nickr
Team-Kodi Member
If you pay for 76 and get 72, it is really within the margin of error.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
Oh yeah I am more than happy with the speed I get from my ISP, 4Mbps overhead is nothing. I wish I could afford a new Desktop to take advantage of the Gigabit network.
HTPCs: RPI 2B & 3B+ running LibreELEC 9.x.x
Control: Google Home + Broadlink RM Mini 3 + OSMC Remote
Audio: Pioneer VSX-819HK & S-HS 100 5.1 Speakers
Server: Acer ASX3400, 3GB RAM, 7.75TB, Xubuntu 18.04, NFS, MySQL
2017-10-19, 11:16
(This post was last modified: 2017-10-19, 11:16 by speedwell68.)
I have hit an issue with this. I noticed that the fan was running constantly. I checked the core temps of the CPU/GPU and whilst they weren't dangerously high they are higher than they should be. So I stripped it down and removed a colossal amount of dust/fluff from the heat sink, fan and duct. Also the thermal paste on the heat sink has gone to nothing. Cleaning it out has reduced the running temp a little. So I have invested 99p in a tube of thermal paste.
After much reading on the subject of CPU/GPU temperature on these machines I have discovered that running the proprietary Linux drivers has a big effect on chip temperature. I am a bit of an Opensource 'Fanboi' and will only run proprietary software if there is a real need to do so. I had been running the Opensource 'Neuveau' drivers as I saw no point running the extra Intel and Nvidia drivers, as I seldom use the display. I usually just SSH or VNC into it if I need to. However after a bit of experimentation, I have discovered that using the proprietary Intel Minicode and Nvidia ION drivers it has better fan control and the CPU/GPU/MB temps are about 10c lower.
My ickle tube of Thermal Paste came today, so I will have a go at doing that tomorrow.
nickr
Team-Kodi Member
Wifi has no place on a server. Kodi will handle either SMB of NFS, so take your pick. NFS is marginally more efficient and speedy.
Back to the temperature problem. I have just replaced the thermal paste on the Intel Atom and the Nvidia Ion and running 'sensors' over SSH the core temps on both chips have dropped around 10c. Also, the fan cannot be heard and sensors is reporting the fan speed is now only around 2000 rpm regardless of loading, whereas previously it was at about 3000 rpm at idle and anywhere up to 5000+ rpm on load. I also stripped the fan down as far as I could and took out loads of crud from the back of it's housing. I think I might treat it to a new fan as this machine is 9 years old and there must be some wear in the spindle and bearings, they cost less than £5 on eBay.
In the new year I intend to replace the HDD with an SSD and replace Xubuntu with Bodhi Linux as it is super minimal. I have to run a GUI as the proprietary Nvidia drivers are required for proper fan control and they won't run without a GUI.
When I look at some of the media server builds on here that use the biggest and best chips with bucket loads of ram, that must be burning electricity hand over fist, I ask myself why?
nickr
Team-Kodi Member
As I said in post 3, external drives drive me nuts.
My Father in Law has just upgraded his Sky satellite receiver so he has gifted me his old one. In these Sky HD boxes is a 500GB 3.5" SATA HDD which I put in a caddy and use as a second TV Shows drive, which has worked out nice as my existing 1TB TV drive is over 75% full. It also helps me stick with my ethos of re-purposing kit that would otherwise be scrapped. I am also going to look at getting CEC working properly on my RPI2 and use the Sky+ remote to control the whole rig, as they are fairly nice remote. I am thinking that my AVR isn't passing through the CEC from the TV to the Pi properly. The Pi is reporting that the TV is connecting at startup but it isn't responding to the TV's controller.
