2017-11-22, 00:32
New LibreELEC.tv Leia build #1121: RPi / RPi2
(Supercedes previous build)
SHA256 Checksum: 1b00499c82e0053ab21358a2223270a610978cf774f0f1bfba47ff07066d3261 (RPi)
SHA256 Checksum: f67baafb08d5c87878c79f40cc59da003a0f1831393fda14667f2d48632bdcf9 (RPi2)
Based on tip of LibreELEC.tv master (194287b, changelog) and tip of XBMC master (8193496, changelog) with the following modifications:
# uname -a
Linux rpi512 4.14.1 #1 Tue Nov 21 21:46:09 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Nov 17 2017 15:23:56
Copyright (c) 2012 Broadcom
version 2c2faa4c5e38cc04d01245905b8338e8fc55ee0d (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171121214456-#1121-g194287b [Build #1121]
# Kodi version
(18.0-ALPHA1 Git:8193496). Platform: Linux ARM 32-bit
- Includes newclock5 patches
- Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.14.y
- Includes latest bcm2835-driver master (4e09292, ahead +3)
- Includes latest kodi-platform master (36fb493)
- Includes latest libcec master (8adc786, ahead +26)
- Includes latest libnfs master (7c68a3d, ahead +106)
- Includes latest p8-platform master (a822e19)
- Includes latest addons: inputstream.adaptive (d2081b2, +5), inputstream.rtmp (0702f7e), peripheral.joystick (33b43ce, +11), pvr.argustv (5b9bdad, +2), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (6129441, +1), pvr.filmon (2dee2ca, +2), pvr.hdhomerun (3af3e91, +11), pvr.hts (67fe2df, +11), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (6c35e88, +1), pvr.mythtv (ffaa1b5, +5), pvr.nextpvr (938bb48, +2), pvr.njoy (4a5efef, +1), pvr.octonet (c4af00a, +1), pvr.pctv (6484615, +4), pvr.stalker (44025a1, +3), pvr.teleboy (2d092c4), pvr.vbox (619c32b, +2), pvr.vdr.vnsi (0ec3e77, +3), pvr.vuplus (7ea6b21, +2), pvr.wmc (55e701b, +1), pvr.zattoo (23d9993, +5)
- Include [env] compare (perma): connman: timeserver: Retry NTP servers periodically on startup
- Include [env] compare (perma): dmidecode: initial package
- Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
- Include [env] patch: libcec: don't link non-existant libtinfo
- Include [env] patch: rev hack for kodi
- Include [env] patch: media_build: disable due to conflicts
- Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
- Include [env] PR:2138 (perma): removed OE mirror links
- Include [env] PR:2144 (perma): Tvheadend 4.2 rework to use ffmpegx
- Include [env] PR:2182 (perma): kodi: updates for Dec 2017
- Include [env] PR:2228 (perma): kodi: safe mode
- Include [env] PR:2241 (perma): samba: update to samba-4.7.3
- Include [env] PR:2242 (perma): linux: update to linux-4.14.1
- Include [pkg] compare (perma): add safe mode text (service.libreelec.settings)
- Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
- Include [pkg] PR:55 (perma): Fix deprecated function warnings (pvr.pctv)
- Include [pkg] PR:86 (perma): connman.py: More secure default password for tethering (service.libreelec.settings)
- Include [pkg] PR:103 (perma): jsoncpp deprecated function change (pvr.stalker)
- Include [pkg] PR:13062 (perma): smbclient changes for smb minprotocol and legacysecurity
- Revert [pkg] f08f58a2: ARM: dts: bcm283x: Fix console path on RPi3 (reason: aliases confuse firmware) (linux)
- New 4.14.1 kernel
- Update to Samba 4.7.3 (security fixes)
- New videodb amd musicdb schemas (v109 and v69 respectively)
- ffmpeg: hevc: Split gpu codec into separate hw accelerated codec
- LibreELEC.tv:
- virtual: avoid exiting with failure code (PR:2238, 1 commit, 1 file changed)
- XBMC:
- added: flag whether vfs add-ons can handle write operations (PR:13071, 1 commit, 3 files changed)
- added: add browsable vfs protocols to CMediaManager::GetNetworkLocations (PR:13070, 1 commit, 1 file changed)
- add archive:// to list of url types with encoded hostname (PR:13054, 1 commit, 1 file changed)
- [PVR][keymaps][guiinfo] Fix / improve subchannel numbers support (PR:13069, 10 commits, 38 files changed)
- changed: drop unused OutputToAllSpeakers setting from database (PR:13074, 1 commit, 3 files changed)
- Remove artist_genre table bumping musicdb to 69 (#13042) (8193496)
- pvr.hts:
- 4.2.7: Fixed predictive tuning. (PR:344, 2 commits, 6 files changed)
- newclock5:
- New commits in this build:
- ffmpeg: hevc: Split gpu codec into separate hw accelerated codec (434079b0)
- kernel 4.14.y:
- dwc_otg: Fix compilation warnings (7b5f7ff4)
- BCM_VC_SM: select DMA_SHARED_BUFFER (d0e37f74)
- drm/panel: Add support for the Raspberry Pi 7" Touchscreen. (17528296)
- panel-raspberrypi-touchscreen: Fix NULL deref if probe order goes wrong. (94049359)
- panel-raspberrypi-touchscreen: Round up clk rate to fix DSI panel. (d13c63e8)
- BCM270X: Add the DSI panel to the defconfig. (9c54c58d)
- drm/vc4: Add support for setting DPMS in firmwarekms. (3745cd86)
- drm/vc4: Fix pitch setup for T-format scanout. (5b992aac)
- config: Enable CONFIG_BRCMDBG temporarily for debugging (4d814731)
- brcmfmac: Disable ARP offloading when promiscuous (5b54c029)
- brcmfmac: Avoid possible out-of-bounds read (59f82795)
- brcmfmac: Delete redundant length check (b7832958)
- USB_DWCOTG: Disable building dwc_otg as a module (#2265) (d457fc52)
- allo-piano-dac-plus: Master volume added + fixes (9391737b)
- allo-digione: 192kHz clicking sound fix (776f81d6)
- Fixed a bug when using 352.8kHz sample rate (08e03ba6)
- config: Add CONFIG_GPIO_WATCHDOG=m (67fc8fbe)
- config: Add CONFIG_W1_SLAVE_DS2438=m (a85d31c3)
- ARM: dts: Add fake CTS signal to pi3-miniuart-bt (a498f3c9)
- mcp2515: Use DT-supplied interrupt flags (9f3fdf9f)
- overlays: i2c-rtc: add m41t62 (92d5ce81)
- BCM270X_DT: Set spidev spi-max-frequency to 125MHz (14ebd4ad)
- Revert "hid: Reduce default mouse polling interval to 60Hz" (8cf08695)
- Include tsl4531, veml6070 and hdc100x dtoverlay (#2252) (6dd5a4ec)
- Tidy up of the ft5406 driver to use DT (#2189) (9bac591e)
- configs: Regenerate defconfigs (cosmetic) (d702f1e4)
- pinctrl-bcm2835: Set base to 0 give expected gpio numbering (54a036e9)
- Updated: [env] PR:2182 (perma): kodi: updates for Dec 2017
- Updated: [env] PR:2228 (perma): kodi: safe mode
- Updated: [pkg] compare (perma): add safe mode text (service.libreelec.settings)
- Added: [env] PR:2241 (perma): samba: update to samba-4.7.3
- Added: [env] PR:2242 (perma): linux: update to linux-4.14.1
