  • 252
  • 253
  • 254(current)
  • 255
  • 256
  • 495
v18 LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)
I'm getting an occasional crash when trying to play a DVD folder.
Crashlog
@smp1 can you determine the first build with this issue?
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2017-12-03, 04:45)Milhouse Wrote: @smp1 can you determine the first build with this issue?
 I will try but it will take some time. I can't easily reproduce this. The issue seem to be present only when I try to play a DVD folder during the playback of another file or when watching a live TV.
There is also another issue that may be related to those crashes - when I try to play a DVD folder during the playback of another file - the playback does not start and it just quits to Kodi GUI. This one is 100% reproducible.
(2017-12-03, 05:20)smp1 Wrote: I will try but it will take some time. I can't easily reproduce this. The issue seem to be present only when I try to play a DVD folder during the playback of another file or when watching a live TV.
It could be something to do with:
PR:12797: VideoPlayer: make OpenFile asynchron
which first appeared in #0913, so it might be worth testing #0912 and then #0913 to see if the behaviour is noticeably different between the two.
New LibreELEC.tv Leia build #1203: RPi / RPi2
(Supercedes previous build)
SHA256 Checksum: b977663ff4259c618dcd15bd2751d4f5f8d9b83392bab2a7759ebb27144d0885 (RPi)
SHA256 Checksum: 41571b5454aa4531f5f75e71b2fd1189ec75cb6a87e6cf69cf59cf783f0af60d (RPi2)
# uname -a
Linux rpi512 4.14.3 #1 Sun Dec 3 21:30:27 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec  1 2017 16:20:32
Copyright (c) 2012 Broadcom
version 38ac72569d7fbd7cf75754d9f14c2495416aaee7 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20171203212915-#1203-g7ab7345 [Build #1203]
# Kodi version
(18.0-ALPHA1 Git:1e9d6ba). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (7ab7345, changelog) and tip of XBMC master (1e9d6ba, changelog) with the following modifications: Build Highlights:
  1. [PVR] Completely reworked playing flags. Moved almost all logic to PVR Manager
  2. VideoPlayer: add support for programs
Build Details:
  1. XBMC:
    • DVDVideoCodecAmlogic: Add VP9 HW decoding support (PR:13081, 2 commits, 4 files changed)
    • drop OSX specific keyboard hack (PR:13104, 1 commit, 8 files changed)
    • Android: Drop Shield workarounds (not needed anymore) (PR:13111, 1 commit, 2 files changed)
    • [PVR] Completely reworked playing flags. Moved almost all logic to PVR Manager (PR:13127, 4 commits, 18 files changed)
    • VideoPlayer: add support for programs (PR:13112, 6 commits, 21 files changed)
  2. pvr.mythtv:
(2017-11-21, 19:53)popcornmix Wrote:
(2017-11-21, 02:33)smp1 Wrote: I'm getting intermittent Kodi crashes when switching from AVC encoded video to HEVC 10-bit video (the crash happens immediately when I start playing HEVC-10 video). Those crashes are easily reproducible and I believe the last good build is #0912 (I can reproduce the issue with #0913 and newer and can't reproduce with #0912 and older.).
I can reproduce. Looks like the async open means that second file starts while first is still playing.
The issue is advanced deinterlace uses the QPUs. So does HEVC decode and we are getting a deadlock.
I suspect that disabling deinterlace (or switching from advanced to bob) will work around the issue for now.
I'll try to find a proper solution.
Looks like this is fixed in build #1203.
However, it still crashes if I skip forward to the next video (e.g. from interlaced AVC to progressive HEVC-encoded video). This is not related to async open, this issue was present before build #0913. No crashes if I turn off advanced deinterlacing.
