  • 109
  • 110
  • 111(current)
  • 112
  • 113
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-08-23, 22:47)dellas60 Wrote: thank you my freind for your reply,yes i configuured it before enabling them,and this is my log:
https://gist.github.com/anonymous/3b9147...307aad79ea
thanks
You've just sent me 11 random logs which I'm not going to bother looking at. Why do people do this (I ask, because I really want them to stop!)
Send ONE log. The best way:
1. Enable debug logging
2. Reboot
3. Reproduce the problem
4. Using ssh connect to LibreELEC, execute "cat /storage/.kodi/temp/kodi.log | pastebinit"
and paste the resulting url.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
New LibreELEC.tv Krypton build #0823: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.2 #1 SMP Wed Aug 24 00:56:43 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160824005445-#0823-g4b4d04e [Build #0823]
Based on tip of LibreELEC.tv master (4b4d04eb, changelog) and tip of XBMC master (903d13fb, changelog) with the following modifications: Build Highlights:
  1. New 4.7.2 kernel
Build Details:
  1. LibreELEC.tv:
    • linux: add support for MN88473 DVB devices (PR:648, 1 commit, 3 files changed)
  2. XBMC:
    • [PVR] Fix epg tag <-> recording association (PR:10327, 1 commit, 4 files changed)
    • [ios] - fixed xcode project after adding platform classes (PR:10328, 1 commit, 1 file changed)
    • Fix osd not showing while watching tv (PR:10326, 1 commit, 1 file changed)
    • VideoPlayer: move supported deinterlacing methods into ProcessInfo (PR:10323, 2 commits, 10 files changed)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:653: linux: update to linux-4.7.2
    • Added: [pkg] PR:10325: [estuary] - show buffering progress in video full screen
Kodi is crashing for me, whenever I press the the Record button to start an instant recording in Live TV.
Using #0822, LibreELEC (community) Version: devel-20160822222244-#0822-gc5864e5
Sorry, I have no idea, when that started to happen... use that feature only occasionally.
SEGFAULT in
#0 0x00007f0a27324400 in _IO_vfprintf_internal (s=s@entry=0x7f09f1c87900, forma
#1 0x00007f0a2734a519 in _IO_vsnprintf (string=0x7f09ea829dd0 "Die n\303\244chs
#2 0x00000000008207aa in StringUtils::FormatV(char const*, __va_list_tag*) ()
#3 0x00000000008208d2 in StringUtils::Format(char const*, ...) ()
#4 0x0000000000b5d432 in ?? ()
#5 0x0000000000b604b2 in PVR::CPVRManager::SetRecordingOnChannel(std:Confusedhared_pt
#6 0x0000000000b609ff in PVR::CPVRSetRecordingOnChannelJob:Big GrinoWork() ()
#7 0x0000000000cf7ef3 in CJobWorker:Tonguerocess() ()
#8 0x0000000000e53ae5 in CThread::Action() ()
#9 0x0000000000e54241 in CThread:ConfusedtaticThread(void*) ()
#10 0x00007f0a2af57424 in start_thread (arg=0x7f09f1c88700) at pthread_create.c:
#11 0x00007f0a273c2e0d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:
Log http://sprunge.us/cDFg
Crashlog http://sprunge.us/jIYM
Thanks for all your work!
Cheers,
Diddle
@Milhouse
While using #0823, selection of deinterlacing-method in VideoOSD video settings is suddenly gone. Using common Intel Haswell NUC with VAAPI HW acceleration enabled. Until now i had the optional "VAAPI - Motion compensated" selected for use with a very small amount of interlacted content i use (Some LiveTV channels + DVD).
Should be related to:
https://github.com/xbmc/xbmc/pull/10323
and
https://github.com/xbmc/xbmc/pull/10316
I'd file a more extensive bug report, but can't because of this weeks work.
If you have the time and can confirm yourself, maybe you can pass on the info.
If not, i'll check back at the issue as soon as i have the time again.
Whatever it is, thanks!
⬅️⬅️ Feel free to leave a 👍 on useful posts  |  A Confluence ZEITGEIST (A modern reimagination of Confluence)  |  axbmcuser REPO (Download Link)  |  Kodi 17.7 DSPlayer x64 BETTERGUI (2020 build)
Do i still need to add the xrandr comand in autostart.sh for the Intel passthrough 16-235 broadcast?
If so can someone point me to the code, can't find it anymore
@meowmoo afaik - no!
thanks
2. Reboot
i am very sorry for this mistake:
http://sprunge.us/QBcK
(2016-08-24, 18:32)dellas60 Wrote: i am very sorry for this mistake:
17:24:12  18.094320 T:140018601416448   DEBUG: CurlFile::Open(0x7f5894029c50) http://192.168.8.101:8089/api/version.html
17:24:12  18.094486 T:140018601416448    INFO: easy_aquire - Created session to http://192.168.8.101
17:24:12  18.095186 T:140018601416448   ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
17:24:12  18.095221 T:140018601416448   ERROR: CCurlFile::Open failed with code 0 for http://192.168.8.101:8089/api/version.html
17:24:12  18.095264 T:140018601416448   ERROR: AddOnLog: DVBViewer Client: Unable to connect to the backend service. Error: Error document empty.
