EPG not working in New Zealand
I have the latest XTi-3442 vbox running the latest firmware revision
It pickups all the freeview channels ok and I can stream them over my network to various devices.
The problem I'm having is that in the EPG most items show as "string format not supported" so I can't actually tell what is on any of the channels.
This makes the system next to useless :-(
I've contacted support and waiting for a reply.
From the little I could find online it would appear that this is to do with the EPG being encrypted. Why would they sell a box for use in NZ if doesn't actually workHuh
thanks
Phil
Hello fellow Kiwi.
It wouldn't be the only thing ever sold that doesn't work.
I am not familiar with this device or how it works with kodi. There are however xmltv grabbers available for NZ Freeview if that would help. Let me know and I will point you in the right direction.
A great place to get support for all things geek in NZ would be geekzone.co.nz forums.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
EPG not working in New Zealand0
