  • 105
  • 106
  • 107(current)
  • 108
  • 109
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-08-19, 23:19)porkchop999 Wrote: I think this is being fixed
https://github.com/xbmc/xbmc/pull/10310
PR10310 is in tonight's build (#0819) which I've just tested, however the reported speed doesn't change with tempo (I'm assuming it should).
I have the following keyboard.xml:
<keymap>
  <global>
    <keyboard>
      <f mod="ctrl">xbmc.playercontrol(tempoup)</f>
      <r mod="ctrl">xbmc.playercontrol(tempodown)</r>
      <o mod="ctrl">PlayerDebug</o>
    </keyboard>
  </global>
</keymap>
and I have "Sync playback to display" enabled (otherwise tempo doesn't work at all - presumably not supported), and pressing ctrl-f/ctrl-r has an obvious effect on playback however the speed shown in PlayerDebug is always "speed: 100.100%" and never changes.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
New LibreELEC.tv Krypton build #0819: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.0 #1 SMP Fri Aug 19 21:07:34 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160819210537-#0819-gf112a3c [Build #0819]
Based on tip of LibreELEC.tv master (f112a3c7, changelog) and tip of XBMC master (08820dc8, changelog) with the following modifications: Build Highlights:
  1. PVR and VideoPlayer fixes
  2. BayTrail/CherryTrail HDMI audio support
Build Details:
  1. LibreELEC.tv:
    • packages/linux-drivers/brcmap6xxx-aml: disable power saving by default (PR:636, 1 commit, 1 file changed)
    • vdr: updates and 4k/hevc support (1b919e69)
  2. XBMC:
    • [PVR] All PVR windows: Prevent updates until window is fully initialized. Fixes trac#16848. (PR:10307, 1 commit, 6 files changed)
    • [PVR] Recordings window context menu fixes (PR:10308, 4 commits, 5 files changed)
    • VideoPlayer: some small fixes (PR:10310, 4 commits, 7 files changed)
    • [lang] remove spaces (PR:10312, 1 commit, 1 file changed)
    • remove longpress from left/right keys (PR:10311, 1 commit, 1 file changed)
  3. xbmc/master (FernetMenta):
    • Commits no longer in build:
      • VideoPlayer: fixes for rewind (608b20f5)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:635: Intel: add patch for kernel 4.7 HDMI sound
Hello all,
Hello Milhouse & FernetMenta
I have two issues with Libreelec since Jarvis version. I have tested all alpha, all build and OE 6.95.x.
Here is my copnfig :
Motherboard Asus P8h67-i
Intel i3 2120 Sandy bridge with HD graphics 2000
4Go Ram
First Issue :
Currently I'm using LE 7.0.2 and I have stutter when I play a video.
BUT, I don't have this problem with kodibuntu 16.1 or OE 6.0.3. So, I think is an issue with LE or OE Jarvis
I have tested a lot of option like Adjust refresh rate, .... But, I have always the stutter on all video.
This is my paste log with debug activate.
Second Issue :
When I want to open Audio DSP my computer crash. It's impossible to use this add-on for me. I contact Wisler (AudioDSP developper) and he said thaht the version of audioDSP is too old.
It is possible to add more recent version on audio DSP in the next build ?
I post a debug log for the 2 problem
http://pastebin.com/fmEXnVWV
Thanks you for your help
(2016-08-20, 00:11)polarrys Wrote: Second Issue :
I've no current plans to include ADSP in these builds.
Still seeing an issue with the recent builds and I think it started around #813/#814. When playing back PVR recordings I try to skip ahead and KODI basically crashes. All other media is find like TV/Movies shows but PVR TV isn't normal. I am using pvr.mythtv as well FYI:
http://sprunge.us/fPiU
HTPC(s): All running LibreELEC
  • AMD 2200G APU on Gigabyte AB350N-Gaming WIFI-CF
  • RPI3 x2 | RPI2 x2
NAS: FreeNAS (Latest Stable) | NFS/CIFS
(2016-08-20, 01:20)pyrodex Wrote: Still seeing an issue with the recent builds and I think it started around #813/#814. When playing back PVR recordings I try to skip ahead and KODI basically crashes. All other media is find like TV/Movies shows but PVR TV isn't normal. I am using pvr.mythtv as well FYI:
Is Kodi actually crashing? If so you'll have a crashlog (see note #4 in first post).
