2016-06-29, 02:27
2016-06-29, 06:09
(2016-06-29, 05:11)vbat99 Wrote: What about remote repeat? That working in this new kernel?
We are very close to nailing it down, maybe there will be a fix in the next build.
2016-06-29, 13:33
(2016-06-29, 03:27)EricSol Wrote: So far so good on new kernel
http://sprunge.us/cXeO
Thank you!! seems that
Hdmi Plugged out error
is fixed ....
2016-06-29, 18:32
(2016-06-29, 02:27)Roby77 Wrote:http://sprunge.us/eBAY(2016-06-29, 00:15)_Spook_ Wrote: New kernel works fine for me
Could you pleaae post your log ?
# journalctl -a | pastebinit
Total sidenote...how random is that the code got to be ebay...hehe
2016-06-29, 21:27
hey there guys, first of all ty so much milhouse!!
ive tested the 28.6 version, but still SPDIF with hifiberry is acting weird, on amazon prime app it does switchs my receiver to dolby or dts,but on apps like Radio, or xStream it doesnt switch to dolby at all.
and a Question about the TV, possible to add iptv simple client to the skin?
Cheers and Thanks alot !!!
2016-06-29, 21:49
Hi guys,
Have a weird one here, I have two Identical cherry trail machines, both have fresh installs of Libreelec with the same Milhouse 628 build, one consistently errors when trying to load the WMC PVR add-on and the other does not?? the add on will work but after a reboot it fails to load, I have wiped the system several times and installed builds from 610 and up, all of them do this, the only difference between the systems is one is using HDMI audio out and the other is using USB BOSE audio.
At first I thought it might have been the Test build of the Amber Skin, but even a fresh install with no add ons still results in the PVR add-on failing to load after a reboot.
I have log files from both units here, if you need me to post other logs just let me know what you need, also the 5.1 sound channels are still mixed up with Kernel 4.6.3.
https://1drv.ms/u/s!AmWyHDdgPG0ngZJw2oAuHuihF_kZMg
https://1drv.ms/u/s!AmWyHDdgPG0ngZJxOJE-P2ppJv04_w
Cheers
KFK
Cheers
KFK
2016-06-29, 22:26
(2016-06-29, 21:27)Cyr0wned Wrote: ive tested the 28.6 version, but still SPDIF with hifiberry is acting weird, on amazon prime app it does switchs my receiver to dolby or dts,but on apps like Radio, or xStream it doesnt switch to dolby at all.
Did you mean to post this in the Raspberry Pi testing thread?
(2016-06-29, 21:27)Cyr0wned Wrote: and a Question about the TV, possible to add iptv simple client to the skin?
I'm not entirely sure what you are asking for, as the PVR IPTV Simple Client add-on is already included in these builds.
If you're asking for a skin feature, then Estuary feature requests should be posted here: http://forum.kodi.tv/showthread.php?tid=262603
2016-06-29, 22:35
oops sry was read so much posts of this build, sry failed for hifiberry q :>
but ty alot
but ty alot
2016-06-29, 22:45
(2016-06-29, 21:49)Kung-Foo-Kamel Wrote: Hi guys,
Cheers
KFK
1) Test with Estuary. As per the "Skin Usage" section in the first post, please don't report problems unless you can reproduce them with the stock Estuary skin.
Your Amber skin doesn't appear to be compatible with latest Krypton, or the installation is corrupt - there are a ton of skin-related issues being reported in the "System One" log:
16:56:57 351.204620 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogConfirm.xml, Line 0
Failed to open file
16:56:57 351.503998 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogNotification.xml, Line 0
Failed to open file
16:57:39 393.494446 T:140334486448192 WARNING: CSkinInfo: failed to load skin settings
etc.
2) Check your network configuration - maybe the Amber skin problems are preventing you from seeing notification of errors and warnings or dialogs requesting network information, but there doesn't appear to be a working network available to System One:
16:51:05 12.130283 T:140333753034496 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
16:51:06 13.148792 T:140333081945856 ERROR: Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
File "/usr/lib/python2.7/threading.py", line 754, in run
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 268, in run_discovery_loop
self.discover()
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 178, in discover
sent = sock.sendto(self.discover_message, self.discover_group)
error: [Errno 101] Network is unreachable
16:51:06 13.150862 T:140333073553152 ERROR: Exception in thread Thread-2:
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 89, in client_update
update_sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, socket.inet_aton(self._multicast_address) + socket.inet_aton('0.0.0.0'))
File "/usr/lib/python2.7/socket.py", line 228, in meth
error: [Errno 19] No such device
3) I can't tell if you're using Amber or not with System Two, as it's not a debug log (neither is System One, but the errors give up more information).
2016-06-29, 22:49
New LibreELEC.tv Krypton build #0629: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (c0082832, changelog) and tip of XBMC master (c6f500ac, changelog) with the following modifications:
# uname -a
Linux LibreELEC 4.6.3 #1 SMP Wed Jun 29 21:05:43 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160629210400-#0629-gc008283 [Build #0629]
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (d9e75d56, ahead +31)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (b171dffe), inputstream.rtmp (8cebd150), inputstream.smoothstream (a38d40a2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (5f9872ca), pvr.dvbviewer (35902f5d), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (343ca980), pvr.iptvsimple (1ea1f36e), pvr.mediaportal.tvserver (369b0189), pvr.mythtv (9141c6fc), pvr.nextpvr (7ed3111c), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (ad1f7d67), pvr.vbox (b24c3cac), pvr.vdr.vnsi (5d5bb64e), pvr.vuplus (c988f849), pvr.wmc (ef4cf3b1)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Includes commits from xbmc/AudioDSP/V2/usability_core_fixes, ahead +33 (AchimTuran)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Enable other binary addons
- Include [env] patch: Fix autorepeat in 4.6+ kernel
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Enable pvr and adsp addons, disable pvr/adsp updates
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: ffmpeg: update to ffmpeg 3.1, minimal Kodi specific commits
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] PR:477: ffmpeg: rework
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:9976: VideoPlayer: expose stream player info to GUI
- Revert kernel commit that is causing auto-repeat issues - please test & confirm (many thanks @lrusak & @mattdevo for the bisecting work!)
- Update with latest ffmpeg/3.1-xbmc commits
- xbmc/AudioDSP/V2/usability_core_fixes (AchimTuran):
- New commits in this build:
2016-06-29, 23:10
(2016-06-29, 23:08)Roby77 Wrote: Sorry @Milhouse but ir doesn't work
http://sprunge.us/bHWZ
IR doesn't work at all, or just auto-repeat (ie. same as before?)
