  • 180
  • 181
  • 182(current)
  • 183
  • 184
  • 187
v17 LibreELEC Testbuilds for x86_64 (Kodi 17.0)
(2016-11-28, 06:17)lrusak Wrote: You can run the "createlog" command via ssh, then the zip will appear in /storage/logfiles
createlog worked just fine.
I got the log but how do get it to you? Tried to send you a private msg with the zip but don't see any file attach option in PM as well. Is there any specific thing we do for attaching file?
-S
MINIX NEO U22-XJ | Denon AVC-X3800H | KEF Q750 | KEF Q250c | KEF Q150 | KEF Q50a | KEF Kube 10 MIE | LG OLED65G16LA | CoreELEC
Upload log to drop box, Google Drive or the likes, post like in your pm
Media Companion Dev.
Media Companion - Kodi / XBMC - Media Companion
(2016-11-28, 08:17)Milhouse Wrote: Can any other AMD RX4x0 users confirm the current state of play with this hardware, is HDMI sound working or not?
I don't have exactly that device but I see another issue playing video with ATI Radeon card. This is the one I have:
VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] (prog-if 00 [VGA controller])
    Subsystem: PC Partner Limited / Sapphire Technology Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] (Radeon HD 6450 1 GB DDR3)
    Flags: bus master, fast devsel, latency 0, IRQ 28
    Memory at d0000000 (64-bit, prefetchable) [size=256M]
    Memory at fe9c0000 (64-bit, non-prefetchable) [size=128K]
    I/O ports at c000 [size=256]
    Expansion ROM at 000c0000 [disabled] [size=128K]
    Capabilities: [50] Power Management version 3
    Capabilities: [58] Express Legacy Endpoint, MSI 00
    Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
    Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
    Capabilities: [150] Advanced Error Reporting
    Kernel driver in use: radeon
I can hear the sound but no video at all - player starts, sound comes out but it get stuck on the same screen. Is it another issue or I'm doing something wrong/stupid?
-San
Thanks vbat99! Here is the log:
https://www.dropbox.com/s/4ug0a3elrxs3a4...7.zip?dl=0
(2016-11-28, 21:13)sw4y Wrote:
(2016-11-28, 20:54)aatoledano Wrote: I have an strange problem. Samba is enabled and I can browse Samba from Kodi, but I am unable to browse the libreelec folders from my PC (windows 10) with \\<libreelec IP>. So I wasn't able to browse the update folder and update libreelec. Thank god I could use WinSCP to upload the file, maybe this should be explained on the tutorials as a third alternative.
Had the same problem - this helped me out
https://forum.libreelec.tv/thread-1252.html
Problems with Samba started with version #1018 I guess, at least I first had problems since that version.
Will give it a try, thanks!
Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
http://sprunge.us/MFaE
I just get a black screen.
