With new #0712 Amazon VOD is working again. Also the audio sync issue seems to be fixed with this build - great!!
To get the Netflix plugin working again, i had to disable the Dolby Sound option in Netflix plugin settings.
Does anyone know the last nightly that had retroplayer working? As of now it still gives the dependency error any time you try to start it.
Milhouse
Retired Team-Kodi Member
Is anyone else seeing the colour blue swapped for the colour red in Amazon and Netflix streams since #0711? I'm seeing this on Skylake NUC and ION2 - fine on RPi3.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
No issues with Adjust display to refresh rate set to always on the Z8350 and have tried many files of different flavours, each of which plays without issue.
