  • 124
  • 125
  • 126(current)
  • 127
  • 128
  • 355
v18 LibreELEC Testbuilds for x86_64 (Kodi 18.0)
Weekly Linux 4.14-rc2 build #0926x: Generic
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Hi Milhouse,
What about my issue with playback freeze ?
01:55:53.563 T:140480115408192  NOTICE: VideoPlayer::OpenFile: smb://NAS/video/Films/Spider-Man - Homecoming (2017).mkv
01:55:53.563 T:140477329798912  NOTICE: Creating InputStream
01:55:53.701 T:140477329798912  NOTICE: Creating Demuxer
01:55:53.751 T:140477329798912  NOTICE: Opening stream: 0 source: 256
01:55:53.751 T:140477329798912  NOTICE: Creating video codec with codec id: 28
01:55:53.751 T:140477329798912  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
01:55:53.751 T:140477329798912  NOTICE: Creating video thread
01:55:53.751 T:140477329798912  NOTICE: Opening stream: 1 source: 256
01:55:53.752 T:140477329798912  NOTICE: Finding audio codec for: 86018
01:55:53.752 T:140477271049984  NOTICE: running thread: video_thread
01:55:53.752 T:140477329798912  NOTICE: Creating audio thread
01:55:53.752 T:140479476041472  NOTICE: running thread: CVideoPlayerAudio::Process()
01:55:53.773 T:140479476041472  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
01:55:53.773 T:140478280349440  NOTICE: COutput::OnStartup: Output Thread created
01:55:53.796 T:140480115408192  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
01:55:53.804 T:140480115408192  NOTICE: GL: NPOT texture support detected
01:55:53.804 T:140480115408192  NOTICE: GL: Using GL_ARB_pixel_buffer_object
01:55:53.804 T:140480115408192  NOTICE: Using GL_TEXTURE_2D
01:55:53.813 T:140480115408192  NOTICE: Display resolution ADJUST : HDMI2: 1920x1080 @ 23.98Hz (24) (weight: 0.000)
01:55:53.813 T:140480115408192  NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
01:55:54.061 T:140480115408192  NOTICE: VideoPlayer: OnLostDisplay received
01:55:54.188 T:140480115408192  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
01:55:54.195 T:140480115408192  NOTICE: GL: NPOT texture support detected
01:55:54.195 T:140480115408192  NOTICE: GL: Using GL_ARB_pixel_buffer_object
01:55:54.195 T:140480115408192  NOTICE: Using GL_TEXTURE_2D
01:55:54.216 T:140480115408192  NOTICE: VideoPlayer: OnLostDisplay received
01:55:54.310 T:140480115408192  NOTICE: VideoPlayer: OnResetDisplay received
01:55:54.324 T:140480115408192  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
01:55:54.332 T:140480115408192  NOTICE: GL: NPOT texture support detected
01:55:54.332 T:140480115408192  NOTICE: GL: Using GL_ARB_pixel_buffer_object
01:55:54.332 T:140480115408192  NOTICE: Using GL_TEXTURE_2D
01:55:54.429 T:140477271049984  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727
02:10:12.941 T:140479476041472  NOTICE: CVideoPlayerAudio::Process - stream stalled
02:10:25.749 T:140480115408192  NOTICE: CVideoPlayer::CloseFile()
02:10:25.749 T:140480115408192  NOTICE: VideoPlayer: waiting for threads to exit
02:10:26.363 T:140477271049984 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
02:10:34.590 T:140477329798912 WARNING: Previous line repeats 155 times.
02:10:34.590 T:140477329798912   ERROR: Read - Error( -1, 110, Connection timed out )
02:10:34.590 T:140477329798912  NOTICE: CVideoPlayer::OnExit()
02:10:34.590 T:140477329798912  NOTICE: Closing stream player 1
02:10:34.591 T:140477329798912  NOTICE: Waiting for audio thread to exit
02:10:34.591 T:140479476041472   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
02:10:34.591 T:140479476041472  NOTICE: thread end: CVideoPlayerAudio::OnExit()
02:10:34.591 T:140477329798912  NOTICE: Closing audio device
02:10:34.598 T:140477271049984 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
02:10:34.610 T:140477329798912  NOTICE: Deleting audio codec
02:10:34.610 T:140477329798912  NOTICE: Closing stream player 2
02:10:34.610 T:140477329798912  NOTICE: waiting for video thread to exit
02:10:34.649 T:140477271049984  NOTICE: thread end: video_thread
02:10:34.649 T:140477329798912  NOTICE: deleting video codec
02:10:44.650 T:140478280349440 WARNING: COutput::StateMachine - signal: 3 form port: timer not handled for state: 2
02:10:57.280 T:140480115408192 WARNING: Previous line repeats 1 times.
