scf2k
Senior Member
Nice! Though the downside now you have described is about monitor users. Wouldn't an additional step in setup wizard (where you set hostname and something else I can't remember now) make things a little better where user could select their display device: monitor or TV. And this settings would set limited off/on according to selected option.
So the limited range setting will tell Kodi and the Intel driver how to behave? Great work!
fritsch
Team-Kodi Developer
No matter. With the mode we set, colors are completely untouched while only using kodi's code to scale the values.
In short: if you have a full range monitor attached, that ignores the limited infoframe, just disable "Use Limited Range" from kodi - that's all.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
2016-08-11, 16:31
(This post was last modified: 2016-08-12, 10:24 by cabal2k.)
Deleted ...
I'll open a thread after some further investigations.
Milhouse
Retired Team-Kodi Member
Remember to remove all previous Intel limited range-related hacks after installing #0811.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
n2vwz
Junior Member
Thanks Fritsch & Milhouse.
Intel Driver support is appreciated.