17:24:12  18.096729 T:140018601416448   ERROR: ADDON: Dll DVBViewer Client - Client returned bad status (1) from Create and is not usable
Check that the client has a working network when Kodi is started. If the network is not available then try enabling "Wait for network before starting Kodi" in the LibreELEC Settings add-on.
Check that your backend is working as expected, and is running (ie. check whatever should be listening on http://192.168.8.101:8089).
Other than that, it looks like an add-on or backend issue which you should probably report to the add-on maintainer.
(2016-08-22, 10:05)fritsch Wrote:
(2016-08-22, 07:49)sh33p Wrote: anyone else struggling to output more than 2 audio channels on hd codecs?
since i moved to LE7 and later from the EGL build of kodi 15.2 i can't output more than 2 channels, although in the debug log i don't see any clear reason
http://sprunge.us/LhjZ
anyone familiar with that?
the hardware is celeron 2955 asus cbox
All fine in the Debug Log. It opens the correct number of channels and so on. From the handshake it seems that you use ARC functionality. Basically if you downgrade to 15.2 it should also not work :-)
feeling a bit stupid... i found that the sound field on the sony avr was set to 2ch on that hdmi input, discovered it when i moved the cbox to other hdmi input and everything was ok
New LibreELEC.tv Krypton build #0824: Generic
# uname -a
Linux NUC 4.7.2 #1 SMP Wed Aug 24 23:09:44 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160824230749-#0824-g4b4d04e [Build #0824]
Based on tip of LibreELEC.tv master (4b4d04eb, changelog) and tip of XBMC master (1f94b1cc, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (fac3a954, ahead +34)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (7898a672), inputstream.rtmp (9c05b8dd), inputstream.smoothstream (b63ecbb4), peripheral.joystick (2a69ba41, +24), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (1042a71c), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (bb9c0b10, +10), pvr.vbox (2750c92a), pvr.vdr.vnsi (40c45dc9), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Includes commits from xbmc/master, ahead +5 (FernetMenta)
  • Exclude [env] libcec-PR208.patch: Merged upstream
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
  • Include [env] PR:621: init: mount per-client boot/disk if available & configured
  • Include [env] PR:641: kodi: update to 17.0-beta1-81d5d26
  • Include [env] PR:653: linux: update to linux-4.7.2
  • Include [env] PR:655: xf86-video-nvidia: update to 367.44
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
  • Include [pkg] PR:10325: [estuary] - show buffering progress in video full screen
  • Include [pkg] PR:10335: skin migration and addon compatibility checking
Build Highlights:
  1. PVR fixes
  2. PR:10335: skin migration and addon compatibility checking (disabling of Kodi game addon repo is to be expected)
  3. xf86-video-nvidia: update to 367.44 - support for TITAN X (Pascal), GeForce GTX 1060 6GB and GeForce GTX 1060 3GB
Build Details:
  1. XBMC:
    • [PVR] Channels window: Fix not disappearing 'record' icon after stopp… (PR:10331, 1 commit, 1 file changed)
    • [PVR] Recordings window: Fix addional 'resume'/'play' context menu po… (PR:10330, 1 commit, 1 file changed)
    • [win32] Remove XBMC to Kodi data migration from NSIS installer (PR:10329, 1 commit, 1 file changed)
    • [estuary] revert addition of repository widget on home screen (PR:10336, 1 commit, 1 file changed)
  2. pvr.stalker:
    • regression fixes and more refactoring (PR:72, 10 commits, 34 files changed)
    • Added: [env] PR:655: xf86-video-nvidia: update to 367.44
    • Added: [pkg] PR:10335: skin migration and addon compatibility checking
Is there any way to force HW decoding?
I get high CPU usage when watching 1080p and discovered that system is using SW decoding no matter what setting are in player.
Same settings always used in previous versions(Helix, Jarvis), on same system, and it showed same CPU usage whether 1080 or not.
THANKS FOR ALL YOUR HARD WORK!
Post your Debug Log ... We have no crystal ball
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
The boot sequence is not completing when I try the testbuilds on my AspireRevo 1600 hardware. Is the Nvidia ION platform no longer supported?
http://imgur.com/yD31Z1A
http://imgur.com/5HgyEQI
(2016-08-25, 17:14)kelsdogz Wrote: Is there any way to force HW decoding?
LOG
http://sprunge.us/aTYH
(2016-08-25, 18:39)richardk Wrote: The boot sequence is not completing when I try the testbuilds on my AspireRevo 1600 hardware. Is the Nvidia ION platform no longer supported?
I found and solved the problem.
I had LibreELEC 7 installed on the hard disk on this system. Even though I was booting from the SD card, the bootloader was recognizing a LibreELEC partition on the hard disk, and trying to use it.
I disabled the SATA controller in the system BIOS, and now it boots LibreELEC 8,0 with no errors.
  • 109
  • 110
  • 111(current)
  • 112
  • 113
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