02:10:57.280 T:140480115408192  NOTICE: VideoPlayer: finished waiting
02:10:57.281 T:140480115408192  NOTICE: VAAPI::Close
02:10:57.281 T:140478280349440  NOTICE: COutput::OnExit: Output Thread terminated
02:10:57.281 T:140480115408192  NOTICE: VAAPI::Close - closing decoder context
02:10:57.282 T:140480115408192  NOTICE: CVideoPlayer::CloseFile()
02:10:57.282 T:140480115408192  NOTICE: VideoPlayer: waiting for threads to exit
02:10:57.282 T:140480115408192  NOTICE: VideoPlayer: finished waiting
02:10:57.290 T:140480115408192  NOTICE: CWinSystemX11::SetFullScreen - calling xrandr
02:10:57.812 T:140477363369728  NOTICE: WakeOnAccess [192.168.0.40] trigged by accessing : MySQL : MyVideos108
02:10:57.825 T:140477313013504  NOTICE: WakeOnAccess [192.168.0.40] trigged by accessing : MySQL : MyMusic67
02:10:57.833 T:140477363369728  NOTICE: WakeOnAccess success exit, server already running
02:10:59.153 T:140477321406208  NOTICE: Previous line repeats 1 times.
02:10:59.153 T:140477321406208   ERROR: NEWADDON Unknown Video Info Key "progress"
02:11:07.046 T:140480115408192   ERROR: Previous line repeats 10 times.
02:11:07.046 T:140480115408192  NOTICE: VideoPlayer::OpenFile: smb://NAS/video/Films/Spider-Man - Homecoming (2017).mkv
Same file on same path working fine with Kodi OSX build. Issue only on LibreELEC.
Here full log file :
https://pastebin.com/KmR5xUkh
 Estuary MOD V2
After hard reseting my system and bringing it back to same status level as before, everythings working like a charm but i couldnt get my imon vfd back to life....
Installed lcdprog (selected imon) and xbmclcdprog (like i did it before many times) but my vfd still stays completely black.
Anybody with any hints for me ---> http://sprunge.us/ACiS ?
(2017-09-27, 03:27)Guilouz Wrote: Hi Milhouse,
No idea, I just create these builds, I try not to add the bugs and it's generally not my responsibility to fix them.
When you originally posted about this I asked you for a debug log (wiki) which you failed to provide, and your log above is also not a debug log. You seem to have an issue providing what you've been asked for, maybe this is why your bug reports are eventually ignored?
I'll ask the question I often ask: which is the first build with this problem?
And if you would like to provide a link to your debug log (wiki) (please don't post log snippets to the forum) then maybe a developer will take an interest. Or open an issue on trac.kodi.tv.
(2017-09-27, 07:28)debutanker Wrote: After hard reseting my system and bringing it back to same status level as before, everythings working like a charm but i couldnt get my imon vfd back to life....
I would suggest starting a thread on the LibreELEC forum - I'm not sure what state the lcdproc add-on is in with regard to Kodi 18a1. Post "journalctl -a | pastebinit" in your thread as that might include useful information. You should also include your lcd config.
Will do - thanks @Milhouse!
New LibreELEC.tv Leia build #0927: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.13.3 #1 SMP Wed Sep 27 21:39:10 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170927213746-#0927-g195c4b1 [Build #0927]
# Kodi version
(18.0-ALPHA1 Git:aa4364c). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (195c4b1, changelog) and tip of XBMC master (aa4364c, changelog) with the following modifications:
  • Includes latest kodi-platform master (36fb493)
  • Includes latest libcec master (8adc786, ahead +26)
  • Includes latest libnfs master (3ba2a2c, ahead +101)
  • Includes latest p8-platform master (a822e19)
  • Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05, +1), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (48febd7, +3), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (12123dd, +1)
  • Include [env] 22775c5: include crazycat dvb drivers addon in image
  • Include [env] compare: dmidecode: initial package
  • Include [env] compare: kodi updates (ffmpeg-3.3.4)
  • Include [env] patch: RPi/RPi2: enable Broadcom WiFi debugging (see details)
  • Include [env] patch: libcec: don't link non-existant libtinfo
  • Include [env] patch: rev hack for kodi
  • Include [env] patch: tvheadend42: fix makefile patch
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.* and os.*
  • Include [env] patch: Add kodi binary addons (pvr, adsp, inputstream, vfs, other)
  • Include [env] patch: pvr addons: disable broken addons
  • Include [env] PR:1776: Don't cause system to hang on halt/reboot when net-booting
  • Include [env] PR:1791: nss/nspr: include in main image [rfc]
  • Include [env] PR:1835: add support for optional kernel modules in image and from addons
  • Include [env] PR:1978: linux: update to linux-4.13.4
  • Include [env] PR:2002: linux: include HBR and ELD fixes for Intel
  • Include [env] PR:2037: samba: update to samba-4.7.0
  • Include [pkg] patch: skin.estuary: reduce system info font size (kodi)
  • Include [pkg] PR:82: #Backup: get free space of selected folder (service.libreelec.settings)
  • Include [pkg] PR:234: implement intensity compensation for VC-1 decoding for Ivybridge and better (intel-vaapi-driver)
  • Include [pkg] PR:260: Fix Seeking with VC1 after 6702b01ee3598017f05374bfc7956493f790361c (intel-vaapi-driver)
  • Include [pkg] PR:12826: Linux: add missing wrapper functions to fix playing DVD folders over network
  • Include [pkg] PR:12844: [PVR] Make PVR database threadsafe.
