!!!!! Help- About To Throw Xbox Out The Window!!!!
LOCK PREFERENCES ISSUE
Ive been having this problem for weeks and weeks. ive pulled every hair out of my head to figure out what the problem is. Ive been trying to stream media from my computer to my xbox. When i go to my xbox and go to my music i see my netowrk and when i click on it ives me this message
LOCK PREFERENCES FOR SMB://192.168.69/home/My Music/
USERNAME(XBOX)
PASSWORD
and it tells me to log in. ive tried every cobination i know and it wont let me in.
VITAL INFO
HERE ARE MY SETTINGS IVE SET UP
XBOX NETWORK SETTINGS
STATIC IP(manual)
ip: 192.168.70
netmask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS Server: 192.168.1.1
using Unleash X Dashboard and Running XBMC as APP.
I have the older version of XBMC. Ive tried it with the newer ones but same error.
PC IPCONFIG
C:\Documents and Settings\Owner>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HOME
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethe
rnet NIC
Physical Address. . . . . . . . . : 00-11-09-08-82-2E
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.69
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : Tuesday, August 28, 2007 11:35:21 AM
Lease Expires . . . . . . . . . . : Wednesday, August 29, 2007 11:35:21
AM
IVE SET UP MY SHARED FOLDER BY GOING TO MY MUSIC AN RIGHT CLICKING ON IT AND SELECTING SHARING AND SECURITY..
I DONT HAVE THE OPTION OF SIMPLE SHARING IN FOLDER OPTIONS.
i am stumped.. i dont know what to do.. any help would be appreacieted.
Kallan001 Wrote:LOCK PREFERENCES FOR SMB://192.168.69/home/My Music/
I am assuming that is a typo seeing as how you are missing the .1 before the .69. Is that how you actually have it set up or do you have a .1 in there? If not, there could be your problem otherwise what I do is set the user name and password in the network settings and then I have no problem getting to my PC shares. Just make a new user on your pc and use that in your network settings.
J_K_M_A_N
did u set up a workgroup in windows xpHuh
J_K_M_A_N- lol yea thats a typo sorry..
craze7- yea its called HOME. In "My Network Places" under "The Internet" theres an icon that says "my Music on Home". Maybe i didnt do it right? could you tell me how to do it in detail? that would be wonderful. thanks.
One presumes in XBMC you just went "Add Source" then "Add Network Source", and clicked on Browse?
Don't set by IP if you can avoid it. Just try browsing to the share.
Always read the XBMC online-manual, FAQ and search the forum before posting.
Do not e-mail XBMC-Team members directly asking for support. Read/follow the forum rules.
For troubleshooting and bug reporting please make sure you read this first.
all i did was this, set my xbmc dash to auto network settings, restart and if u see ur rss feed ur grand..
set up ur workgroup on xp and call it "WORKGROUP" pass is optional but i dont use one..
then in xbmc go to smb client under network settings and call your work group "WORKGROUP"
Then click add source under video, click add source/add network location/ it should say windows network smb, click browse server name and it should show ur "workgroup" then ur pc name..
once u click that it will list all ur shared folders/ drives!!!!!
im using vista now so im a bit sketchy!!!!!
still no luck...
Is File and Printer sharing enabled in Windws firewall.
Did you run the Network file sharing wizard?
I have the windows firewall on off. maybe i have other firewalls? but i dont see any icons on the task bar that relate to firewalls or an anti virus software.. is there a way to check if i have a firewall?
oh and btw i cana acess feeds
can or cantHuh?
May or may not help anyone, but here is how i setup my shares at the PC side, works for me, i've seen some folks having problems there....
1 - Setup a new windows user account with password, for your xbox (And setup xbmc network with same user/pass)
2 - Disable simple file sharing. (Control panel/folder options/view)
3 - Right click folder to be shared, select "sharing and security"
Under both Sharing and Security, add user Xbox to the list
Just noticed you have no simple file sharing option, what version of windows are you on (XP, vista, home, pro...etc) Do you get the security tab? or the permissions option under sharing?
Shorty
Question
sorry about the typo.. i was in a rush.. i CAN access the FEEDS.
i am using windows xp home. i can go on the web using linksbok too
but i just cant acccess my files...
maybe there is a way to get the lock preferance feature out of the program itslef?
Do you have Windows XP Pro or Home?
  • 0 Vote(s) - 0 Average
!!!!! Help- About To Throw Xbox Out The Window!!!!00
