2016-10-28, 20:42
(2016-10-28, 04:03)gujal Wrote: Can someone please advise how I get my Hauppauge IR Receiver recognised under libreelec
Thanks very much
Make a forum post on the LibreELEC forum and I will help you out.
Thanks very much
(2016-10-28, 15:21)john.cord Wrote: Seems that Video DB Cleanup is broken in V17. I had to disable "Wake Server on Access" to get is working and even then Kodi reported a Share as missing that was online and accessable. Idea?
(2016-10-28, 20:42)lrusak Wrote:The answer is already in this thread. You need to go back a couple months of posts.(2016-10-28, 04:03)gujal Wrote: Can someone please advise how I get my Hauppauge IR Receiver recognised under libreelec
Thanks very much
# uname -a
Linux NUC 4.8.4 #1 SMP Sat Oct 29 02:45:36 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161029024419-#1028-gd32cb9c [Build #1028]
# Kodi version
Kodi (17.0-BETA6 Git:e5cb8b0). Platform: Linux x86 64-bit
Quote:- no HEVC 10bit decoding, but I think that is known or normal status as I understand the posts before
Quote:- all Versions since I use Intel, not NVIDIA GPU: only limited Color Space possible in LibreElec.
Quote:- no audio passthrough (decoding by CPU works) (like in #1026+1027)
(2016-10-29, 10:15)llkobe Wrote: Hy There!
Is there a way to disable glamor on non GCN radeon cards? I'm getting terrible screen tearing since it was enabled. The last build that didn't use glamor
works perfetcly fine.
Thank you in advance!
cp /etc/X11/xorg-radeon.conf /storage/.config/xorg-radeon.conf
Option "DRI3" "1"
Option "AccelMethod" "glamor"
(2016-10-29, 17:10)_Spook_ Wrote: @fritsch when next gen NUC is released in january I can donate one with i3 to you
(2016-10-29, 20:59)flyingernst Wrote: So,
did now make a logged test of HD Audio passthrough (which didnt work) and additional one file with AC3 which worked
http://pastebin.com/t96AXxzt
Thats the Audio Log. Any other Log important?!
(2016-10-29, 21:02)flyingernst Wrote: Thats what i did!
# uname -a
Linux NUC 4.8.4 #1 SMP Sat Oct 29 21:31:27 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161029213009-#1029-gc6538f7 [Build #1029]
# Kodi version
Kodi (17.0-BETA6 Git:a0d63d1). Platform: Linux x86 64-bit
