20 Nov 2019 - TVDB Scraper v3.2.0 is now available which reinstates scraping. TVDB are still in the process of fixing a number of bugs so there may still be further breakages. See this post. 2901570 (post)
  • 17
  • 18
  • 19(current)
  • 20
  • 21
  • 355
  Thread Closed
v18 LibreELEC Testbuilds for x86_64 (Kodi 18.0)
New LibreELEC.tv Krypton build #0107: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.9.1 #1 SMP Sat Jan 7 21:37:25 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170107213606-#0107-gc7cd1d4 [Build #0107]
# Kodi version
(18.0-ALPHA1 Git:5c40b5c). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (c7cd1d4a, changelog) and tip of XBMC master (2b073a7e, changelog) with the following modifications: Build Highlights:
  1. New 4.9.1 kernel
  2. Minor libcec and libnfs updates
Build Details:
  1. LibreELEC.tv:
    • settings: update githash for 0.8.7 (PR:1144, 1 commit, 1 file changed)
    • repo: correct minimum add-on version for ls.io repo (PR:1145, 1 commit, 1 file changed)
  2. XBMC:
    • Replace raw new/delete in Util with stack object (PR:11387, 1 commit, 1 file changed)
    • Add python scrapers (PR:9984, 3 commits, 13 files changed)
    • App Name for Windows OS is not reflected at APPDATA directory. (PR:11085, 1 commit, 1 file changed)
    • [cmake/win32] Don't use system wide installed dependencies (PR:11246, 1 commit, 1 file changed)
    • [Android] disable zeroconf (PR:11393, 1 commit, 1 file changed)
  3. libcec:
    • Install pkgconfig in arch-specific dir (PR:284, 1 commit, 1 file changed)
  4. libnfs:
    • Revert "socket: batch pdu read in function rpc_read_from_socket" (PR:162, 1 commit, 1 file changed)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1146: linux: update to linux-4.9.1
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2017-01-04, 23:26)Milhouse Wrote: You'll then need to remove the current patch for the nvidia-legacy package as the current patch is for 340.101. Not sure if the 304 driver needs any patches to build with the 4.9 kernel - hopefully not, but if so you'll need to add them in the patches folder.
just FYI - mtrr patch needs for 304 legacy drivers and recent kernel
https://forum.libreelec.tv/thread-3523-p...l#pid27187
Nvidia Shield
kodi 18.1 RC1
New LibreELEC.tv Krypton build #0108: Generic
# uname -a
Linux NUC 4.9.1 #1 SMP Sun Jan 8 21:03:32 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170108210211-#0108-g9e4c5ea [Build #0108]
# Kodi version
Based on tip of LibreELEC.tv master (9e4c5ea8, changelog) and tip of XBMC master (ec07c1dc, changelog) with the following modifications: Build Highlights:
  1. Include media_build
  2. fluxbox: start applications maximized by default
  3. move back to DRI2
Build Details:
  1. LibreELEC.tv:
    • media_build for Generic and RPi (PR:1138, 6 commits, 12 files changed)
    • linux: update to linux-4.9.1 (PR:1146, 2 commits, 5 files changed)
    • fluxbox: start applications maximized by default (PR:1142, 1 commit, 2 files changed)
    • move back to DRI2 (PR:1093, 2 commits, 2 files changed)
    • scripts/create_addon: use PKG_REV as part of the binary addon version (PR:1025, 1 commit, 1 file changed)
  2. XBMC:
    • Replace raw new/delete inside CDVDFactorySubtitle (PR:11396, 3 commits, 14 files changed)
    • spelling: acquire (PR:11363, 1 commit, 4 files changed)
    • Replace raw new/delete with unique_ptr in GUIWindowSlideShow (PR:11398, 1 commit, 2 files changed)
  3. pvr.hts:
    • Don't reconnect immediately on register error (PR:274, 2 commits, 4 files changed)
How to add Games menu in home screen like Irusak builds?
(2017-01-09, 19:38)vali Wrote: How to add Games menu in home screen like Irusak builds?
