Film Noir Theater
#31
(2017-03-13, 15:11)movie78 Wrote:
(2017-03-10, 16:25)Skank Wrote: Very nice,
So you have led light at the back too? Yes
So it's zero edge? So cool? Edgeless much better, just like the movie theater
How is picture quality comparing to my screen now: kingpin vfs210 16:9? (https://www.kingpinscreens.nl/velvet-frame-screen)
Is it as good? even better? I like the edgeless because it give more real estate and movie theater feel
I want a bigger screen, but those kingpin screens have huge borders (8cm), so an edgeless screen gives me the possibility to go larger... however. edgeless screens are expensive.
Might do a DIY screen edgeless like yours but then +- 100 inch... if it's doable and not too expensive.
How much did you spend? The Spandex material cost me about $50 and the wood and accessories about $50 I would say a total of $100
With Spandex screen it allows you to put your front LCR behind the screen and gives you more theater feel because the sound would be coming from the screen.
 Just upgraded my screen to 2:35 Smile
Nice!!
MY CURRENT MEDIA PLAYER | MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X  | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
Very nice, but now i have another problem.
Thers only 1 skin that does cih right..
Scopenox
I cant install it on my intel nuc.. Which is running 17.0 beta, cant upgrade there since theres no 3d working version for dn2820
Cant install it on zidoo either, cause that uses zdmc and external player... So no kodi gui with external player
Hate it
Film Noir Theater0
