  • 133
  • 134
  • 135(current)
  • 136
  • 137
  • 495
v18 LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)
Just got a stupid question,
Now I have not updated for many days, the last one is # 507, can I just take the latest one, I also get everyone, or should I take one of the times?
Take the latest one.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2017-06-12, 20:24)Milhouse Wrote: Take the latest one.
thank you
New LibreELEC.tv Leia build #0612: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.11.4 #1 Mon Jun 12 21:04:45 BST 2017 armv6l GNU/Linux
# vcgencmd version
Jun  8 2017 13:35:04
Copyright (c) 2012 Broadcom
version 0784a9f7dfa6a45aa2524eeab1980da00cd93019 (tainted) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170612210321-#0612-g16fdbb7 [Build #0612]
# Kodi version
(18.0-ALPHA1 Git:423072a). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (16fdbb7a, changelog) and tip of XBMC master (5b0d6818, changelog) with the following modifications: Build Highlights:
  1. [addons] change visualization to new way
Build Details:
  1. XBMC:
    • [addons] change visualization to new way (PR:12262, 2 commits, 23 files changed)
    • [addons] fix my mistake with git "add ." on wrong place (PR:12290, 1 commit, 1 file changed)
    • [addons/settings] CAddonSettings: fix "file" settings not opening the file selection dialog (PR:12291, 1 commit, 1 file changed)
    • Cleanup up unused stuff under tools/ (PR:12294, 3 commits, 6 files changed)
  2. peripheral.joystick:
    • Fix settings (PR:111, 2 commits, 4 files changed)
  3. kernel 4.11.y:
    • New commits in this build:
      • config: Add CONFIG_CAN_GS_USB (935308cd)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1687: e2fsprogs: do not build fuse2fs
(2017-06-11, 22:22)peak3d Wrote: @bmonster: any special advancedsettings.xml in use? If unsure, can you pls. provide a kodi log after kodi startup? thx!
No nothing at all, no advanced settings, just a couple of addons, youtube, extended info, tv shows next aired, and iplayer.
Using stock skin as well.
Kind regards
Bucky
(2017-06-11, 23:53)Milhouse Wrote:
(2017-06-10, 23:11)Milhouse Wrote:
(2017-06-10, 18:27)bmonster Wrote: Hi Milhouse,
Noticed a little bug that started with 0605, using an addon like extended info script, when you scroll down thru the info, the button/focus moves down but the screen doesn't, so the active button goes off screen.
Same with tv shows next aired addon. when moving right thru the days of the week the focus moves along, but again the screen doesn't.
Back on 0604 and everything's working fine again..hope you can understand what I'm trying to explain..
Kind regards
Bucky
Edit: checked my windows x64 nightly and the same issue is there..
Thanks for the report - there were a few PRs that might cause this in #0605, my guess would be PR12224, PR12232 and PR12234 - ping @peak3d and @alwinus.
@bmonster are you sure this issue is first seen with #0605? My testing suggests it starts with #0606.
Hi Milhouse,
Ive just checked 0605, and im still seeing the problem with extended info and tv next aired, button moves but screen doesnt..
Kind regards
Bucky
(2017-06-12, 22:54)bmonster Wrote: Hi Milhouse,
Kind regards
Bucky
I couldn't reproduce the issue with tv next aired - it works, and the cursor seems to track the selection, but it doesn't show any thumbnails (which doesn't seem to be a recent issue) - however I could see the problem with extended info but only starting with #0606 (test build #0610c for Generic works perfectly). A possible fix is PR12295 that has just been pushed - I'll test that and publish a test build for you a bit later tonight if it fixes the extended info script.
Kind regards
Bucky
Can you test with build #0612b: RPi2
This is the same as #0612 but includes PR12295 - please confirm if the reported issues are now resolved (or new issues introduced). Thanks.
Kind regards
Bucky
Hi Milhouse,
I can confirm 0612b fixes the issue, no new bugs seen so far..
Thank you
Bucky..
Kind regards
Bucky
the thumbnail issue started with the introduction of estuary, so its been there quite a while, fanarts ok thankfully..
Thanks @bmonster.
Edit: Also, I've now seen the issue with tv next aired (fixed in #0612b) - my testing was sub-standard (it's a little hard to tell the scrolling isn't working without the thumbnails!) Smile
Has anyone reported the thumbnails/Estuary issue to the add-on maintainer?
Are there now new visualization addons?
Because # 0612 cries incompatible visualization addons Blush
[3x RPi3]#[ AV Receiver - Marantz NR1506 ]#[ TV Panasonic TX-50EXW784 ]#[ NAS - OMV 4.1.xx (Arrakis) @ NanoPI M4 ]#[ Nextcloud 17.0.3 @ ODROID C2 ]
I've just pushed #0612 updates for:
visualization.shadertoy
visualization.spectrum
visualization.waveform
Any better?
(2017-06-13, 16:37)Milhouse Wrote: I've just pushed #0612 updates for:
Any better?
I can confirm that all works perfectly again Cool
Many thanks Milhouse
And screensaver.shadertoy? If start config, it shows wrong display
  • 133
  • 134
  • 135(current)
  • 136
  • 137
  • 495
LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)24
