update (PR:88, 2 commits, 4 files changed)
      • projects/imx6/patches/u-boot: set delay of 1 second to speed up the boot (PR:97, 1 commit, 1 file changed)
      • projects/imx6/linux: disable PCI MSI interrupts for kernel 4.4 (PR:96, 1 commit, 1 file changed)
      • screensaver.shadertoy: Add package (PR:73, 1 commit, 1 file changed)
      • image: BUG_REPORT_URL should reflect origin repo used for build (PR:91, 1 commit, 1 file changed)
      • preset directories and paths for picons (PR:89, 2 commits, 2 files changed)
      • readme: update README.md text (PR:76, 1 commit, 1 file changed)
      • visualization.shadertoy: fix build for OpenGLES (PR:100, 1 commit, 1 file changed)
      • Package updates (PR:103, 6 commits, 7 files changed)
        • mesa: update to 11.2.0
        • bluez: update to 5.38
        • setuptools: update to 20.6.7
        • Pillow: update to 3.2.0
        • fontconfig: update to 2.11.94
        • inputproto: update to 2.3.2
      • libiconv: add libiconv package (PR:104, 1 commit, 3 files changed)
      • addons: add OSCam (PR:99, 1 commit, 15 files changed)
      • addons: version bump for LE 7.0 Beta 1 (PR:90, 1 commit, 21 files changed)
      • Hyperion! (PR:39, 3 commits, 10 files changed)
    • Kodi:
      • Videoplayer code cleanup & race condition fix (PR:9442, 4 commits, 2 files changed)
      • Cleanup dll loader / posix win32 emulation functions. (PR:8798, 13 commits, 66 files changed)
      • [EGLIMX] Added category D framebuffer modes (PR:9551, 1 commit, 1 file changed)
      • [guilib][fix] Fix "vector iterator not incrementable". dialog->Close … (PR:9547, 1 commit, 1 file changed)
      • [Builtins/Cec] add missing registrations (PR:9535, 1 commit, 1 file changed)
      • [EGLIMX] Added category D framebuffer modes (c70dfe76)
    • FernetMenta:
      • Not present - #0405 incorrectly built using Raspberry Pi linux and kodi (newclock5) patches
  • #0406:
    • LibreELEC:
      • scripts/clean: allow cleaning package for all projects (PR:108, 1 commit, 1 file changed)
      • scripts/clean: fixup previous commit (PR:109, 1 commit, 1 file changed)
      • boblightd: bump version (PR:110, 1 commit, 1 file changed)
      • hyperion: updated description and bump version (PR:111, 1 commit, 2 files changed)
      • Upstream changes (PR:101, 5 commits, 5 files changed)
    • Kodi:
      • small syntax typo (PR:9554, 1 commit, 1 file changed)
      • VideoPlayer: set speed on demuxer when speed of player is changed (PR:9555, 1 commit, 1 file changed)
      • remove some unused/duplicate context menus (PR:9548, 4 commits, 8 files changed)
      • videoinfotag: fix typo introduced in e6e2d0ace5cfe6191b8f7727ced1747854254ce4 (PR:9558, 1 commit, 1 file changed)
      • [coverity] Some cleanup/fixes (PR:9512, 14 commits, 23 files changed)
      • [Estouchy] change include syntax (PR:9562, 1 commit, 1 file changed)
      • VideoPlayer: simplify video rednering (c7bb0a59)
      • simplify render loop (002a4df8)
      • VidoePlayer: do not block renderthread if no gui was rendered and video is separate layer (6b453df8)
      • move FinishPipeline from application to gfx context (06e797f3)
      • squash: fix build after WaitPresentTime (3e2e4f2a)
same result here,
#0403 played full screen
1  [||||||||||||||        14.2%]     Tasks: 23, 32 thr; 2 running
  2  [|||        2.5%]     Load average: 0.49 0.23 0.08
  Mem[|||||||||||||||||||||||||                                                      414/3943MB]     Uptime: 00:01:39
  Swp[        0/0MB]
  PID USER      PRI  NI  VIRT   RES   SHR S CPU% MEM%   TIME+  Command
  652 root       20   0 1546M  371M 93620 S 19.4  9.4  0:13.46 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  667 root       20   0 1546M  371M 93620 S  5.3  9.4  0:04.41 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  747 root       20   0 1546M  371M 93620 S  0.5  9.4  0:00.43 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  748 root       20   0 1546M  371M 93620 S  0.5  9.4  0:00.67 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  751 root       20   0 1546M  371M 93620 S  0.5  9.4  0:00.02 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  744 root       20   0  9920  2364  1980 R  0.5  0.1  0:00.07 htop
   410 root       20   0  113M 59248 37028 S  0.0  1.5  0:01.36 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /etc/X11/xorg-nvidia.conf -ignoreABI
  330 avahi      20   0 19116  2804  2588 S  0.0  0.1  0:00.02 avahi-daemon: running [LibreELEC-kvm.local]
    1 root       20   0 11208  4364  2896 S  0.0  0.1  0:05.08 /usr/lib/systemd/systemd