New LibreELEC.tv Krypton build #1128: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.11 #1 SMP Mon Nov 28 21:06:15 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161128210447-#1128-g4d4fe5d [Build #1128]
# Kodi version
(17.0-BETA6 Git:17.0-beta5-e92818a). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (4d4fe5db, changelog) and tip of XBMC master (c5d944c1, changelog) with the following modifications: Build Highlights:
  1. New Chorus2 web interface
  2. Added pvr.octonet (Digital Devices Octopus NET Client) add-on
  3. Added Synaptics touchpad driver
Build Details:
  1. LibreELEC.tv:
    • packages/linux-drivers/wetekdvb: Update to wetekdvb-20161127 (PR:993, 1 commit, 1 file changed)
  2. XBMC:
    • New default webinterface Chorus2 (PR:10989, 2 commits, 115 files changed)
    • Fix GetFilter SQL for music artists, albums and songs nodes (PR:10974, 1 commit, 3 files changed)
    • Song Info Dialog contributors in control list (PR:10951, 1 commit, 4 files changed)
    • Fix processing of Performer/TMCL/TIPL Tag values (PR:10994, 1 commit, 4 files changed)
    • [Estouchy] Song Info Dialog contributors in control list (PR:11005, 1 commit, 1 file changed)
    • [estuary] sync (PR:11002, 1 commit, 107 files changed)
    • [listprovider] Refresh list when job was not finished (PR:10957, 1 commit, 4 files changed)
    • [DirectoryNodes] override GetChildType() for Episode DirectoryNodes (PR:11007, 1 commit, 2 files changed)
  3. kodi-theme-Estuary:
  4. inputstream.adaptive:
    • fix debian packaging (PR:2, 1 commit, 7 files changed)
    • cleanup (1ac4f839)
  5. pvr.hts:
    • 3.4.10. Adpated to pvr addon api 5.2.1 (3.4.9 was just to ake it compile again). (PR:251, 1 commit, 7 files changed)
  6. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: kodi-binary-addons: pvr.octonet initial package
    • Added: [env] PR:997: xorg-server: add Synaptics driver if using evdev
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-11-28, 23:56)_matt_ Wrote: Are there known issues currently with screensavers? Here's a debug log with my attempt at using the Solarwinds screensaver:
The problem is with the addon and the way it is packaged/built for Linux in the Team Kodi repository (ie. this is not a LibreELEC issue):
15:46:32.022 T:140715961202816   DEBUG: ADDON: Dll Initializing - Solarwinds
15:46:32.022 T:140715961202816   ERROR: ADDON: Could not locate screensaver.rsxs.solarwinds.so.1.3.0
It should be reported to the add-on maintainer.
The following will fix it, al least temporarily until any future add-on update breaks it again:
cd /storage/.kodi/addons/screensaver.rsxs.solarwinds
mv screensaver.rsxs.solarwinds.so screensaver.rsxs.solarwinds.so.1.3.0
We package this add-on so it's probably our issue. Not sure if we are installing symlinks or not (not sure of that's needed).
"PPC is too slow, your CPU has no balls to handle HD content." ~ Davilla
"Maybe it's a toaster. Who knows, but it has nothing to do with us." ~ Ned Scott
(2016-11-29, 00:49)lrusak Wrote: We package this add-on so it's probably our issue. Not sure if we are installing symlinks or not (not sure of that's needed).
Ah, I thought it was coming from the Team Kodi repo - my bad. And thanks.
Weekly kernel 4.9-rc7 test build #1128x: Generic
Note: Still waiting for an updated 340.xx nvidia-legacy driver, so don't use this build on nvidia-legacy hardware.
You can confirm your Nvidia driver with:
dmesg | grep "NVIDIA UNIX"
If the reported version is 340.98 then you're using the legacy driver and will want to avoid #1128x.
I tried the ShaderToy screensaver as well. It causes a restart of Kodi every time I try to preview it. Same issue?
http://sprunge.us/QdCY
Upload your crashlog (see note #4, first post)
Sorry, Milhouse. Here it is (hopefully): http://sprunge.us/AZXe
(2016-11-29, 05:28)_matt_ Wrote: Sorry, Milhouse. Here it is (hopefully): http://sprunge.us/AZXe
Thanks. What version of the screensaver.shadertoy add-on are you using? I suspect the version in the repo may be incompatible, and the last version I uploaded on 1 April certainly is, so it could just be crashing due to some binary incompatibility.
I've uploaded a new version of screensaver.shadertoy here - please install this new #1128 version and see if it works any better.
If it continues to crash, install this debug-enabled build #1128y as this will provide a more informative crashlog.
If you also plan on using visualization.shadertoy be aware that this add-on crashes (crashlog) quite regularly and as there's no way to report issues to the developer my advice is just don't use it.
  • 180
  • 181
  • 182(current)
  • 183
  • 184
  • 187
LibreELEC Testbuilds for x86_64 (Kodi 17.0)11
