The TVDB scraper is currently broken due to upgrade works at TheTVDB site. We hope this issue will be resolved quickly.
  • 149
  • 150
  • 151(current)
  • 152
  • 153
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
So, my tests show:
On the NUC6i5SYK
#1005x sound 4.8 final no 4k patch
#1003x no sound 4.8 final 4k patch
#0926x no sound 4.8 rc8 4k patch
#0917l no sound 4.8 rc6 4k patch
The tests I did before with the #0917 builds was on NUC6i7KYK that has some other hardware components. I will test on that also.
EDIT:
On the NUC6i7KYK (Adjust display refreshrate: off, or else no video or sound)
#1003x sound 4.8 final 4k patch
#0926x sound 4.8 rc8 4k patch
#0917l sound 4.8 rc6 4k patch
So it behaves different on different hardware...
EDIT2:
Just wanted to add that my setup it 4k all the way. So the 4k patch should work on my setup.
AppleTV 4K, LG 65E6 OLED TV, Marantz NR1606, Harmony Elite
Thanks both. Odd results, @_Spook_. It's possible there's some extra SND_SOC options that could be enabled but it also risks breaking something else... I'll see if I can pin it down.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
I know, it's very strange. Let me know if you need something tested.
@Milhouse
I know the problem has already been discussed but I do not know the status. When I start kodi new I can by holding down the right or left button of my remote control rapidly up scrolling through my library. After I sent kodi once in the suspend mode and have reawakened works scroll only slowly when I hold the button down. Is this a known problem?
I have the version 0924 installed
(2016-10-05, 20:23)Eisi2005 Wrote: @Milhouse
I think you're the first person to report this. Please describe your hardware, although it's unlikely there's an easy fix unless #1005x works better for you as this has a brand spanking new kernel.
Alternatively, buy a cheap IR dongle (FLIRC etc.).
By the way, I'll be switching to the 4.8.0 kernel tonight.
New LibreELEC.tv Krypton build #1005: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.0 #1 SMP Thu Oct 6 03:14:07 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161006031247-#1005-ga946329 [Build #1005]
Based on tip of LibreELEC.tv master (a9463290, changelog) and tip of XBMC master (6618c8f5, changelog) with the following modifications:
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (048e7737, ahead +59)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (4a90d6a7, +6), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (e842db92), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Exclude [env] libcec-PR208.patch: merged upstream (libcec)
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: linux: Enable generic support for HID multitouch panels
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: linux: Enable support for additional Intel cypto hardware
  • Include [env] patch: libdrm: update to libdrm-2.4.71
  • Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:752: linux: extra options for Baytrail and 32-bit EFI
  • Include [env] PR:759: linux: update to linux-4.8.0 [WIP]
  • Include [env] PR:792: scripts/build: use MinSizeRel cmake build type
  • Include [env] PR:796: scripts/build: cleanup
  • Include [env] PR:800: xf86-video-intel: enable dri3 and make it default
  • Include [env] PR:803: kodi: update to update to 17.0-beta3-7041777
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] PR:30: enable samba at wizard (LibreELEC-settings)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
  • Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
  • Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
  • Include [pkg] PR:10594: [gui] smartplaylisteditor: convert spinners etc to regular buttons
  • Include [pkg] PR:10620: [jsonrpc] CAnnouncementManager: fix invalid type "movies" for video items without video info tag
Build Highlights:
  1. New 4.8.0 kernel
  2. Start of Kodi 17.0 beta4 cycle
Build Details:
  1. LibreELEC.tv:
    • projects/WeTek_Play_2: Update recovery image (PR:804, 1 commit, 1 file changed)
    • projects/*/options: disable lcdproc for all projects except Generic/Virtual (PR:793, 1 commit, 8 files changed)
    • xf86-video-ati: add xorg-radeon.conf to enable dri3 and glamor (PR:786, 1 commit, 2 files changed)
  2. XBMC:
    • bump to 17.0 beta 4 (PR:10599, 1 commit, 2 files changed)
    • VAAPI: restore accidentally lost call to sync of vaapi render picture (PR:10622, 1 commit, 2 files changed)
    • paplayer: fix gapless playback (PR:10623, 1 commit, 3 files changed)
    • [eventlog] implement high resolution datetime sort method (CDateTime granularity of 1 sec is not sufficient). (PR:10617, 2 commits, 6 files changed)
    • [python-api] - deprecate listitem.getduration(), .getfilename(), .getdescription() (PR:9697, 1 commit, 2 files changed)
    • [cmake/osx] Fix detecting SSE4.2 and AVX2 hardware support (PR:10624, 1 commit, 1 file changed)
    • [estuary] country flags - use RGB color space (PR:10626, 1 commit, 49 files changed)
  3. inputstream.mpd:
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: linux: Enable generic support for HID multitouch panels
    • Added: [env] patch: linux: Enable support for additional Intel cypto hardware
    • Added: [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
    • Added: [env] PR:759: linux: update to linux-4.8.0 [WIP]
    • Added: [env] PR:792: scripts/build: use MinSizeRel cmake build type
    • Added: [env] PR:796: scripts/build: cleanup
    • Added: [env] PR:803: kodi: update to update to 17.0-beta3-7041777
I just tested the latest build #1005 to see if an issue I'm experiencing with LibreELEC is being resolved (skipping frames on intel NUC).
for more info see here: https://forum.libreelec.tv/thread-1231.html
the system is constantly skipping frames, even with this latest build... it's subtle when watching movies (maybe one or two frames skipped every 10 seconds or so) but I'm noticing it. the command "kodi-send --action=PlayerDebug" confirms my observations.
regards,
michael
Have you opened a ticket at trac.kodi.tv? It would be helpful as it would get more attention there.
(2016-10-06, 11:59)Boulder Wrote: Have you opened a ticket at trac.kodi.tv? It would be helpful as it would get more attention there.
nope, I did not. thnx for the hint, I will open a ticket... -> http://trac.kodi.tv/ticket/16962
interesting discovery: out of curiosity, I tried build #1005 also on a generic DELL PC equipped with an NVIDIA GeForce 210. this system also was skipping frames, although much less often. like every few minutes it skips a single frame. OpenELEC 6.0.3 definitely isn't skipping any frames...
@Milhouse
after Updating to 1005 remote Control works perfect.
Greets
@Milhouse
Nuc 6i3 arrived and the problem is solved .... now I've installed the new Krypton build #1005 with no problem.
okay. as it seems, the cause of the issue I had is the long known limitation of certain intel graphics controllers (because of the clock generator logic these chips are unable to output true 23,976 Hz). I still wonder why I had no troubles while running OpenELEC 6.0.3 though...
How does one reenable long press?
@milhouse:
just read in libreelec forum, that in their V7.90.006alpha there has been a digitaldevices Cine S2 patch included, which helps using those tv-cards out-of-the-box.
Is this patch also included in your version ?
Still looking forward in testing your version with my hardware (Skylake HD520 + CineS2).
  • 149
  • 150
  • 151(current)
  • 152
  • 153
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
