Release Now Playing - (Displays what you're playing in Kodi on your web site!)
#16
v2.3
- Logo, banner, fanart
v2.4
- Improved series episode handling
- Don't display ATV saver info
v2.5
- Unicode error fix
v2.6
- Improve logic
v2.7
- Bug fix
v2.8
- Do not display Video Screensaver info
v2.9
- Icon change
hi any chance of a direct zip download link?
my kodi does not have access to the internet, its a closed system
Sure, but if you don't have access to internet how are you going to use this addon which sends files to the web? Smile Smile
http://kodi.lanik.org/_repo/service.kodi...ng-2.9.zip
Smile
A local FTP server, closed network would be a better description Smile
v3.0
- Bug fix
This plugin is perfect for a project im working on, but every time i play something in Kodi the mus.xml file gets written with the same contents regardless of what i play:
xml:
<?xml version="1.0" encoding="UTF-8"?>
<none>
<name>No Activity (Idle)</name>
<loggedon>Master user</loggedon>
<started>2018-02-06 20:07:57</started>
</none>
Also the plugin keeps complaining that it needs to be configured although i have configured it via kodi since its writing the xml file to my FTP site, am i missing out on something here?
Hard to tell, can you post your debug log? You need to open the addon settings and enter the ftp adress and password.
v3.1
- Language file format related changes
Hi Dalibor,
I just found your projects on kodi etc...
i have my kodi pc build on a Mini itx board in a 19"casing with a smoke plexyglass front
I have made an android app to show what is playing but it crashes too often, when looking for better info to scrape the info i found your aproach to the almost same problem.
I liked it an i plan to use it too :-)
Dous it display music also ?
only thing i mis is, time to end etc...
but maybe i can make that myself
Thanks so far.
Now Playing - (Displays what you're playing in Kodi on your web site!)0
