  • 317
  • 318
  • 319(current)
  • 320
  • 321
  • 495
v18 LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)
(2018-03-14, 12:42)Pienoet Wrote: @Milhouse and @popcornmix i ordered today the new raspberry pi 3b+ model will your testbuilds compatible out of the box with this new model?
Look 3 posts above yours.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Sorry man i looked over that but thanks!
(2018-03-13, 22:39)Milhouse Wrote:
(2018-03-13, 19:21)doldi Wrote: With #312 i a have yet the problem on my rpi3 and also on a rpi2 with the mouse => scrolling in a big folder and select something is absolutly impossible, also in the skin.
The scrollbar (video/audio) is moving/shifting if i touch the mouse.
Harald
edit: back to 8.2.3 and this all will work fine on both pi.
I'll drop the libinput changes.
Thank You very much milhouse - works fine now.
hi question regarding New Raspberry PI 3 B+ can you test 1080p Netflix is it running smoothly ? Because now RPI3 with slight OC to 1350 is able to run only 720p.
(2018-03-14, 22:10)mateuzzz Wrote: hi question regarding New Raspberry PI 3 B+ can you test 1080p Netflix is it running smoothly ? Because now RPI3 with slight OC to 1350 is able to run only 720p.
Netflix (and all widevine-related) decode is an entirely software process, limited by the CPU speed, and unfortunately the Pi3+ - even with the bump to 1400Mhz- is just not able to decode 1080p@24fps using the ARM alone. It can almost do it, but not quite (slight audio sync issues, so it's not "smooth"). Stick with 720p even on the Pi3+ for now if you want "smooth" Netflix playback.
 OK, so no upgrade for me to B+ will stick with Raspberry PI 3 and 720p .
New LibreELEC.tv Leia build #0314: RPi / RPi2
(Supercedes previous build)
SHA256 Checksum: e821829c3185aa3b36ec7d8ad29b19b95f77746db29125c63336e5b913f57f7c (RPi)
SHA256 Checksum: be3e3cca9f031cbf15fb93477d9b33460da404a8b7184282faec48850df5ac27 (RPi2)
text:
# uname -a
Linux rpi512 4.14.26 #1 Wed Mar 14 21:05:12 GMT 2018 armv6l GNU/Linux
# vcgencmd version
Mar 14 2018 16:55:36
Copyright © 2012 Broadcom
version 5afe871e8e58f66e0a39531895d09ed692893267 (clean) (release)
# lsb_release
LibreELEC (Milhouse): devel-20180314210257-#0314-g035d69e [Build #0314]
# Kodi version
(18.0-ALPHA2 Git:258cf89). Platform: Linux ARM 32-bit
Based on tip of LibreELEC.tv master (035d69e, changelog) and tip of XBMC master (46058c5, changelog) with the following modifications: Build Highlights:
  1. New firmware (Pi3+/Pi0W conditional filters, Pi3+ dt-blob)
  2. New 4.14.26 kernel
  3. Update to Samba 4.8.0
  4. Avoid unncecessary DB access by GUI on update Item
Build Details:
  1. Firmware (Mar 14):
    • firmware: ldconfig: Support Pi3+ and Pi0W sections
    • firmware: platform: Update firmware dt-blob for pi3+
  2. LibreELEC.tv:
    • samba: update to samba-4.7.6 (PR:2582, 1 commit, 1 file changed)
    • kodi: mid-March update (PR:2565, 3 commits, 27 files changed)
  3. XBMC:
    • [videoplayer][pvr] Remove deprecated IDispTime from CDVDInputStreamPV (PR:13645, 2 commits, 6 files changed)
    • Add support for scanning AVI files (PR:13646, 1 commit, 3 files changed)
    • Avoid unncecessary DB access by GUI on update Item (PR:13640, 1 commit, 3 files changed)
  4. inputstream.rtmp:
    • [debian] fix dbg package generation and build on ubuntu 18.04 (PR:36, 1 commit, 1 file changed)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [env] PR:2585 (perma): linux: update to linux-4.14.30
    • Added: [env] PR:2586 (perma): samba: update to samba-4.8.0
    • Added: [env] PR:2587 (perma): brcmfmac_sdio-firmware-rpi: cleanup wlan-firmware
Would have f2fs filesystem any benefit on rpi builds? Better performance/lifetime of sdcards?
I have tested your latest build #0314, with an overclocked Pi 3 and high data rate h265 video files, all looks great, no crashes or memory problems.
I still have MALLOC_MMAP_THRESHOLD_=16384 set in mmap_threshold.conf is this still being used? what is the built in defalt now?
Thanks,
Kevin.
I should get new Pi3 B+ today some time (ordered it yesterday) Smile
Any recommended settings for new Pi3 B+ to get the most out of HEVC?
Any Pi version specific section in configuration file like [pi2]...[pi3] when moving SD chip around?
Maybe [pi3+]...?
[pi2]
arm_freq=1000
gpu_freq=400
over_voltage=4
force_turbo=1
sdram_freq=600
over_voltage_sdram=5
sdram_schmoo=0x02000020
[pi3]
arm_freq=1300
gpu_freq=500
over_voltage=4
force_turbo=1
sdram_freq=580
[pi3+]  Huh
(2018-03-15, 19:31)3DBuff Wrote: Any recommended settings for new Pi3 B+ to get the most out of HEVC?
Maybe [pi3+]...?
Yes - that was added in last night's build. Be aware that both [pi3] and [pi3+] sections apply to a pi3+,
so keep the [pi3+] section last.
I think you'll find without overclocking the Pi3+ will play almost all 1080p30 hevc content just fine,
but feel free to experiment if you want to push it further.
Be aware that setting over_voltage higher that default can generate more temperature and hence cause throttling,
so try without aggressive overclocks first to be sure the overclock is helping.
Thanks for the [Pi3+] info.
(2018-03-15, 19:23)bleep42 Wrote: I still have MALLOC_MMAP_THRESHOLD_=16384 set in mmap_threshold.conf is this still being used? what is the built in defalt now?
No you can delete that now, we're using a default of 8192 for all arm devices now. I'm not sure if 8192 contributes to the difficulties producing crashlogs with gpu_mem=320 - it's something I mean to investigate.
(2018-03-15, 11:17)polo_joe Wrote: Would have f2fs filesystem any benefit on rpi builds? Better performance/lifetime of sdcards?
ext4 vs f2fs benchmarks here: https://www.phoronix.com/scan.php?page=a...5-fs&num=2
f2fs performs slightly better than ext4 (but also much worse in some tests), and the results don't really justify replacing ext4 with f2fs IMHO.
I can't really say if f2fs results in improved lifetime of sd cards compared with ext4.
Maybe [pi3+]...?
 What would be default set for Pi3+ if it reads both sets [pi3] and [pi3+] not to overclock or change anything?
Any default set of parameters?
[pi3]
arm_freq=1300
gpu_freq=500
over_voltage=4
force_turbo=1
sdram_freq=580
[pi3+]
arm_freq=1400
  • 317
  • 318
  • 319(current)
  • 320
  • 321
  • 495
LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)24