New LibreELEC.tv Leia build #1204: RPi / RPi2
SHA256 Checksum: 74a5ca99dfd57cf370f043cb79682bc4497ee896d02c0d281ac33bc4c756c686 (RPi)
SHA256 Checksum: 3d282236edb3da7f4700a4b1de7434f4712ee8731ce2a00bf7eb8aea2758642b (RPi2)
# uname -a
Linux rpi512 4.14.3 #1 Mon Dec 4 21:06:39 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec  1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171204210529-#1204-g0cb2a40 [Build #1204]
# Kodi version
(18.0-ALPHA1 Git:02c0008). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (0cb2a40, changelog) and tip of XBMC master (02c0008, changelog) with the following modifications: Build Highlights:
  1. [PVR][Estuary] radio recordings fix + improvement
Build Details:
  1. LibreELEC.tv:
    • init: fix offset calculation after busybox fdisk change (PR:2287, 1 commit, 1 file changed)
  2. XBMC:
    • VideoCodecDRMPRIME: fix end-of-file loop (PR:13132, 1 commit, 1 file changed)
    • [PVR][Estuary] radio recordings fix + improvement (PR:13129, 2 commits, 2 files changed)
    • [win32] force resize on CreateNewWindow (PR:13134, 1 commit, 1 file changed)
    • [linux][gbm] cleanup, fixes, and atomic prep (PR:13100, 9 commits, 12 files changed)
Weekly Linux 4.15-rc1 build #1204x: RPi / RPi2
DO NOT USE IF YOU DEPEND ON THE FOLLOWING WIFI DRIVERS!
Packages disabled:
RTL8188EU
RTL8189FS
RTL8192CU
RTL8192DU
RTL8192EU
RTL8812AU
New LibreELEC.tv Leia build #1205: RPi / RPi2
SHA256 Checksum: f28fc4028e6afbb0ab115b60ea3f0fa7ae22d34e7372bf08333e15ef79daf20a (RPi)
SHA256 Checksum: 781e26ffad8f82a9472d96aff9b63e9a4d41fa692b566186a3ee321197e23050 (RPi2)
# uname -a
Linux rpi512 4.14.4 #1 Tue Dec 5 21:05:05 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec  1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171205210407-#1205-gf279603 [Build #1205]
# Kodi version
Based on tip of LibreELEC.tv master (f279603, changelog) and tip of XBMC master (02c0008, changelog) with the following modifications: Build Highlights:
  1. New 4.14.4 kernel
Build Details:
  1. LibreELEC.tv:
    • Docker update to 17.10 (PR:2179, 2 commits, 12 files changed)
  2. kernel 4.14.y:
    • New commits in this build:
      • lan78xx: Enable LEDs and auto-negotiation (c9a72c9f)
      • thermal: enable broadcom menu for arm64 bcm2835 (343df183)
      • pwm: Set class for exported channels in sysfs (d47bf375)
    • Commits no longer in build:
      • hid: Reduce default mouse polling interval to 60Hz (90e38e27)
      • raspberrypi-firmware: Define the MBOX channel in the header. (63061887)
      • overlays: add gpio-ir-tx and pwm-ir-tx (b3defb65)
      • dwc_otg: Fixup change to DRIVER_ATTR interface (d6600722)
      • GPIO and gpio-poweroff clarifications (bb83dc0b)
      • ARM: dts: Swap serial aliases for BT-enabled Pis (a2397237)
      • bcm2710: Refactor bcm2710.dtsi using bcm2837.dtsi (#2236) (4fa846a4)
      • bcm2710: Fix compatible string in bcm2710.dtsi (eb2835ad)
      • BCM270X_DT: Add PaPiRus overlay (d7b69a5f)
      • BCM2708_DT: Undo downstream changes to upstream dtsis (2779c941)
      • dwc_otg: Fix compilation warnings (68506903)
      • BCM_VC_SM: select DMA_SHARED_BUFFER (08069cb9)
      • USB_DWCOTG: Disable building dwc_otg as a module (#2265) (943bd28a)
      • allo-piano-dac-plus: Master volume added + fixes (4cc6b882)
      • allo-digione: 192kHz clicking sound fix (cd7cebdc)
      • Fixed a bug when using 352.8kHz sample rate (12876877)
