  • 32
  • 33
  • 34(current)
  • 35
  • 36
  • 355
  Thread Closed
v18 LibreELEC Testbuilds for x86_64 (Kodi 18.0)
(2017-02-21, 05:27)khaoohs Wrote: Harmony remote stopped working build #0220.
http://sprunge.us/Ydgj
Seems to work fine here with my Harmony Elite.
New LibreELEC.tv Leia build #0221: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.10.0 #1 SMP Tue Feb 21 21:18:36 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170221211717-#0221-ga1d6251 [Build #0221]
# Kodi version
(18.0-ALPHA1 Git:4c792db). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (a1d6251d, changelog) and tip of XBMC master (755d7db3, changelog) with the following modifications:
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (0a97062d, ahead +22)
  • Includes latest libnfs master (2e0a67fc, ahead +49)
  • Includes latest p8-platform master (2d90f986, ahead +9)
  • Includes latest addons: inputstream.adaptive (a347296e), inputstream.rtmp (df64b9b2, +6), peripheral.joystick (69c9e5fe, +1), pvr.argustv (5a36c586), pvr.demo (8243935f), pvr.dvblink (0015079e), pvr.dvbviewer (9fb34b3c), pvr.filmon (315e5034), pvr.hdhomerun (98cb8d40), pvr.hts (1caa390d, +1), pvr.iptvsimple (53d63cce), pvr.mediaportal.tvserver (019c7e99), pvr.mythtv (18fe56e4, +11), pvr.nextpvr (cb1b5415), pvr.njoy (080cd321), pvr.octonet (8549a31c), pvr.pctv (e67e9695), pvr.stalker (a609149c), pvr.vbox (dea8335a), pvr.vdr.vnsi (7033621d), pvr.vuplus (6ff2eb28), pvr.wmc (5f1db43f)
  • Exclude [env] kodi-999.99-PR11662.patch: kodi: merged upstream
  • Include [env] afbd134f: linux: Enable Fair Queue packet scheduling (TEST)
  • Include [env] e533a8be: linux: Default to CONFIG_TCP_CONG_BBR (TEST)
  • Include [env] patch: ffmpeg: add extra RPi lib required when building ffmpeg command line with gpu service hevc patches
  • Include [env] patch: repository.retroplayer.libreelec.addons: add temp repo for testing
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: iwlwifi-firmware: update to iwlwifi-firmware-ba301aa
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: linux: enable in-tree rtl8192cu for RPi/RPi2
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] PR:1121: linux: update to linux-4.10.0
  • Include [env] PR:1287: virtio-gpu support (qemu/kvm)
  • Include [env] PR:1326: Build system scripts cleanup
  • Include [env] PR:1329: imagedecoder.raw: add add-on
  • Include [env] PR:1355: xorg-server: clean package when nvidia drivers are bumped
  • Include [env] PR:1365: build system: switch to absolute paths
  • Include [env] PR:1379: projectM: remove glew [LE9]
  • Include [pkg] patch: alsa-lib: conf: Add card config for Intel HDMI/DP LPE audio (alsa-lib)
  • Include [pkg] PR:56: bluetooth: add missing 'Connect' option when device is Trusted (service.libreelec.settings)
  • Include [pkg] PR:11668: FFmpegImage: Document and change alignment
  • Include [pkg] PR:11702: [Fix] Songs smart playlists 3 x slower than similar library node
Build Highlights:
  1. Search backwards for keyframe when resuming playback
Build Details:
  1. XBMC:
    • [addons] update Chorus (PR:11717, 1 commit, 16 files changed)
    • Search backwards for keyframe when resuming playback (PR:11713, 1 commit, 1 file changed)
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Can you provide more detail - has it stopped working completely, ie. you have no buttons working, or is it just button repeat that is not working? Can you confirm if 4.10-rc8 and 4.10-rc7 better/worse/same.
The button repeat issue is being caused by the media_build package, which I may drop from future builds until we have an updated version that doesn't break other features (ie. lirc).
New LibreELEC.tv Leia build #0222: Generic
# uname -a
Linux NUC 4.10.0 #1 SMP Wed Feb 22 21:59:11 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170222215751-#0222-ga1d6251 [Build #0222]
# Kodi version
Based on tip of LibreELEC.tv master (a1d6251d, changelog) and tip of XBMC master (e94a5d90, changelog) with the following modifications:
Build Highlights:
  1. Temporarily drop media_build package (remote control issues)
Build Details:
  1. XBMC:
    • [Fix] Songs smart playlists 3 x slower than similar library node (PR:11702, 1 commit, 1 file changed)
    • [EPG] Trac 17323: Guide window fixes (PR:11705, 2 commits, 4 files changed)
    • [estouchy] player process info (PR:11718, 1 commit, 4 files changed)
    • [cleanup] remove some old xbox references (PR:11711, 1 commit, 3 files changed)
    • [Fix]REMIXER tag as alternative to MIXARTIST for FLAC and APE tags (PR:11725, 1 commit, 1 file changed)
    • [Darwin] Separate Apple Remote settings into new group (PR:11692, 1 commit, 4 files changed)
    • Input improvements (PR:11688, 6 commits, 11 files changed)
Any better with #0222?
Can you post "journalctl -a | pastebinit" and "dmesg | pastebinit" from #0220.