Build Highlights:
  1. PR:12844: [PVR] Make PVR database threadsafe.
  2. Drop PR:12715, served its purpose
Build Details:
  1. XBMC:
    • [addons] remove the CAddonMgr::GetInstance() usage (PR:12839, 3 commits, 69 files changed)
    • [cosmetics] update skin docs for PR10850 (PR:12845, 1 commit, 1 file changed)
  2. pvr.teleboy:
    • Make loading guide multithreaded (48febd7)
  3. pvr.zattoo:
    • Make loading EPG multithreaded (12123dd)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:82: #Backup: get free space of selected folder (service.libreelec.settings)
    • Added: [pkg] PR:12844: [PVR] Make PVR database threadsafe.
I've restrained myself from posting the past week or so regarding an ongoing weirdness with samba shares but somethings amiss and nobody is mentioning it so thinking it might be a genuine issue my end.
After a full "hard" reset no samba shares are visible from libreleec so cannot add any videos via smb protocol. This behaviour has been happening on and off the past month or so since the change to samba with respect to adding those extra options about security. Anyway at this point no amount of switching which protocol version 1/2/3 etc makes any difference.
The box is fully browsable by ssh smb as server etc.
Am I missing some extra step we need to do to make samba work properly?
Many thanks.
(2017-09-28, 03:17)robo989 Wrote: I've restrained myself from posting the past week or so regarding an ongoing weirdness with samba shares but somethings amiss and nobody is mentioning it so thinking it might be a genuine issue my end.
Many thanks.
Please read the release notes here and pay attention to the samba section https://libreelec.tv/2017/08/libreelec-k...-1-0-beta/
"PPC is too slow, your CPU has no balls to handle HD content." ~ Davilla
"Maybe it's a toaster. Who knows, but it has nothing to do with us." ~ Ned Scott
(2017-09-23, 02:30)WaVe_99 Wrote:
(2017-09-22, 02:30)Milhouse Wrote: New LibreELEC.tv Leia build #0921: Generic
# uname -a
Linux NUC 4.13.2 #1 SMP Thu Sep 21 21:04:43 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170921210317-#0921-g5a1b34f [Build #0921]
# Kodi version
(18.0-ALPHA1 Git:f3f144a). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (5a1b34f, changelog) and tip of XBMC master (f3f144a, changelog) with the following modifications:
  • Includes latest addons: inputstream.adaptive (8e505bb, +11), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (b46e5be), pvr.nextpvr (03933e9, +3), pvr.njoy (cc1cb56, +1), pvr.octonet (a77cf11), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (8280157, +16), pvr.vbox (ff01396, +1), pvr.vdr.vnsi (f3f80d5, +1), pvr.vuplus (5e154bc, +4), pvr.wmc (7e2cb4b, +1), pvr.zattoo (7fa43c7, +9)
  • Include [env] PR:1992: squashfs: change upstream, update to squashfs-1a6ffc7, add zstd support
  • Include [pkg] PR:12820: AE: fix pause bursts
Build Highlights:
  1. Update samba-4.6.8, bluez-5.47 (security fixes)
  2. xf86-video-nvidia: update to xf86-video-nvidia-384.90 (fix for "a" suspend bug)
  3. VideoPlayer: fixes for audio delay (fix 2-3 second delay after seeking)
  4. AE: fix pause bursts (improve HBR compatability with Denon/Marantz AVRs)
Build Details:
  1. LibreELEC.tv:
    • samba: update to samba-4.6.8 (PR:2010, 1 commit, 1 file changed)
    • mono: update to 5.2.0.224 (PR:2014, 1 commit, 2 files changed)
    • xf86-video-nvidia: update to xf86-video-nvidia-384.90 (PR:2018, 1 commit, 2 files changed)
    • bluez: update to bluez-5.47 (PR:2009, 2 commits, 2 files changed)
  2. XBMC:
    • VideoPlayer: fixes for audio delay (PR:12814, 2 commits, 8 files changed)
    • [video] Fix CVideoInfoTag::SetYear not to except years <= 0. (PR:12816, 2 commits, 1 file changed)
    • [droid] fix mediasession issue (fixes #17601) (PR:12818, 2 commits, 1 file changed)