  219 root       20   0  9180  1952  1740 S  0.0  0.0  0:00.02 /usr/lib/systemd/systemd-journald
  234 root       20   0 17024  3368  2316 S  0.0  0.1  0:00.05 /usr/lib/systemd/systemd-udevd
  288 root        9 -11  213M  6760  5504 S  0.0  0.2  0:00.00 /usr/bin/pulseaudio --system
  293 root        9 -11  213M  6760  5504 S  0.0  0.2  0:00.00 /usr/bin/pulseaudio --system
  244 root        9 -11  213M  6760  5504 S  0.0  0.2  0:00.03 /usr/bin/pulseaudio --system
  248 dbus       20   0 16984  2900  2460 S  0.0  0.1  0:00.03 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
  267 root       20   0 13928  2120  1904 S  0.0  0.1  0:00.50 /usr/sbin/eventlircd -f --evmap=/etc/eventlircd.d --socket=/run/lirc/lircd --release=_UP
  270 root       20   0  8912  2012  1816 S  0.0  0.0  0:00.00 /usr/lib/systemd/systemd-logind
  279 root       20   0  7728  1604  1512 S  0.0  0.0  0:00.00 /sbin/crond -f -S
  323 root       20   0 15140  3640  3280 S  0.0  0.1  0:00.00 /usr/sbin/sshd -D
  326 root       20   0 18344  3892  3476 S  0.0  0.1  0:00.01 /usr/sbin/connmand -nr --config=/etc/connman/main.conf
  335 root       20   0 16316   228     0 S  0.0  0.0  0:00.01 /usr/bin/rpcbind
  339 root       20   0 19604  2100  1780 S  0.0  0.1  0:00.00 /usr/bin/wpa_supplicant -u
  350 root       20   0 27164  2992  2580 S  0.0  0.1  0:00.00 /usr/bin/nmbd --configfile=/run/samba/smb.conf
  370 root       20   0 29168  4448  3960 S  0.0  0.1  0:00.00 /usr/bin/smbd --configfile=/run/samba/smb.conf
  391 root       20   0 13968   572   488 S  0.0  0.0  0:00.00 xorg-launch-helper -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /etc/X11/xorg-nvidia.conf -ignoreABI
  632 root       20   0 23800  5188  4320 S  0.0  0.1  0:00.02 /usr/bin/fluxbox
#0406 played full screen - same video
1  [||||||||                                              11.3%]     Tasks: 23, 43 thr; 2 running
  2  [||||||||||||||||||||||||||||||||||||||||||||||||||||||95.7%]     Load average: 0.98 1.03 0.91
  Mem[|||||||||||||||||||                              480/3938MB]     Uptime: 00:25:07
  Swp[                                                      0/0MB]
  670 root       20   0 1689M  442M  100M R 103. 11.2 23:46.23 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  683 root       20   0 1689M  442M  100M S  4.8 11.2  1:16.00 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  693 root       20   0 1689M  442M  100M S  1.0 11.2  0:03.58 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  865 root       20   0 1689M  442M  100M S  0.5 11.2  0:03.10 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
1095 root       20   0  9888  2488  2108 R  0.5  0.1  0:01.26 htop
   435 avahi      20   0 19120  2872  2652 S  0.0  0.1  0:00.16 avahi-daemon: running [LibreELEC-kvm.local]
  687 root       20   0 1689M  442M  100M S  0.0 11.2  0:00.30 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  763 root       20   0 1689M  442M  100M S  0.0 11.2  0:00.66 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  675 root       19  -1 1689M  442M  100M S  0.0 11.2  0:00.57 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  680 root       21   1 1689M  442M  100M S  0.0 11.2  0:00.13 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  694 root       20   0 1689M  442M  100M S  0.0 11.2  0:02.33 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  691 root       20   0 1689M  442M  100M S  0.0 11.2  0:00.17 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  690 root       20   0 1689M  442M  100M S  0.0 11.2  0:00.31 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  249 dbus       20   0 16988  3056  2612 S  0.0  0.1  0:00.04 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --sys
  529 root       20   0  113M 59544 37096 S  0.0  1.5  0:04.57 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config
  649 root       20   0 23804  5188  4316 S  0.0  0.1  0:00.04 /usr/bin/fluxbox
  819 root       20   0 19840  4100  3648 S  0.0  0.1  0:00.11 sshd: [email protected]/0
#0403 played menu over full screen - same video
1  [        0.0%]     Tasks: 23, 32 thr; 1 running
  2  [||||||        5.1%]     Load average: 0.44 0.33 0.15
  Mem[|||||||||||||||||||||||||                                                      425/3943MB]     Uptime: 00:04:36
  Swp[        0/0MB]