Modify skin I believe
14 years using XBMP, XBMC and Kodi! :)
Try the Konami Code... works best with a keyboard or joystick. Smile
Took a couple trys but it does work! Big Grin
"PPC is too slow, your CPU has no balls to handle HD content." ~ Davilla
"Maybe it's a toaster. Who knows, but it has nothing to do with us." ~ Ned Scott
Hi Milhouse,
long time ago i reported kodi does instantly crash if i do an instant record in live tv with the option "ask what to do" in pvr settings.
Today i got some time and setup libreelec from scratch. in the first time of testing all works fine,but after a while the bug comes back.
Now i got the trick -> it's the language setting. if i set libreelec to english language all works fine -> choose german language in regional settings and the nice "ask what to do" option in pvr setting crashes kodi if you want to use it.
(2017-01-10, 02:13)schlumpfschlaubi Wrote: Hi Milhouse,
Can you upload your crashlog (see note #4 in the OP)
kodi.log
http://sprunge.us/NZFC
dmesg | pastebinit
http://sprunge.us/HTbM
journalctl -a | pastebinit
http://sprunge.us/SjFb
i did trigger instant record at 01:43:10
it also happens in other languages, for example french. only with english language i get the "instant recording action" windows instead of a crash
(2017-01-10, 02:51)schlumpfschlaubi Wrote: kodi.log
dmesg | pastebinit
Thanks. Hopefully a PVR developer can look into it.
@pvrdevelopers - if a debug-enabled crashlog would help, please shout and I'll get one uploaded so that schlumpfschlaubi can hopefully re-test.
New LibreELEC.tv Krypton build #0109: Generic
# uname -a
Linux NUC 4.9.2 #1 SMP Tue Jan 10 02:22:58 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170110022138-#0109-gf8d7242 [Build #0109]
# Kodi version
Based on tip of LibreELEC.tv master (f8d7242e, changelog) and tip of XBMC master (fa383a18, changelog) with the following modifications: Build Highlights:
  1. New 4.9.2 kernel
  2. Bump GUI ABI - this will break backward compatability with skins
Build Details:
  1. LibreELEC.tv:
    • RBP: enable SND_BCM2708_SOC_HIFIBERRY_AMP (PR:1151, 1 commit, 4 files changed)
    • imx6: update kodi patch (fix partially broken deinterlace) (PR:1152, 1 commit, 1 file changed)
  2. XBMC:
    • [gui] Bump GUI version ABI as we start to break backwards compatibility. (PR:11306, 2 commits, 4 files changed)
    • spelling: json (PR:11403, 1 commit, 2 files changed)
    • spelling: output (PR:11402, 1 commit, 7 files changed)
    • [PVR] PVRMananger::m_currentFile: CFileItem* -> CFileItemPtr. (PR:11397, 1 commit, 2 files changed)
    • [cmake] fixes cpack dependency list generation (PR:11370, 2 commits, 17 files changed)
    • spelling: paths (PR:11401, 1 commit, 1 file changed)
    • spelling: strings (PR:11406, 1 commit, 2 files changed)
    • spelling: DestroyDispmanxWindow (#11365) (2f1c47c9)
  3. pvr.hdhomerun:
    • Use correct channel number parsed from GuideNumber (PR:32, 0 commits, 0 files changed)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1153: linux: update to linux-4.9.2
Weekly Linux 4.10-rc3 build #0109x: Generic
Same as #0109, but without media_build extensions (not compatible with this kernel).
dmesg | pastebinit
This is actually a translation bug. The resource string was not translated correctly, interestingly for both German (de_DE) and French (fr_FR). All other languages I checked are okay. For German language I just fixed this in Transifex. For French I do not have the needed access priviledges. My fix will be avaliable with next Transifex update for Kodi.
Many thanks @ksooo!
  • 17
  • 18
  • 19(current)
  • 20
  • 21
  • 355
  Thread Closed
  • 24 Vote(s) - 4.5 Average
LibreELEC Testbuilds for x86_64 (Kodi 18.0)4.524
