  • 52
  • 53
  • 54(current)
  • 55
  • 56
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
Build #614... ir mce is not working on braswell
Unlucky also kodi uploader crashed
Edit:downgrade to 613 solved ir problem
New LibreELEC.tv Krypton build #0614: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Tue Jun 14 21:12:35 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160614210526-#0614-g6c9db28 [Build #0614]
Based on tip of LibreELEC.tv master (6c9db285, changelog) and tip of XBMC master (44b4163a, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cdd1643c, ahead +28)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (32275717), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: binary-addon: inputstream.rtmp
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: Enable other binary addons
  • Include [env] PR:412: splash: Stop blanking splash too early in RPi boot sequence
  • Include [env] PR:428: Package updates
  • Include [env] PR:431: Revert "Merge pull request #136 from lrusak/modesetting"
  • Include [env] PR:432: build: start using .libreelec-unpack
  • Include [env] PR:433: libreelec: use build project directory for ccache
  • Include [env] PR:448: wlan-firmware: bump to 0.0.32
  • Include [env] PR:449: lirc: update to 0.9.4
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
  • Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
  • Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
  1. Fix for Settings add-on Update procedure. Update to #0614 manually, then you should be able to update using the add-on from tomorrow (#0615)
  2. lirc: update to 0.9.4
  3. Package updates: curl, llibmicrohttpd, libirman, libressl, xkeyboard-config, xf86-input-evdev, mesa, xf86-video-intel
  4. xf86-video-nvidia: update to 367.27 (link)
Build Details:
  1. LibreELEC.tv:
    • tinc: enable build from clean (PR:444, 1 commit, 1 file changed)
    • dispmanx_vnc: enable build from clean (PR:445, 1 commit, 1 file changed)
  2. XBMC:
    • [doxygen] todo list (PR:9977, 1 commit, 215 files changed)
    • [depends] bump python to 2.7.11 (PR:9978, 1 commit, 6 files changed)
    • [depends] gettext 0.19.8 (PR:9943, 1 commit, 2 files changed)
    • [xbmc][cleanup] Some minor cleanup of texture handling (PR:9960, 1 commit, 5 files changed)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:428: Package updates
    • Added: [env] PR:448: wlan-firmware: bump to 0.0.32
    • Added: [env] PR:449: lirc: update to 0.9.4
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Maybe this broke ir mce function ?
(2016-06-14, 23:40)Roby77 Wrote: Build #614... ir mce is not working on braswell
Not sure, will need some guidance on how best to debug broken IR...
(2016-06-14, 23:40)Roby77 Wrote: Unlucky also kodi uploader crashed
Do you have a debug log? How did it crash?
Yeah, IR "broken" here also on NUC6i7KYK
AppleTV 4K, LG 65E6 OLED TV, Marantz NR1606, Harmony Elite
(2016-06-15, 00:22)Roby77 Wrote: lirc: update to 0.9.4
It's possible. I think we need to start doing some serious debugging of this IR issue... Or just buy a Raspberry Pi3, they work... ;-)
(2016-06-13, 22:05)zag Wrote: Have you tried Tvheadend 4.0?
I know speaking with the devs there were certainly a lot of changes between those versions which is why both are in the repository.
I'm using v4.0 on jarvis with no issues.
Have not tried krypton with livetv yet.
Jarvis backend with 4.0.9 iirc and Krypton front-end and still live tv is poor. So must be the clients then? Krypton struggling with hstp
14 years using XBMP, XBMC and Kodi! :)
Here are logs from #0614:
dmesg | paste
http://sprunge.us/IcLE
cat $HOME/.kodi/temp/kodi.log | paste
http://sprunge.us/EdYh
EDIT: My logs are with advanced logging enabled
Here is my log (no advanced loggin enabled)
https://www.dropbox.com/s/35l71cpymppukp...4.zip?dl=0
If you run "irw" at the ssh command line do you see any output while you press buttons on the remote control?
(2016-06-15, 00:38)_Spook_ Wrote: Here are logs from #0614:
dmesg | paste
Can you run:
systemctl status eventlircd | paste
and paste the link.
Then try:
systemctl start eventlircd
and see if that makes any difference.
(2016-06-15, 00:52)Milhouse Wrote: If you run "irw" at the ssh command line do you see any output while you press buttons on the remote control?
Nothing
http://sprunge.us/NTHQ
no change
OK it's being looked into, maybe a problem with uinput. As soon as I have anything that can be tested I'll post it here.
Cool Smile Just post and I will test when I see it.
  • 52
  • 53
  • 54(current)
  • 55
  • 56
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
