  • 66
  • 67
  • 68(current)
  • 69
  • 70
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
Developer always say...No Debug Log no support.... Smile
(2016-06-27, 12:05)menno Wrote: When I connect a USB cd/dvd/Blu-ray player I cannot access it anywhere. The GUI doesnt add a DISC icon nor can I find the device through File Manager. Is this normal?
This is not supported. Connect it while powered off and boot after it is plugged in.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
OK and where should it appear than? In the Main Menus or in File Manager only? Ill check dmesg cause even pre powering it up I cannot see it anywhere. So ill test some more stuff,anyway I am curious where it should pop-up
This looks kinda bad hehe
LibreELECw:~ # dmesg | grep usb
[    0.000000] Kernel command line: root=/dev/ram0 rdinit=/init usbcore.autosuspend=-1 BOOT_IMAGE=/KERNEL boot=UUID=e2d05cb3-52a7-4c13-811c-ff9918556efe disk=UUID=13b65e6b-74a7-4a65-910f-49359823f7b3  quiet
[    0.592626] usbcore: registered new interface driver usbfs
[    0.592639] usbcore: registered new interface driver hub
[    0.592654] usbcore: registered new device driver usb
[    0.745668] usbcore: registered new interface driver rtsx_usb
[    0.758303] usbcore: registered new interface driver uas
[    0.758330] usbcore: registered new interface driver usb-storage
[    0.789318] usbcore: registered new interface driver usbhid
[    0.789324] usbhid: USB HID core driver
[    1.114939] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[    1.246126] usb 1-4: string descriptor 0 read error: -22
[    1.524888] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[    1.699548] usb-storage 1-5:1.0: USB Mass Storage device detected
[    1.699661] scsi host2: usb-storage 1-5:1.0
[    3.281104] usbcore: registered new interface driver ath3k
[    3.281579] usb 1-4: USB disconnect, device number 2
[    3.284714] usbcore: registered new interface driver btusb
[    3.591476] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[    3.766957] usb 1-4: string descriptor 0 read error: -22
[   18.606984] input: BD Remote Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/bluetooth/hci0/hci0:21/0005:054C:0306.0001/input/input14
LibreELECw:~ # lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13fd:084c Initio Corporation
Bus 001 Device 004: ID 13d3:3393 IMC Networks
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I dont see any reference, this drive works perfectly under latest stable OpenElec
//edit
Ah gettig some feedback
scsi host2: usb-storage 1-6:1.0
[13782.135792] scsi 2:0:0:0: CD-ROM            TSSTcorp DVDWBD SE-406AB  TS00 PQ: 0 ANSI: 0
[13782.142033] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[13782.142512] sr 2:0:0:0: Attached scsi CD-ROM sr0
[13782.143150] sr 2:0:0:0: Attached scsi generic sg1 type 5
// Last not least 2nd edit.
I cannot see it anywhere in the New Skin, nor through file manager. Cannot add is as a source either :S
New LibreELEC.tv Krypton build #0627: Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Mon Jun 27 22:06:15 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160627220448-#0627-gdf3c36b [Build #0627]
Based on tip of LibreELEC.tv master (df3c36b5, changelog) and tip of XBMC master (1f9e2a2c, changelog) with the following modifications: Build Highlights:
  1. PR:10036: [PVR] Guide window: Fix timer icon issues (trac #16621)
Build Details:
  1. LibreELEC.tv:
    • kodi-binary-addons: Update unofficial addons (PR:492, 3 commits, 8 files changed)
    • squeezelite: remove ir (PR:495, 2 commits, 3 files changed)
    • kodi-binary-addons: Fix update_binary-addons (PR:496, 2 commits, 4 files changed)
  2. XBMC:
    • ZeroconfMDNS.cpp: add header to fix compile with gcc 4.9 & uClibc (PR:10035, 1 commit, 1 file changed)
  3. pvr.hts:
    • Fix setting channel type & setting epg uid (PR:232, 3 commits, 3 files changed)
  4. pvr.stalker:
    • [debian] disable LTO (PR:66, 1 commit, 1 file changed)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:10036: [PVR] Guide window: Fix timer icon issues (trac #16621)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Hi, would it be possible to have a choice of the 4.7 kernel again for the latest build(s)? It seemed to be much less prone to blank screens/wrong resolution output on my haswell nuc.