  652 root       20   0 1546M  381M 94132 S 15.4  9.7  1:00.50 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  667 root       20   0 1546M  381M 94132 S  5.1  9.7  0:13.83 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  747 root       20   0 1546M  381M 94132 S  0.5  9.7  0:01.82 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  749 root       20   0 1546M  381M 94132 S  0.5  9.7  0:00.54 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  657 root       19  -1 1546M  381M 94132 S  0.5  9.7  0:00.14 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  750 root       20   0 1546M  381M 94132 S  0.0  9.7  0:00.62 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  748 root       20   0 1546M  381M 94132 S  0.0  9.7  0:01.38 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  751 root       20   0 1546M  381M 94132 S  0.0  9.7  0:00.09 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  672 root       20   0 1546M  381M 94132 S  0.0  9.7  0:00.28 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  665 root       21   1 1546M  381M 94132 S  0.0  9.7  0:01.05 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  656 root       20   0 1546M  381M 94132 S  0.0  9.7  0:00.28 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  330 avahi      20   0 19116  2804  2588 S  0.0  0.1  0:00.04 avahi-daemon: running [LibreELEC-kvm.local]
  744 root       20   0  9920  2364  1980 R  0.0  0.1  0:00.25 htop
   739 root       20   0 17700  3972  3528 S  0.0  0.1  0:00.01 sshd: [email protected]/0
#0406 played menu over full screen - same video
1  [|||||                                                  4.8%]     Tasks: 23, 45 thr; 2 running
  2  [|||||                                                  6.1%]     Load average: 0.92 1.07 0.97
  Mem[|||||||||||||||||||                              522/3938MB]     Uptime: 00:30:25
  Swp[                                                      0/0MB]
  670 root       20   0 1764M  482M  104M S 15.1 12.3 29:00.62 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  683 root       20   0 1764M  482M  104M S  5.0 12.3  1:31.07 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  863 root       20   0 1764M  482M  104M S  1.5 12.3  0:11.95 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  864 root       20   0 1764M  482M  104M S  0.5 12.3  0:05.75 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
2331 root       20   0 1764M  482M  104M S  0.5 12.3  0:00.55 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  693 root       20   0 1764M  482M  104M S  0.5 12.3  0:04.45 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
2332 root       20   0 1764M  482M  104M S  0.5 12.3  0:00.30 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  763 root       20   0 1764M  482M  104M S  0.5 12.3  0:00.84 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  681 root       21   1 1764M  482M  104M S  0.0 12.3  0:06.64 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
  865 root       20   0 1764M  482M  104M S  0.0 12.3  0:03.81 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
1095 root       20   0  9888  2488  2108 R  0.0  0.1  0:01.57 htop
  435 avahi      20   0 19120  2872  2652 S  0.0  0.1  0:00.18 avahi-daemon: running [LibreELEC-kvm.local]
  819 root       20   0 19840  4100  3648 S  0.0  0.1  0:00.12 sshd: [email protected]/0
  526 root       20   0 27168  2472  2056 S  0.0  0.1  0:00.01 /usr/bin/nmbd --configfile=/run/samba/smb.conf
Thank you @Milhouse for digging into that!
Seems to be a Kodi 17 / VideoPlayer issue, as I'm able to reproduce this on all Nvidia setups,
now we have to wait for FernetMenta.
Best regards
http://pastebin.com/bXWCV3Yq
#520. Same error. Might be this line
13:31:14 112.375107 T:140128475379456   DEBUG: CVideoPlayerVideo::CalcDropRequirement - dropped in decoder, lateframes: 14, Bufferlevel: 3, dropped: 1
#420 no issues... UPDATE: I switched back to #420 and for the first time i played a file i got the exact same issue. I tried to replicate it but after the first try all played fine... Huh
ASRock Beebox J3160 4GB RAM 120GB SATA SSD - Harmony Elite BT
Intel NUC Kit DN2820FYKH 4GB RAM 120GB SATA SSD - Harmony Smart Control BT
all @ Libreelec Testbuild
HP N54L @ Ubuntu 14.04.4 Minimal Server / MySQL DB
HP N40L @ Ubuntu 14.04.4 Minimal Server
OK so i started with irusaks retroplayer build as an upgrade it went OE6 - LE7- LE8 , After the upgrade I couldnt get the game addons to run until i did a full reset however after the reset my remote stopped working. I tested moving to teh millhouse LE8 but still no remote , So far a restore of teh backup fixed the issue but i dont know what. Im a little light on log files after all this but will reset and test
Im on a Intel NUC - DCCP847DYE using a USB MCE IR reciever and Harmony 950 remote
"my remote stopped working" - if you mean auto-repeat stopped working, it's a known issue with the current 4.6 kernel in LE8 builds.
