Connect to tv server across network
I have the tv server running on one pc on the network and would like to know how I can connect Kodi to it from another machine.
The MediaPortal app connects to it fine, but my Kodi log shows this:
15:47:40.353 T:16332   ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 127.0.0.1:9596
15:47:40.353 T:16332   ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=0) WSA Error
15:47:40.353 T:16332   ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
15:47:40.353 T:16332   ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
15:47:40.752 T:13088  NOTICE: Skin Helper Service --> skin helper service version 1.0.100 started
15:47:40.787 T:13088  NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
15:47:40.793 T:16624  NOTICE: script.grab.fanart: Grab Fanart Service Started
15:47:43.344 T:16332   ERROR: PVR::CPVRClients::UpdateAddons - failed to create add-on MediaPortal PVR Client, status = 1
Your log is massively incomplete, but it looks like you are trying to connect to mediaportal on your kodi machine (127.0.0.1). Try putting the ip address of the server into the mediaportal settings in kodi.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
Connect to tv server across network0
