  • 168
  • 169
  • 170(current)
  • 171
  • 172
  • 187
  Thread Closed
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-10-29, 01:12)_Spook_ Wrote:
(2016-10-28, 15:21)john.cord Wrote: Seems that Video DB Cleanup is broken in V17. I had to disable "Wake Server on Access" to get is working and even then Kodi reported a Share as missing that was online and accessable. Idea?
Works fine for me. Has on all builds.
The Missing Share was a typo in the path... but DB Cleanup is sometimes not working but i think its related to a problem with the Server Wakeup Feature...
(2016-10-22, 23:15)Milhouse Wrote: New LibreELEC.tv Krypton build #1022: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.2 #1 SMP Sat Oct 22 21:05:34 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161022210415-#1022-g69bca63 [Build #1022]
# Kodi version
Kodi (17.0-BETA4 Git:cf08208). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (69bca63e, changelog) and tip of XBMC master (cf082085, changelog) with the following modifications:
  • Includes FernetMenta "VideoPlayer" patches
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (c559955d, ahead +17)
  • Includes latest libnfs master (2edbd147)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (87a23de8, +28), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892, +1), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f, +3), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (2f3dfcdc, +2), pvr.nextpvr (6a2128d8, +1), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (5b47bd06, +1), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Includes commits from xbmc/master, ahead +2 (FernetMenta)
  • Exclude [env] libcec-PR208.patch: merged upstream (libcec)
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:837: lcdd: initial addon
  • Include [env] PR:859: linux: add support for VIA82XX audio in Generic builds
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
  • Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
  • Include [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
  • Include [pkg] PR:34: system update - fix cross-device linking (service.libreelec.settings)
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
  • Include [pkg] PR:10714: AESinkAUDIOTrack: Don't false alarm with m_offset
  • Include [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
Build Highlights:
  1. Clean build.
  2. Enable integrated AC97 support with VIA chipsets
Build Details:
  1. LibreELEC.tv:
    • imx6: build all additional drivers (PR:865, 1 commit, 1 file changed)
  2. XBMC:
    • smart playlists: fix drill down from artists lists that have role based rules (PR:10700, 1 commit, 1 file changed)
    • [xbmc][Fix] Guard against double free by setting our deleted values to nullptr (PR:10745, 1 commit, 1 file changed)
  3. peripheral.joystick:
    • [readme] Move repo to xbmc org (87a23de8)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:859: linux: add support for VIA82XX audio in Generic builds
I've tested LibreELEC v7.0.2 and it was the best Kodi experience in my old PC. I could play 720p videos smoothly that ran with lags on Kodibuntu and OpenELEC. The problem was that LibreELEC didn't recognized mi VIA AC'97 sound board so I had no sound at all. I tested this test build and the board was recognized (I can see it with aplay -l) but in this case LibreELEC did not finished booting. I got stucked at the LibreELEC logo and it seems to have an issue with the video in this case (http://sprunge.us/dVHb).
Anyway I've tested it on a netbook and it seems to be much more slow and resouses intensive than v7.0.2 (at least on old machines).
So the question is, could you build a 7.0.2 version with support for VIA AC97? It would be the ideal situation for me. It seems to run really fast on old machines.
I know maybe I'm asking something that is not where LibreELEC is going. If you can't do that, is any way I can do that myself? Can you help me in doing that? I'm not an expert but I can follow instructions.
Thanks in advance.
(2016-10-31, 16:46)garoto Wrote: So the question is, could you build a 7.0.2 version with support for VIA AC97? It would be the ideal situation for me. It seems to run really fast on old machines.
There may be a 7.0.3 in which case ask for support on the LibreELEC forum, but IMHO it wild be better to identify and fix the problem you have with your video hardware. You could start by posting a link to your Xorg.0.log, and a few other things:
cat /var/log/Xorg.0.log | pastebinit
dmesg | pastebinit
lspci -v | pastebinit
(2016-10-31, 16:46)garoto Wrote: If you can't do that, is any way I can do that myself? Can you help me in doing that? I'm not an expert but I can follow instructions.