If you had a more serious failure of your remote, such as your remote not working at all, then that's not a known issue and would require further investigation (dmesg, lsusb etc.)
New LibreELEC.tv Krypton build #0521: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.0 #1 SMP Sat May 21 23:16:37 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160521231430-#0521-gd4dc519 [Build #0521]
Based on tip of LibreELEC.tv master (d4dc5198, changelog) and tip of XBMC master (032f8103, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82, ahead +4)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (00d9ba15, ahead +19)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (29bfe9d8, +3), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (4ff1552f, +4), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (dc112316, +6), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
  • Includes commits from xbmc/master, ahead +6 (FernetMenta)
  • Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: xf86-video-intel: bump to 3fafabe
  • Include [env] patch: Fix SIGTERM patch after PR9748
  • Include [env] patch: Fix cmake after PR9750
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
  • Include [env] PR:366: mysql: update to 5.7.12
  • Include [env] PR:374: eventlircd update to new upstream
  • Include [env] PR:381: splash: Select splash image based on native resolution
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
  • Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
  • Include [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. PR:381: splash: Select splash image based on native resolution (720p still to be added)
Build Details:
  1. LibreELEC.tv:
    • squeezelite: cleanup package (PR:372, 1 commit, 1 file changed)
    • dtc: add package (PR:371, 2 commits, 2 files changed)
    • moonlight: allow building for Generic, add neon support in opus (PR:368, 4 commits, 5 files changed)
    • moonlight: bump PKG_REV (PR:380, 1 commit, 1 file changed)
  2. XBMC:
    • [PVR] Fix 'Stop recording' from inside PVR channel window, another case. (PR:9846, 1 commit, 1 file changed)
    • [test][fix] missing includes after rework of tagloader (PR:9852, 1 commit, 1 file changed)
    • [aml] settings: make useamcodec{mpeg2,mpeg4,h264} aml specific (PR:9849, 1 commit, 1 file changed)
    • rev (ef0c3cbc)
    • oops - revert previous commit (569f576e)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:381: splash: Select splash image based on native resolution
(2016-05-22, 00:30)Milhouse Wrote: "my remote stopped working" - if you mean auto-repeat stopped working, it's a known issue with the current 4.6 kernel in LE8 builds.
Hi, I mean it stopped working completely as did my Bluetooth keyboard. When I get a few hours where the TV isn't needed by my wife or kids I'll pull out the logs/dmesg, etc
(2016-04-20, 14:41)Milhouse Wrote:
(2016-04-20, 10:49)_Spook_ Wrote: 2. Stop using xf86-video-intel driver, switch to xf86 modesetting driver instead. Intel users: please report regressions!
Why?
Quite often the associated PR contains all the answers.
The PR says:
Quote:https://github.com/LibreELEC/LibreELEC.tv/pull/136
Thanks for the tip @fritsch
apparently,
the intel devs suggest using the modesetting driver + glamor
Ubuntu 16.04 may ship with the modesetting driver + glamor
But that is not true?
See for yourself:
https://bugs.freedesktop.org/show_bug.cgi?id=94843
Also, the Ubuntu 16.04 statement also does not seem to be true?
Where are the sources for these statements?
By the way, here are all the links for:
"Ditching xf86-video-amdgpu in favor of xf86-video-modesetting?"
https://bugs.freedesktop.org/show_bug.cgi?id=94841
"Ditching xf86-video-ati in favor of xf86-video-modesetting?"
https://bugs.freedesktop.org/show_bug.cgi?id=94842
"Ditching xf86-video-intel in favor of xf86-video-modesetting?"
"Ditching xf86-video-nouveau in favor of xf86-video-modesetting?"
https://bugs.freedesktop.org/show_bug.cgi?id=94844
"Ditching xf86-video-openchrome in favor of xf86-video-modesetting?"
https://bugs.freedesktop.org/show_bug.cgi?id=95524
Wink
I have an annoying video issue.
When I play more than one video, the second tends to play with a lot of tearing. The video in the link shows the issue: https://vid.me/qJ8j
This happens randomly, but so far never with debuglogging enabled (my theory is that it has something to do with the debugging overlay) but I have no idea how to test or verify that).
In the log ( http://sprunge.us/aPCj ) I turned on debug logging during the first file nad turned it off during the second. The second file plays fine, but the third one (with logging again disabled) is corrupted.
I don't know if this is a known issue, or how to proceed. @Milhouse @ fritsch any suggestions are welcome..
(2016-05-22, 14:20)tinzarian Wrote: I have an annoying video issue.
Do you have an Intel GPU? If so, a few years old?
core i3 4020y, so that makes it an Intel HD Graphics 4200
  • 35
  • 36
  • 37(current)
  • 38
  • 39
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
