Nevermind... I think I got it
Hopefully... ahh, good old days when ASCII was the only option
Try it now, I updated the repository with v1.5.0
Good morning, i was writing to you that no line referred to the error was shown in the log just the path of my photos and the number of levels iicrc.
I see new update, I'm performing a scan now, and folder.jpg are created under user_data both in deepest folders that in the one we need. So we are ok.
2016-06-30, 09:19
(This post was last modified: 2016-06-30, 09:43 by peppe_sr.)
all done, all images created without errors.
have you thought at some improvements of the behaviour?
- now if i add a new folder to my collection, not in kodi, i have to rescan all again.
- if i dislike a thumbnails created and i want redo just one i can't i have to rescan all again.
thanks again for this cool script.
Peppe
EDIT
another little thing that i don't know if you can control with your script:
the creation of thumbnails ignores the exif informations related to the orientation of images.
Peppe
Great, important that I got through with this encoding stuff
Now I can try to improve small things....
I think I can make it so that it ignores folders with folder.jpg, that should be pretty easy.
I have no idea how to solve the thumbs that you don't like - now I am scanning ALL pictures and selecting random 4.... but we'l see
EXIF? Hmmm, I'm just checking width/height... will see if I can read EXIF info from images
regards,
D.
2016-07-06, 21:21
(This post was last modified: 2016-07-07, 11:27 by User 325245.)
(2016-06-30, 09:19)peppe_sr Wrote: another little thing that i don't know if you can control with your script:
Peppe
Can you try new version (1.6) if EXIF rotation tag works?
D.
edit:
updated to v1.7 - added option no to overwrite existing thumbs (folder.jpg)
v1.8
- Optimize reading
- Overalll code cleanup
- Add 3rd level folder thumbs creation
- Added Serbian, Serbian Cyrillic and Czech translations
i'm reading now. i will test as soon as possible!
Peppe
Updated:
v1.9
- Better debugging
Atreyu
Posting Freak
2016-07-22, 00:18
(This post was last modified: 2016-07-22, 00:21 by Atreyu.)
That's neat, another handy addon :-)
Just a thing i noticed from the screenshot you posted on the first page.
It might already have been corrected, but it contains a spelling error on the shown 'create thumbnails' dialog.
Directiry should be directory...
Will take a look, thanks!
2016-07-22, 21:21
(This post was last modified: 2016-07-29, 13:43 by User 325245.)
v2.0
- Typo fixed (thanx Atreyu!)
v2.1
- Bug Fixes, optimizations
v2.2
- Context menu - delete single thumb, whole tree, recreate 1st level thumbs, whole tree
2016-08-01, 10:40
(This post was last modified: 2016-08-01, 10:50 by User 325245.)
Right now, thumbs are in JPG format, and I think this is the only way it works. Kodi expects folder.jpg file, I am not sure .png would work... I'll test and see...
As far as refreshing goes - I found out that after you make thumbnails, you have to refresh thumbs (kodi option from right-click or "c" menu - regenerate thumbnails) and then sometimes to OPEN this folder and then go back and then press "regenerate" once more....
Will give a try with png.
OK, here are the results of test:
When I use PNG, the folder uses the image and has transparency (cooool!!!)
But!!!
When you open the folder, the folder.png image is VISIBLE as normal image:
Which is not cool
