2016-09-19, 10:18
See the openelec wiki for fixating the EDID information.
(2016-09-19, 07:50)jacko5 Wrote: @Milhouse,
The last 3 update builds do not boot on my Samsung chromebox,
What has changed from 3 builds ago ?
The last build that works for me is from 0909.
Thank you.
Quote: Build Details:
LibreELEC.tv:
kodi: update to 17.0-beta2-6e9d6fb (PR:746, 8 commits, 19 files changed)
XBMC:
LibreELEC.tv:
XBMC:
(2016-09-19, 13:36)Roby77 Wrote:Quote: Build Details:
LibreELEC.tv:
XBMC:
Why beta 2 for 918 ? Build 917 reports beta 3
(2016-09-18, 23:57)Milhouse Wrote:(2016-09-18, 23:42)madmarkym Wrote: @Milhouse I am not sure if you can help me with this or I if I need to revert to openmediaelec which I used successfully previously.
I am trying to configure my gyration remote with Lirc using this guide
http://kodi.wiki/view/How-to:Gyration_US...using_Lirc
The problem I am having is there is no etc/rc.local file or /etc/lirc/lircd.conf and that folder is locked.
Instead of ~usernamerunningxbmc/.xbmc/userdata/Keymap.xml I am using /storage/.kodi/userdate/keymaps/gem.xml (this was generate by the keymap, so I thought it best to use this file.
And instead of this file ~usernamerunningxbmc/.xbmc/userdata/Lircmap.xml, I create /storage/.kodi/userdate/keymaps/Lircmap.xml.
Do you have any ideas how I can resolve this?
Thanks again for your time.
Sorry, not a lirc expert by any stretch of the imagination. Presumably this is a "general" LibreELEC issue (same problem in 7.0.2?) in which case please ask on the LibreELEC forum for support. I need to restrict this thread to issues directly related to these builds, rather than try to solve every problem - hope you understand.
What I can say is that the equivalent of the /etc/rc.local file in LibreELEC is your /storage/.config/autostart.sh file. Not sure about /etc/lirc/lircd.conf, but someone on the LibreELEC team will know.
(2016-09-19, 13:31)Milhouse Wrote:(2016-09-19, 07:50)jacko5 Wrote: @Milhouse,
Thank you.
#0909 is 9 builds ago - do all 9 builds since #0909 fail to boot? How does it fail to boot - any on-screen messages, how far does it get (is it Kodi that fails to start or the whole PC)? I have to ask as you're the only person reporting this issue, and "does not boot" is not a very precise description.
I know what changed in #0910 - there were some package updates and a change to init - but this hasn't been a problem for anyone else (about 200 daily installations of these Generic test builds) and shouldn't prevent the PC from booting, although it might cause Kodi to fail (possibly the mysql bump, what's in your kodi.log?)
dmesg | pastebinit
journalctl | pastebinit
cat /storage/.kodi/temp/kodi.log | pastebinit
# uname -a
Linux NUC 4.7.4 #1 SMP Mon Sep 19 21:32:36 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160919213120-#0919-gef0f30a [Build #0919]
(2016-09-19, 23:03)dellas60 Wrote: hi,
when iam on live tv (tvheadenend) and when i active vdpau i notice artifictes and jerky on some sd channel. please help me.
http://sprunge.us/DMCS
(2016-09-19, 23:21)Milhouse Wrote:(2016-09-19, 23:03)dellas60 Wrote: hi,
Try the latest build, your build is 2 weeks old.
Also, what version of tvheadend are you using? I provide current tvheadend42 builds here: http://milhouse.libreelec.tv/builds/addo...vheadend42
