Can someone ELI5 why its a bad thing that HDR is turned on all the time in Windows please?
Does it affect the picture if non HDR content is being played?
Sorry for what may be quite ignorant questions but I wasn't planning on having a 4K HDR TV yet but the one I was saving up for was such a good price in this weeks deals I had to buy it and its arriving tomorrow, subsequently I haven't looked into all the pros and cons of HDR be it always on, always off or dynamically switched.
Hello everybody
I have learned from the manufacturer of my ZBOX CI547 NANO box you use another controller such as the intel nuc box.
HDMI 2.0 interface controller: Parade Technologies (PS175)
and supposedly that the passthrough HD audio should not be a problem.
Is that true or do they just want to put me off?
ODROID-N2 4 GB RAM CE 19.2 Kodi 19
Updated to latest Intel drivers and latest PowerDVD patch on two KL boxes, now watching 4K rips using PowerDVD works flawlessly. Prior I would get auto HDR switching but no audio when HDR was enabled.
I have the BeeBox 7100u (same bios) --> Denon x2300 (latest update) --> Samsung UN65JS8500 (latest firmware) and working great on my end.
Although I never see Atmos displayed, not sure if receiver needs to be set up as such to have it displayed, DTS-X does display for me.
I have a HTPC build with AsRock Fatal1ty Z270 Gaming-ITX/ac connected to Marantz 8802. I was trying to see if 4K HDR works in my set up with PowerDVD 17 so I enabled SGW in BIOS and downloaded ASROCK HDCP 2.2 toolkit. Once I run the toolkit, I am losing bitstreaming of lossless audio, which immediately restores after downloading HDMI Firmware upgrader ver:1.66 (listed on AsRock site as well). I don't know if any other users with the same motherboard experienced the same bitstreaming issue.
P
