  • 141
  • 142
  • 143(current)
  • 144
  • 145
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-09-23, 12:37)kenmex Wrote: @millhouse
Thank you for all your work, I respect what you do for all of us.I have two questions, if you can please let me know
Do these builds support MVC or AVC 3d? I know I can play .iso files and SBS or Top and bottom 3d, but I cannot seem to play 3d mvc mkv files.They just play in plain monoscopic.If not, do you have any plans to support this 3d format, or the only solution will be to install Windows?
Also, using Estuary skin, greek characters in the Music library do not appear correctly.The same Albums/songs/Artists appear correctly when viewing the File Mode of the music.I have tried changing fonts from the GUI, editing Font.xml using other full unicode fonts that I know support Greek characters, but with no luck.Do you have any idea what might be the cause of this?
Thank you very much.
No, there is unfortunately no MVC support (and I'm not sure what AVC 3D is). MVC support needs to be added to ffmpeg and to be honest given the decline in interest of 3D I don't see this happening now.
Regarding the Greek issue, that sounds odd - does this happen with Confluence?
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Thanks for the reply Millhouse, to be honest I have not tried with Confluence, I am using Estuary mod. I reverted to Estuary and Estouchy to test, and this happens with those skins as well.Will try with Confluence tonight and let you know.Will also post a screenshot.
As for the MVC 3D, what is unclear to me is why the builds for Rpi3 support this format, while x86 do not.Do they use a different ffmpeg version?
The RPi supports a hardware based player, OMXPlayer, that supports MVC playback without needing ffmpeg.
@Milhouse,
Further to out last conversation.
I tried 22.09 tonight.
It loads in fine, then i get this message on screen,
Add-on migration in progress-please wait...
Left it to do its thing for 20 mins and it just still says the above,
So i thought i would go back to your 0909 as that was the last one i had full working.
Guess what .. i and still getting, Add-on migration in progress-please wait...
Not sure what to do now.
Regards Wayne.
(2016-09-23, 20:36)jacko5 Wrote: Not sure what to do now.
Regards Wayne.
See my last reply to you - there's nothing anyone can do without logs.
@jacko5: By the way, the database migration message probably doesn't mean it's migrating a database - you'll see that message every time now, whether there's a database to be migrated or not. What it does indicate in your case is that Kodi has crashed, hung or otherwise stopped responding while trying to connect to your databases.
Without knowing anything about your setup because of the lack of logs, I can't help you any further.
@Milhouse,
Thanks for your help.
I just reinstalled Libreelec from scratch via usb and then put your 0909 update on .. now all is Ok.
Weird how updates after 0909 crash.
I did have kernel ,, system missing onscreen sometimes after new update.
I think i will leave it at 0909 for now as this works great .. thanks for all your help ;-)
@jacko5 I guess that's easier than providing the logs that might have allowed you to upgrade in future.
Hi, first of all i would like to thank you for your hard work.
I ran into a problem with the moonlight addon from the LibreELEC repository. Whatever is do, i'm not able to get an audio output. So i checked the logs and dmesg and found a segfault error.
Here are all the infos that might be useful:
kodi.log: http://sprunge.us/ZVSZ
dmesg: http://sprunge.us/RGLe
moonlight service.log: http://sprunge.us/RFFA
Since others reported the same behaviour with moonlight + x86_64, it might be a platform specific error but actually i can only guess.
Thank you!
Given the bleeding edge nature of these builds not all add-ons will be compatible (add-ons may be built using shared libraries that are now updated/bumped to newer versions in these builds). Chances are, moonlight is one of these incompatible add-ons. I'll see if I can publish an updated build of moonlight for you later today, but it will be a one-off update as I don't have time to keep rebuilding every add-on available - this kind of breakage is the price for using bleeding edge builds.
Ok, thank you very much for your time.
New LibreELEC.tv Krypton build #0923: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.4 #1 SMP Sat Sep 24 03:20:33 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160924031915-#0923-g8a3b79d [Build #0923]
Based on tip of LibreELEC.tv master (8a3b79d2, changelog) and tip of XBMC master (12b1b128, changelog) with the following modifications: Build Highlights:
  1. PR:760: rework cmake build system and adjust build variables (clean build)
  2. PR:10544: [pvr] attempt to fix crashing and general failure in ChannelExists()
Build Details:
  1. LibreELEC.tv:
    • RBP: include missing libelftoolchain.so (PR:761, 1 commit, 1 file changed)
    • RBP: Bump firmware to version that includes libelftoolchain.so now th… (PR:764, 1 commit, 2 files changed)
  2. XBMC:
    • [osx] - no need for KODI_HOME env in xcode (PR:10531, 2 commits, 2 files changed)
    • [depends] openssl 1.0.2i (PR:10537, 1 commit, 1 file changed)
    • [ios] - added latest ios devices for proper screen scale (PR:10540, 1 commit, 1 file changed)
    • [Estuary][PVR] PVR Info dialog: Add 'Add timer' button. (PR:10536, 2 commits, 5 files changed)
    • OMXPlayer: Fix bug where audio timestamps fail to update (PR:10532, 1 commit, 1 file changed)
    • [osx] - add support for Xcode 8 (PR:10530, 5 commits, 7 files changed)
    • Lang: Refine Allow passthrough vs. enable passthrough (PR:10433, 1 commit, 1 file changed)
    • [cmake] Fix LIRC_DEVICE option (PR:10482, 1 commit, 4 files changed)
    • Mention-Bot: change kodi to Kodi (ff35090f)
    • Fix GetRolesNav passing of all options through from base path (#10485) (fcba1bb7)
  3. pvr.argustv:
    • fix api version and avoid unclean kodi exit (PR:60, 3 commits, 3 files changed)
  4. pvr.nextpvr:
    • Fix: GetBackendName() function returns only the Hostname. (PR:15, 1 commit, 1 file changed)
    • Fix: GetLiveStreamURL() - live stream url does not contain the sub-channel number. (PR:16, 1 commit, 1 file changed)
    • Sync enum representation of char_class_e in struct traits with defini… (PR:42, 1 commit, 1 file changed)
    • Fix Travis CI build on XCode 6.1 and bump version (PR:49, 2 commits, 3 files changed)
    • Fixed, crashing on bad server responses (PR:51, 2 commits, 3 files changed)
  5. pvr.vdr.vnsi:
    • fix addon settings prio and port (PR:90, 2 commits, 3 files changed)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Exclude [env] kodi-999.99-PR10345.patch: closed upstream, no longer required
    • Added: [env] patch: Quick fix for moonlight
    • Added: [env] PR:760: rework cmake build system and adjust build variables
    • Added: [env] PR:763: bcm2835: simplify
    • Added: [pkg] PR:10544: [pvr] attempt to fix crashing and general failure in ChannelExists()
(2016-09-24, 01:35)raynetec Wrote: Ok, thank you very much for your time.
Try installing this zip: http://milhouse.libreelec.tv/builds/addo...lhouse.zip (install #0923 first)
I'm failing the size check for the 1st time ever on build #0923.
Says I need a 512MB system partition, using an Asus ChromeBox was running Openelec on it before.
I got:
/sda1 230.4M 2201.M 6.3M 97% /flash
/sda2 14.3G 2.4G 11.6G 17% /storage
What are my options to fix this please!
Thanks Smile
(2016-09-24, 08:19)Magoo32 Wrote: What are my options to fix this please!
See note #5, first post.
  • 141
  • 142
  • 143(current)
  • 144
  • 145
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
