  • 151
  • 152
  • 153(current)
  • 154
  • 155
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
Audio sync issues with Video set to change refresh rate on start/stop and passthrough audio enabled.
This is on 2 different HTPCs, one AMD APU and one NVIDIA GTX + AMD, one Asrock one MSI board.
I can set audio ahead/behind but it doesn't stay the same for different container types, ie. mkv/mp4/avi etc, or different qualities.
I can set to sync with display for video and ofc passthrough disabled and all is ok.
This is 2 different TVs, on 4k LG on Sharp Aquos.
Thanks for builds, very much appreciated! 8)
@badaas is this a recent problem, which build did this start with?
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-10-08, 14:44)Milhouse Wrote: @badaas is this a recent problem, which build did this start with?
Sorry, latest build.
The previous build I could set on 4k tv to ahead by 200ms and it seemed to work across all formats [passthrough to tv to optical soundbar - this works fine for all other devices/tv/apps].
I noticed it worse last night on Aquos [AMD APU 5350 + MSI], I couldnt set sync across formats on passthrough + set tv to refresh rate.
I can't see if it is in previous builds past the last 2 as only just started using this libreelec OS.
I know on windows kodi 17 latest beta's all has been ok on both HTPCs.
Media is stored on a hardwired NAS and database is SQL on the same NAS, never had issues [not sure that relevant but just in case!] Smile
(2016-10-07, 00:00)Milhouse Wrote:
(2016-10-06, 18:44)wookl Wrote: How does one reenable long press?
Are you saying there's a problem with longpress? Please describe in more detail...
I am using a fire tv bluetooth remote with a nuc5c, when I press the "enter" button I start to play a movie. It used to be so that when I long-pressed the "enter" button the context menu would come up, but when I try to hold the "enter" button it is doing repeat presses of play instead of a long press.
Identify the build that introduced the change of behaviour. Assuming this is intentional then you'll need to create a custom remote.xml that includes your longpress.
New LibreELEC.tv Krypton build #1008: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.0 #1 SMP Sat Oct 8 21:07:12 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161008210557-#1008-g5d0b534 [Build #1008]
Based on tip of LibreELEC.tv master (5d0b5347, changelog) and tip of XBMC master (2379b8eb, changelog) with the following modifications:
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (62b8520c, ahead +15)
  • Includes latest libnfs master (048e7737, ahead +59)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (b45f98ff, +8), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (e842db92), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (57b546a3, +2), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Exclude [env] libcec-PR208.patch: merged upstream (libcec)
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:759: linux: update to linux-4.8.0 [WIP]
  • Include [env] PR:792: scripts/build: use MinSizeRel cmake build type
  • Include [env] PR:796: scripts/build: cleanup
  • Include [env] PR:800: xf86-video-intel: enable dri3 and make it default
  • Include [env] PR:807: Network: smb & ntfs config mods
  • Include [env] PR:810: path: remove regex dependency when processing packages
  • Include [env] PR:812: libdrm: update to libdrm-2.4.71
  • Include [env] PR:813: scripts/build: no need to setup toolchain twice and before really building
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Revert [env] PR:793: projects/*/options: disable lcdproc for all projects except Generic/Virtual (Reverted until add-on available)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
  • Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
  • Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
  • Include [pkg] PR:10641: [video] fix NFO parsing of <namedseason>'s
  • Include [pkg] PR:10658: support reusing of CFile::m_pFile
Build Highlights:
  1. PR:10658: support reusing of CFile::m_pFile
Build Details:
  1. LibreELEC.tv:
    • kodi: correct patch on WP after 17b3 changes (PR:818, 1 commit, 1 file changed)
    • tvheadend42: wizard fix + general config updates (PR:814, 1 commit, 3 files changed)
  2. XBMC:
    • [doxygen] Add revision when API was changed or expanded (PR:10631, 1 commit, 15 files changed)
    • VideoPlayer: drop some outdated pullup correction code that does more… (PR:10651, 1 commit, 3 files changed)
    • [cmake/jenkins] Build with CMake (PR:10649, 1 commit, 22 files changed)
    • CUtil::MakeShortenPath() should return true if the given path is already short enough (fixes #16783) (PR:10640, 1 commit, 1 file changed)
    • FIX: [gles;oes] confusion between field and index (PR:10653, 1 commit, 1 file changed)
    • [webserver] CHTTPImageHandler: add GetLastModifiedDate implementation (PR:10032, 3 commits, 4 files changed)
    • [android] AMC: align allowed ref with player (PR:10655, 1 commit, 1 file changed)
    • [docs] clarify checkbox uasge in PR template (2379b8eb)
  3. pvr.iptvsimple:
    • Handle time offset in EPG programme start and end times (PR:89, 2 commits, 3 files changed)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:10658: support reusing of CFile::m_pFile
(2016-10-08, 11:27)Milhouse Wrote: Read the first post, there's an "Installing" section.
Hello. So I made it but it still does not solve the problem with some adoons like More Power or from czech republic SosačTV. Installation not work.Sad((
Can't help without a debug log, but unless those add-ons claim to be Krypton compatible there's no point trying to install them with these builds.
@don007 MorePower looks to be far from legit so please don't ask about that add-on in future, there's no support on these forums for add-ons that facilitate piracy.
(2016-10-09, 11:18)Milhouse Wrote: @don007 MorePower looks to be far from legit so please don't ask about that add-on in future, there's no support on these forums for add-ons that facilitate piracy.
Excuse me. It will not happen
@Milhouse changing to 4.8.1 in next build?
AppleTV 4K, LG 65E6 OLED TV, Marantz NR1606, Harmony Elite
(2016-10-09, 15:10)_Spook_ Wrote: @Milhouse changing to 4.8.1 in next build?
Which of the changes do you find relevant: https://cdn.kernel.org/pub/linux/kernel/...eLog-4.8.1 ? Or just "later / greater" thinking?
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
The builds will use 4.8.1 tonight, but I don't expect there to be any difference as far as LE and Kodi are concerned.
I just think that latest is always greatest Tongue And I am curious. No other reason.
Hi Milhouse,
i have an audio problem.
With my Zotac ci520 Intel Core i3-4020Y there is no DTS passthrough, only DD51.
With my Zotac ci321 Intel 2961Y there is no problem with DTS.
I used build #1008.
  • 151
  • 152
  • 153(current)
  • 154
  • 155
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
