I have a directory containing multiple files from the same film, but TMM detects them as three different films.
/MOVIE
MOVIE Part 1.mkv
MOVIE Part 2.mkv
MOVIE Part 3.mkv
I can't figure a way to merge all three entries into one.
I could delete entries 2 and 3, but then I can't find a way to manually add the 2 other files to the first entry. As a result, every time I update the library, it causes problems.
I could rename to files to something like movie.cd1.mkv, movie.cd2.mkv, movie.cd3.mkv, and it would probably work (would it ?), but I'd like to avoid this solution.
Any help ?
myron
Posting Freak
Which version do you have?
Can you send us the logs?
It works here...
myron
Posting Freak
2016-08-09, 10:38
(This post was last modified: 2016-08-09, 10:52 by myron.)
Ah ok, i see.
Problem here is, that the "stacking marker" like Part X is defined to be the LAST thing in filename...
Have to ckeck, if we could tweak that a bit...
We always use the folder name for title.
But since the movie is not detected as stacking, we see 3 "different" movies in a single dir, and in this case, we have to take the filename...
Or you could merge them with ffmpeg.
Remove the blank in "Part 1".
Here's the link to Kodis rules (see chapter 4.1). This works for me:
Naming video files
This is how I control merging or separating movie files.
If I want to make each part a separate movie item:
Carlos Part 1 (2010).mp4
Carlos Part 2 (2010).mp4
Carlos Part 3 (2010).mp4
If I want to merge files under one movie item:
Carlos (2010) Part 1.mp4
Carlos (2010) Part 2.mp4
Carlos (2010) Part 3.mp4
The example above "Harry Potter 7 - Part 2 CD1 (2011).mkv" should be the same.
To separate:
"Harry Potter 7 - Part 2 CD2 (2011).mkv
To merge:
"Harry Potter 7 - Part 2 (2011) CD1.mkv
"Harry Potter 7 - Part 2 (2011) CD2.mkv
myron
Posting Freak
Is there a reason for NOT joining them together?
Because if i change this now, all variants might be detected as multipart movie correctly.
Since TMM is a tool for organizing/normalization, WE need to parse this accordingly, to correctly write/rename this for Kodi...
PS:
Roman letters like "Part II" are NOT detected as stacking either
Actually I don't join them at all because I'm using export function extensively.
If I have multiple video files for a movie, it then populates multiple resolutions, bit rates etc., for a single movie, breaking column alignment.
I'd appreciate if you just leave it as is since it's working fine and flexibly as I posted above.
was this ever fixed as I am having same issue with 3.0.5