Steps to compile LibreELEC can be found in the wiki: https://wiki.libreelec.tv/index.php?title=Compile
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
New LibreELEC.tv Krypton build #1031: Generic
# uname -a
Linux NUC 4.8.6 #1 SMP Mon Oct 31 21:23:06 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161031212148-#1031-gae704a7 [Build #1031]
# Kodi version
Kodi (17.0-BETA6 Git:14124fd). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (ae704a71, changelog) and tip of XBMC master (14124fd2, changelog) with the following modifications:
  • Includes latest libcec master (811eae4f, ahead +55)
  • Includes latest p8-platform master (2d90f986, ahead +9)
  • Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (e2dd8e69, +1), inputstream.smoothstream (081c6c43), peripheral.joystick (ae86732f), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (aa02879b, +2), pvr.mythtv (2f3dfcdc), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (810994a2), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
  • Include [env] ed1576d2: RBP: ARCH_MULTIPLATFORM changes (see PR:1699)
  • Include [env] 3c2d1813: linux: update to linux-4.8.6
  • Include [env] 28bc8bb1: linux: drop Cherry Trail support until fixed up
  • Include [env] 094361cc: i915: drop Valley View extended HDMI fix - incompatible
  • Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
  • Include [env] PR:898: systemd: machine-id.service is required for systemd-tmpfiles-setup-dev.service
  • Include [pkg] patch: i965: Add some APL and KBL SKU strings (mesa)
  • Include [pkg] PR:10775: bump to libCEC 4.0.0 + some rebased PRs
  • Include [pkg] PR:10785: add privacy policy
  • Include [pkg] PR:10819: fix hash checking in addon installer
  • Include [pkg] PR:10832: [PVR] Fix local art lookup log spam. pvr recordings never have local art.
Build Highlights:
  1. New 4.8.6 kernel (drop Valley View HDMI and Cherry Trail Audio commits, as no longer compatible with 4.8.6)
  2. Fix crash when caching images (PR:10828)
  3. Avoid occasional systemd-tmpfiles-setup-dev.service error on startup
Build Details:
  1. XBMC:
    • AudioTrack: Workarounds (PR:10809, 2 commits, 3 files changed)
    • [AMLUtils] Update aml_permissions() to check for RW access to more paths (PR:10822, 1 commit, 1 file changed)
    • [cmake] 2 small fixes related to binary-addon build (PR:10825, 2 commits, 2 files changed)
    • fixed: used av_free when av_freep was intended in f5f9b8d and aadfc21d (PR:10828, 2 commits, 2 files changed)
    • [cmake/android] Attempt to fix binary-addon packaging (PR:10827, 1 commit, 1 file changed)
    • Hide passwords from advancedsettings log (PR:10790, 1 commit, 1 file changed)
    • [PVR] Guide window: Fix responsiveness on first open. (PR:10814, 2 commits, 1 file changed)
    • FIX: [amcs] get proper VideoView size (fixes #17032) (PR:10818, 1 commit, 9 files changed)
    • [xbmc][fix] Make CDirectory::Create create all the needed folders (PR:10811, 1 commit, 6 files changed)
  2. libcec:
    • break on first valid drm edid (PR:262, 1 commit, 1 file changed)
  3. inputstream.rtmp:
    • fix cross compiling on android and linux (PR:8, 1 commit, 2 files changed)
    • Added: [env] 3c2d1813: linux: update to linux-4.8.6
    • Added: [env] 28bc8bb1: linux: drop Cherry Trail support until fixed up
    • Added: [env] 094361cc: i915: drop Valley View extended HDMI fix - incompatible
    • Added: [env] PR:898: systemd: machine-id.service is required for systemd-tmpfiles-setup-dev.service
    • Added: [pkg] PR:10832: [PVR] Fix local art lookup log spam. pvr recordings never have local art.
I got loop crashes on kodi with build #1030 when initating a library scan, but gone in #1031 so no biggy Smile
(2016-10-31, 23:58)_Spook_ Wrote: I got loop crashes on kodi with build #1030 when initating a library scan, but gone in #1031 so no biggy Smile
Yes, caused by PR10810 in #1030, fixed by PR10828 in #1031. Smile
A general problem with Libreelec when using Texture Cache Maintenance utility, from another network computer (Win10)
If I trigger the R option (delete orphaned thumbs in thumbnails), I get the error message:
Fatal: The Task you wish to perform requires read/write access to the Thumbnails folder, which ist inaccessible.
Is there a workaround to fix this?
cfg File entry looks like this:
xbmc.host = 192.168.1.50
userdata = ~/.kodi/userdata/
dbfile = ~/.kodi/userdata/Database/Textures13.db
thumbnails = ~/.kodi/userdata/Thumbnails/
webserver.port = 8080
webserver.username = kodi
@pacoma2610 you're in the wrong thread.
