Hey Milhouse just wondering why you stopped updating Openelec Testbuilds as of 04/15?
Milhouse
Retired Team-Kodi Member
#0522 includes an update (PR9862) that should help address remaining issues after PR9778. Those with remaining busy-dialog related issues please test and confirm by commenting in PR9862.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
2016-05-23, 00:34
(This post was last modified: 2016-05-23, 00:35 by smitopher.)
I have a NUC5PPYH with the Brasswell Pentium N3700 processor. I put it in Akasa fanless case.
I have a habit of feeling it to see if the fanless case is doing the job.
While running LE 7.0, when idle, it is barely above cold. After watching a 2 hour movie just warm.
Running build 518,
It gets very warm while idle and borderline hot while viewing a movie.
When debug mode is on, and idle, it reports the CPU as very busy, of 50% average of all cores.
I surmise that there are still race conditions in the Kernel when running on Brasswell.
Thanks for the hard work and the buillds. One issue, i checked kodi log nothing shows up. My pvr.hts (tvheadend) client didn't load channels after system startup. I need to deactivate and activate pvr.hts then it works immediately.
How can i debug this? Thanks in advance