Knowing the exact build when this problem started could also help.
It doesn't crash but I see a spinning circle for a long time. I can try again later tonight and see if it will crash.
Also it started with #813 I believe but I'll try #812 to confirm.
  • RPI3 x2 | RPI2 x2
I have a question about Milhouse Build vs LibreElec 7
I have a NUC braswell NUC5CPYH in a fanless case
LibreElec 7 at idle is barely above ambient room temp and barely warm after I watch a 2 hour movie
Milhouse Build is very warm at idle, approaching hot.
Are there still kernel problems with braswell with new kernels?
No - there are no kernel issues anymore.
Most likely an addon running with a huge cpu load. Verify with top.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Thanks Milhouse for your help. I will wait Smile
What about the first issue about video stutter on HD Graphics 2000. Can you please help me with this problem. It's so difficult to Watch video with this stutter.
Thanks .
(2016-08-20, 07:29)fritsch Wrote: No - there are no kernel issues anymore.
Have you noticed how badly behaved the Intel pstate powersave governor is with kernel 4.6 and 4.7 on Braswell? It doesn't clock my N3150 up to maximum turbo with software decoding and causes skipping in Kodi and MPV. Kernel 4.4 is OK.
My workaround is to modify the airmont_params in intel_pstate.c like this:
setpoint =35 (was 60)
deadband = 15 (was 0)
I think that gives an up threshold of 50 and a down threshold of 20.
With those settings it does clock up to max turbo with software decoding, and down to minimum with hardware decoding, using Kodi 17 alpha2.
It's a pity you can't set these via sysfs.
Beware: turbostat from kernel 4.7 reports my Braswell at 3.3GHz! If only that were possible... You need an earlier version to get plausible numbers.
I hope you filed a bugreport at bugs.freedesktop.org - otherwise it won't be solved. Why are you using alpha2, btw.?
Edit: Cannot reproduce, btw.
Kodi playing h265-10 bit on my Braswell N3150 system:
Quote:fritsch@minix:~$ cat /proc/cpuinfo |grep -i mhz
cpu MHz : 2079.980
cpu MHz : 2079.980
cpu MHz : 2079.980
cpu MHz : 2079.980
Edit: Fixed the screenshot with: https://github.com/xbmc/xbmc/pull/10316
Sorry, I don't understand how you can play video with that specification on Braswell. I would have thought it's limit for software decoding would be about 1080i50 + yadif 2x
(2016-08-20, 14:50)LateAdopter Wrote: Sorry, I don't understand how you can play video with that specification on Braswell. I would have thought it's limit for software decoding would be about 1080i50 + yadif 2x
I don't get what you want to say, sorry.
A Braswell plays 3840x2160 @60p h264 without issues, while outputting it to a HDMI 1.4b target. It also can play 3840x2160@60p HEVC 8 bit without issues. The test above was meant to show, that all cores go up to their maximum when using SW decoding - nothing else. It's obviously clear that a braswell cannot play hevc-10 bit 4k file without skipping and stuttering, but this was not tested here.
Btw. using yadif 2x won't work well on a BSW too cause of the immense cpu copying overhead. VAAPI provides VAAPI-MCDI which has similar quality while not using any additional CPU.
Edit: The yadif in the above screenshot is a bug - it's not used at all, cause that video is not interlaced.
(2016-08-20, 07:29)fritsch Wrote: Most likely an addon running with a huge cpu load. Verify with top.