      • ARM: dts: Add fake CTS signal to pi3-miniuart-bt (962ca9bc)
      • overlays: i2c-rtc: add m41t62 (e1fc064e)
      • BCM270X_DT: Set spidev spi-max-frequency to 125MHz (15eb0ac7)
      • Revert "hid: Reduce default mouse polling interval to 60Hz" (353618da)
      • Include tsl4531, veml6070 and hdc100x dtoverlay (#2252) (a907e617)
      • lan78xx: Enable LEDs if no valid EEPROM or OTP (e3bafbdd)
      • enable sht3x module in kernel, add sht3x definition to i2c-sensor dts definition (#2282) (d055ee99)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [env] PR:2242 (perma): linux: update to linux-4.14.4
build #1205 RPi2
an xvid file is asynchronous, while the video is often played faster and then jerky
however, the file will play normally under Windows (Zoom Player)
File info : https://pastebin.com/Ad0Yxx5G
(2017-12-06, 19:37)Malocher Wrote: build #1205 RPi2
It would help if you could determine when it started behaving like this.
 When? All through the movie, every minute..The movie runs very fast for a short time and then is in sync again
He means what build #, if you update every day the it should be easy to determine when it happened. However, if you update once a month go back through builds and try until you find the build it broke.
Sent from my iPhone
HTPC(s): All running LibreELEC
  • AMD 2200G APU on Gigabyte AB350N-Gaming WIFI-CF
  • RPI3 x2 | RPI2 x2
NAS: FreeNAS (Latest Stable) | NFS/CIFS
New LibreELEC.tv Leia build #1206: RPi / RPi2
SHA256 Checksum: 1e42860c2c2261c5d6058043146921b5511da25d19baa33ef0803ae67601f3b3 (RPi)
SHA256 Checksum: a710872d8c2c153ff45fc40442b961e02919fcf51d6dc7c03aae796a1390e0e7 (RPi2)
# uname -a
Linux rpi512 4.14.4 #1 Wed Dec 6 21:04:25 GMT 2017 armv6l GNU/Linux
# vcgencmd version
Dec  1 2017 16:20:32
# lsb_release
LibreELEC (Milhouse): devel-20171206210316-#1206-g7e07b2f [Build #1206]
# Kodi version
(18.0-ALPHA1 Git:6db0579). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (7e07b2f, changelog) and tip of XBMC master (6db0579, changelog) with the following modifications: Build Highlights:
  1. Reintroduce media_tree (hauppauge, crazycat) drivers - see video detailing how you enable various drivers. Xbox dvb-t2 is included.
  2. Allow root password to be changed - use "passwd" command at ssh prompt and enter new password
Build Details:
  1. LibreELEC.tv:
    • multimedia-tools: squeezelite: support all possible media formats (PR:2289, 1 commit, 3 files changed)
    • go: cleanup (PR:2291, 1 commit, 1 file changed)
    • linux: update to linux-4.14.4 (PR:2242, 14 commits, 10 files changed)
    • busybox: allow changing root password (PR:2284, 1 commit, 4 files changed)
  2. XBMC:
    • [PVR] Global direct channel number input & global unique channel numbers (PR:13135, 3 commits, 4 files changed)
  3. vfs.libarchive:
    • changed: disable rar support (8fa085e)
  4. Additional commits/pull requests/changes not yet merged upstream:
Looks like there is a serious GUI performance bug that seem to be triggered by enabling/disabling Teletext.
I noticed that Kodi's sliding menus are sometimes not smooth, especially when watching a live TV and this can only be fixed by restarting Kodi/reboot.
I tried to find a way to reliably reproduce this issue and found out that the "jerkiness" appear when I enable and then disable teletext.
  • 252
  • 253
  • 254(current)
  • 255
  • 256
  • 495
LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)24