Also, I assume you never tested any of the previous weekly 4.10-rc builds - is your Harmony (most likely lirc) functioning in 4.10-rc8? 4.10-rc7? Etc.
4.10-rc8: 2525501 (post)
4.10-rc7: 2518444 (post)
4.10-rc6: 2512663 (post)
4.10-rc5: 2508477 (post)
4.10-rc3: 2497349 (post)
No, i have not tried any of the 4.10 rc builds.
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/hDQA
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/bBYi
LibreELEC:~ # pastebinit .kodi/temp/kodi.log
http://sprunge.us/SVZK
I have a harmony one and a harmony elite, neither works with build 220. Meaning there is nothing happening when pressing buttons.
Thank you for rebuilding projectM.
(2017-02-23, 00:32)khaoohs Wrote: I have a harmony one and a harmony elite, neither works with build 220. Meaning there is nothing happening when pressing buttons.
Please try #0222 - hopefully that restores functionality.
Must replace my Asus Chromebox due to wierd EDID HDMI Handshake Problems. Is Libreelec running well on the J3160 Celeron Boxes like the Beebox J3160Huh My Setup is 1080p only. No 4k, no HEVC. Huh
Yes, my remote works again.
(2017-02-23, 01:31)john.cord Wrote: Must replace my Asus Chromebox due to wierd EDID HDMI Handshake Problems. Is Libreelec running well on the J3160 Celeron Boxes like the Beebox J3160Huh My Setup is 1080p only. No 4k, no HEVC. Huh
I have n3150 version and works perfectly (Like chromebox i have randomly black screen after libreelec logo due to kernel/intel driver bug)
which is your problem of hdmi handshake ? after resume ?
New LibreELEC.tv Leia build #0223: Generic
# uname -a
Linux NUC 4.10.0 #1 SMP Thu Feb 23 22:47:30 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20170223224610-#0223-g0d24524 [Build #0223]
# Kodi version
Based on tip of LibreELEC.tv master (0d24524c, changelog) and tip of XBMC master (cecf1791, changelog) with the following modifications:
  • Include [env] PR:1387: buildsystem: Create unpack stamps for packages without sources
  • Revert [pkg] PR:11732: [xbmc][fix][win32] Add utf8 support to freetype to fix libass font issues (Reason: Not needed, causes conflict with newclock5)
Build Highlights:
  1. Estuary Sync pt1
  2. Reintroduce media_build package (same version as LE8 - 2017-01-22 - now patched for 4.10 kernel)
Build Details:
  1. LibreELEC.tv:
    • imx6: update kodi patch (stop/resume streams on OnLostDisplay/OnReset… (PR:1385, 1 commit, 1 file changed)
    • build system: switch to absolute paths (PR:1365, 6 commits, 138 files changed)
    • imx6: update kodi patch for kodi 18 (PR:1388, 1 commit, 1 file changed)
  2. XBMC:
    • [PVR][guiinfo][Estuary] Recordings window: Introduce a content view filter (PR:11704, 1 commit, 8 files changed)
    • [linux] prevent wasting RAM due to memory fragmentation (PR:11722, 1 commit, 1 file changed)
    • Fix memory and resource leak (PR:11687, 3 commits, 3 files changed)
    • AESinkPULSE: Avoid deadlock (PR:11728, 1 commit, 1 file changed)
    • [estuary] Sync pt1 (PR:11727, 2 commits, 639 files changed)
    • [xbmc][fix][win32] Add utf8 support to freetype to fix libass font issues (PR:11732, 1 commit, 1 file changed)
    • properly exclude musicbrainz timeout for python scrapers (PR:11720, 1 commit, 1 file changed)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:1387: buildsystem: Create unpack stamps for packages without sources
    • Reverted: [pkg] PR:11732: [xbmc][fix][win32] Add utf8 support to freetype to fix libass font issues (Reason: Not needed, causes conflict with newclock5)
How is it with #0223?
Harmony button repeat is fine for me with this version of media_build.
Hello compliments for their work, I use your version for a long time, I have only one problem that I have always found unlike the official version of libreelec, with the official version addon as stream on demand or other addon video when I watch a video is marked as seen with your version remains unmarked, there is some specific settings? thank you
(2017-02-24, 02:30)flaflasat Wrote: Hello compliments for their work, I use your version for a long time, I have only one problem that I have always found unlike the official version of libreelec, with the official version addon as stream on demand or other addon video when I watch a video is marked as seen with your version remains unmarked, there is some specific settings? thank you
No special setting that I'm aware of. These builds are based on Kodi 18 while the official release is Kodi 17. Can you identify when this problem started (go back through the builds until you find the last build which correctly marks watched videos as watched).
Also try testing with a "clean" .kodi directory in case it's a corrupted add-on or setting:
systemctl stop kodi
mv /storage/.kodi /storage/.kodi.bak
reboot
and then re-test, if necessary add your add-ons. Once your testing is complete you can restore your original Kodi as follows:
systemctl stop kodi
rm -fr /storage/.kodi
mv /storage/.kodi.bak /storage/.kodi
reboot
Settings page is broken in build #0223 (see this post for details).
  • 32
  • 33
  • 34(current)
  • 35
  • 36
  • 355
  Thread Closed
  • 24 Vote(s) - 4.5 Average
LibreELEC Testbuilds for x86_64 (Kodi 18.0)4.524