Oh yes, see it, sorry
please bump https://github.com/notspiff/visualization.shadertoy
New LibreELEC.tv Krypton build #1101: Generic
# uname -a
Linux NUC 4.8.6 #1 SMP Tue Nov 1 22:50:05 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161101224848-#1101-g61cb0dc [Build #1101]
# Kodi version
Kodi (17.0-BETA6 Git:5855cfe). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (61cb0dcb, changelog) and tip of XBMC master (5855cfe6, changelog) with the following modifications: Build Highlights:
  1. Restore CherryTrail HDMI/Audio support in 4.8.6
  2. Update mesa-13.0.0, with Mako package
  3. (Clean build)
Build Details:
  1. LibreELEC.tv:
    • systemd: machine-id.service is required for systemd-tmpfiles-setup-de… (PR:898, 1 commit, 1 file changed)
  2. XBMC:
    • ListItem.Year - prefer to use the year value from the firstaired date (PR:10770, 1 commit, 2 files changed)
    • [python] add xbmcgui.ListItem.setCast() (PR:10619, 1 commit, 2 files changed)
    • [python] add xbmcgui.Dialog().videoinfo() and .musicinfo() (PR:10616, 1 commit, 2 files changed)
    • [python] fix pydocs after a2f675e04b8e4c8dab2cf1398bcd2be2e3d8e98f (PR:10833, 1 commit, 1 file changed)
    • [PVR] Fix local art lookup log spam. pvr recordings never have local art. (PR:10832, 1 commit, 1 file changed)
    • [xbmc][fix] Don't try to index outside our lookup table and crash (PR:10831, 1 commit, 2 files changed)
    • Subtitles: allow self-closing br and html escape characters (PR:10813, 2 commits, 1 file changed)
    • slideshow: only stop video player, keep background music playing (PR:10835, 1 commit, 1 file changed)
    • Fixed OnPlayBackResumed not getting fired anymore. (PR:10739, 1 commit, 1 file changed)
    • DVDDemuxFFmpeg: Fix whitespace (PR:10821, 1 commit, 1 file changed)
    • VideoPlayer: hls, select best resolution closest to desired bandwidth (PR:10801, 1 commit, 2 files changed)
    • VideoPlayer: add user name and password back to url after testing for… (PR:10799, 1 commit, 1 file changed)
    • fix streaminfo set by python (PR:10824, 1 commit, 1 file changed)
    • [cmake] add our own FindLibXml2.cmake, needed for static libs (PR:10829, 1 commit, 1 file changed)
  3. libcec:
    • changed: renamed 'libcec-dev' to 'libcec4-dev' (81fe5bc0)
  4. inputstream.rtmp:
    • [depends] fix openssl install when INSTALL_PREFIX env var is set (PR:9, 1 commit, 1 file changed)
  5. pvr.vbox:
    • Genre mapping for programs, using mapping XML (PR:146, 8 commits, 7 files changed)
    • Added version check for VBox databases (channels & EPG) before fetch (a34454c4)
    • Added version check for VBox databases (channels & EPG) before fetch (8e496578)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] 881901c6: Mako: initial commit
    • Added: [env] patch: mesa: update to mesa-13.0.0
    • Added: [env] patch: visualization.shadertoy: update to 1.1.4
    • Added: [env] PR:900: linux: update to linux-4.8.6
    • Reverted: [pkg] c396c9a2: Makefile.ffmpeg: ffmpeg 3.2, libvpx 1.6.0, x265 2.1 (tvheadend42)
(2016-11-01, 17:54)ironic_monkey Wrote: please bump https://github.com/notspiff/visualization.shadertoy
There is an updated addon in the addons that you can install from zip. Completely untested.
Once the LE 8 repository is updated you'll need to uninstall this version and re-install from the repository in order to receive future updates.
i tested it enough dev'ing the fixes, this is for others to test. but thanks Smile
Why does the build # go from 1031 to 1101? New branch?
No new branch, just a new month (November = 11) Wink
  • 168
  • 169
  • 170(current)
  • 171
  • 172
  • 187
  Thread Closed
  • 11 Vote(s) - 3.91 Average
LibreELEC Testbuilds for x86_64 (Kodi 17.0)3.9111