Kodi at rest
top - 08:59:24 up 14:38,  1 user,  load average: 0.35, 0.48, 0.49
Tasks: 141 total,   1 running, 140 sleeping,   0 stopped,   0 zombie
%Cpu(s): 11.1 us,  1.9 sy,  0.6 ni, 78.7 id,  7.7 wa,  0.0 hi,  0.0 si,  0.0 st
KiB Mem :  3950360 total,  2800268 free,   385600 used,   764492 buff/cache
KiB Swap:        0 total,        0 free,        0 used.  3145380 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
  762 root      20   0 2779024 362964  59520 S  52.3  9.2 147:30.43 kodi.bin
  624 root      20   0  101192  16772  10188 S   2.3  0.4   4:16.36 Xorg
5535 root      20   0       0      0      0 S   0.3  0.0   0:00.82 kworker/0:2
5538 root      20   0    9180   1796   1456 R   0.3  0.0   0:09.37 top
5539 root      20   0       0      0      0 S   0.3  0.0   0:00.77 kworker/1:1
    1 root      20   0   11196   4340   3040 S   0.0  0.1   0:01.93 systemd
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.02 kthreadd
    3 root      20   0       0      0      0 S   0.0  0.0   0:01.16 ksoftirqd/0
    5 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/0:0H
    7 root      20   0       0      0      0 S   0.0  0.0   0:12.12 rcu_sched
    8 root      20   0       0      0      0 S   0.0  0.0   0:00.00 rcu_bh
    9 root      rt   0       0      0      0 S   0.0  0.0   0:01.80 migration/0
   10 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 lru-add-drain
   11 root      rt   0       0      0      0 S   0.0  0.0   0:00.24 watchdog/0
   12 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/0
   13 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/1
   14 root      rt   0       0      0      0 S   0.0  0.0   0:00.24 watchdog/1
   15 root      rt   0       0      0      0 S   0.0  0.0   0:01.55 migration/1
   16 root      20   0       0      0      0 S   0.0  0.0   0:01.18 ksoftirqd/1
   18 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/1:0H
   19 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/2
   20 root      rt   0       0      0      0 S   0.0  0.0   0:00.24 watchdog/2
   21 root      rt   0       0      0      0 S   0.0  0.0   0:01.41 migration/2
   22 root      20   0       0      0      0 S   0.0  0.0   0:01.51 ksoftirqd/2
   24 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/2:0H
   25 root      20   0       0      0      0 S   0.0  0.0   0:00.00 cpuhp/3
   26 root      rt   0       0      0      0 S   0.0  0.0   0:00.25 watchdog/3
   27 root      rt   0       0      0      0 S   0.0  0.0   0:01.22 migration/3
   28 root      20   0       0      0      0 S   0.0  0.0   0:01.27 ksoftirqd/3
   30 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/3:0H
   31 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kdevtmpfs
   32 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 netns
   33 root      20   0       0      0      0 S   0.0  0.0   0:00.05 khungtaskd
   34 root      20   0       0      0      0 S   0.0  0.0   0:00.00 oom_reaper
   35 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 writeback
   36 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kcompactd0
   37 root      39  19       0      0      0 S   0.0  0.0   0:00.00 khugepaged
   38 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 crypto
   39 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   40 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kblockd
   42 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 ata_sff
   44 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 rpciod
   46 root      20   0       0      0      0 S   0.0  0.0   0:00.00 kswapd0
   47 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 vmstat
   48 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 nfsiod
   49 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 cifsiod
   65 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 acpi_thermal_pm
   67 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   68 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   69 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   70 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   71 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   72 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   73 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   74 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   75 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   76 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   77 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   78 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   79 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   80 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   81 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   82 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   83 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
   84 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 bioset
3 plug-ins
MythTV
Amazon Prime Instant Video
HDHomeRun
I know that MythTV has background stuff. Do they all show up as kodi.bin?
  • 105
  • 106
  • 107(current)
  • 108
  • 109
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