Thanks Smile
Blank screen when ? At boot ?
(2016-06-28, 00:45)csutcliff Wrote: Hi, would it be possible to have a choice of the 4.7 kernel again for the latest build(s)? It seemed to be much less prone to blank screens/wrong resolution output on my haswell nuc.
Thanks Smile
No. 4.7 will come in it's own time, the previous builds were one-off "toes in the water".
What about 4.6.3?
(2016-06-28, 02:12)EricSol Wrote: What about 4.6.3?
Tomorrow.
Be sure and let us know when "PR:9731: [WIP] 3dlut and simple ICC linking support for color correction" returns. Also waiting for passthru to work correctly again. That said, thanks for your work on this.
What's Happened To The Changelog Display ?
I've been keeping up with the bleeding edge of Krypton development pretty religiously (including #0625), and last night discovered I cannot display the Changelog text of ANY addon. How curious Huh.
So I went back through time - restoring previous builds - until the text was successfully displayed... and found myself back at #0611. This is the debug log from #0611 where I am able to see the Changelog info displayed for the CBC video addon.
By way of contrast, here is the debug log of the same operations (ie: attempt to see CBC Changelog info) running the latest #0626 build. No luck... Nuthin' to See Here Sad.
BTW, any/every build I tried > #0611 gave the same result - no Changelog text displayed.
Am I the only one to experience this loss of functionality ?
...and YES - I'm using the Krypton version of Xonfluence skin. I attempted to get results with Estuary, but could not even find a way to trigger a Changelog text display.
There are those who love Estuary... and I'm with the other group Wink.
::  LibreELEC 9.2.6 RELEASE - Generic x86_64  ::  Intel 847 NUC  ::  KVR1333D3S9/4G  ::  Kingston SMS200S3/30G mSATA  ::  MS 1044 MCE keyboard  ::  GP-IR02BK remote  ::  Xonfluence  ::  10.9TiB on FreeNAS v11.3-U5 (RAID-Z2)  ::
(2016-06-28, 07:45)gjwAudio Wrote: So I went back through time - restoring previous builds - until the text was successfully displayed... and found myself back at #0611. This is the debug log from #0611 where I am able to see the Changelog info displayed for the CBC video addon.
Thanks for identifying the last working build. The change in behaviour is due to the following change in #0612:
(2016-06-13, 00:24)Milhouse Wrote:
  • Build Details:
    1. [addons] move changelog to addon.xml (PR:9351, 1 commit, 9 files changed)
Krypton compatible add-ons should now be using the <news> tag in addon.xml for changelog details. The changelog.txt file is no longer supported in Krypton (after PR9351).
As this change is not backwards compatible add-ons that do not support the <news> tag will not be able to display any changelog details in the latest Krypton builds. Very few addons have updated to support the new tag, and it may take some time before they do.
New LibreELEC.tv Krypton build #0628: Generic
# uname -a
Linux LibreELEC 4.6.3 #1 SMP Tue Jun 28 21:06:43 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160628210522-#0628-gc008283 [Build #0628]
Based on tip of LibreELEC.tv master (c0082832, changelog) and tip of XBMC master (c6f500ac, changelog) with the following modifications: Build Highlights:
  1. New 4.6.3 kernel
Build Details:
  1. LibreELEC.tv:
    • kodi-binary-addons: update to latest versions (PR:497, 1 commit, 4 files changed)
    • linux: Update to 4.6.3 + RPi firmware (PR:499, 4 commits, 32 files changed)
    • build: evaluate DEVTOOLS after $HOME options (PR:494, 1 commit, 1 file changed)
  2. XBMC:
    • [PVR] Guide window: Fix timer icon issues. Fixes #16621 (PR:10036, 3 commits, 6 files changed)
    • Revert "[addons] Preserve strings which are not string ids in enum lv… (PR:10040, 1 commit, 1 file changed)
New kernel works fine for me Smile
AppleTV 4K, LG 65E6 OLED TV, Marantz NR1606, Harmony Elite
  • 66
  • 67
  • 68(current)
  • 69
  • 70
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