  3. pvr.vbox:
    • Update pvr.vbox to PVR API version 5.7.0 (PR:204, 1 commit, 3 files changed)
    • Added: [env] compare: dmidecode: initial package
    • Added: [pkg] PR:12820: AE: fix pause bursts
WOW, that is amazing work from developers, bitstream audio for DTS-HD and DOLBY TRUE HD works with my NUC Kaby Lake, that is realy great, many thanks for all participated developers! There is just one format, which does not work at all. Dolby Digital Plus (E-AC3). Can someone send this info to participated developers? (i dont know, who is exactly working on HBR patch for Kaby Lake and Apolo Lake). Many thanks again :-)
FF and rewind are also working just great, also with keep sound device alive option disabled :-) Great.
For everyone, who has problems with bitstream - DD+ and other issues - dont forget update HDMI firmware on your KL NUCs... I missed, that this is necessarily for bitstream audio correct working. After update FW to 1.66 works everything for me... Unfortunately, update FW is possible just under Win10 64 bit, but its just 30 minut to process...
http://nucblog.net/2017/09/linux-driver-...-problems/
New LibreELEC.tv Leia build #0928: Generic
# uname -a
Linux NUC 4.13.3 #1 SMP Thu Sep 28 22:54:09 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170928225244-#0928-g5d02e52 [Build #0928]
# Kodi version
(18.0-ALPHA1 Git:f0ec8aa). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (5d02e52, changelog) and tip of XBMC master (f0ec8aa, changelog) with the following modifications:
  • Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05, +1), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (48febd7, +3), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (4ae4837, +2)
Build Highlights:
  1. Updated "Make PVR database threadsafe"
Build Details:
  1. LibreELEC.tv:
    • dvb-firmware: update to 1.2.2 (PR:2042, 1 commit, 1 file changed)
    • repo tool: fixes for DEVICE support (PR:2039, 1 commit, 1 file changed)
    • settings: bump to fix backup free-space calc (PR:2046, 1 commit, 1 file changed)
  2. XBMC:
    • Fixed issues with Win64 build failing to build ffmpeg (PR:12781, 1 commit, 2 files changed)
    • [addons] binary cache update is not triggered on enable/disable of addons (PR:12843, 5 commits, 15 files changed)
    • [XBMCHelper] - fixed up and down buttons on ir remotes with macOS High Sierra (PR:12848, 1 commit, 1 file changed)
    • [droid] network fixes (PR:12847, 2 commits, 4 files changed)
    • Add Volume to Game OSD settings (PR:12765, 1 commit, 14 files changed)
    • RetroPlayer: Add renderer for Windows, OpenGL, OpenGLES and MMAL (PR:12715, 7 commits, 144 files changed)
  3. pvr.zattoo:
(2017-09-26, 14:43)fritsch Wrote:
(2016-12-01, 21:44)Roby77 Wrote: Could someone point me to main differences between v17 vs v18 ?
Kidding?
@fritsch
LOL why did you quote a message of almost 1 year ago Huh HuhRoflRofl
New LibreELEC.tv Leia build #0929: Generic
# uname -a
Linux NUC 4.13.4 #1 SMP Fri Sep 29 21:05:05 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170929210339-#0929-g5d02e52 [Build #0929]
# Kodi version
(18.0-ALPHA1 Git:5e8da16). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (5d02e52, changelog) and tip of XBMC master (5e8da16, changelog) with the following modifications:
  • Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05, +1), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (3221c9a, +4), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (e7f5ec8, +3)
  • Include [env] PR:2048: mesa: update to 17.2.1
Build Highlights:
  1. New 4.13.4 kernel
  2. mesa: update to 17.2.1
Build Details:
  1. XBMC:
    • [Droid] Assorted fixes (PR:12855, 3 commits, 3 files changed)
  2. pvr.teleboy:
    • Try to fix windows build (3221c9a)
  3. pvr.zattoo:
    • Try to fix windows build (e7f5ec8)
    • Added: [env] PR:2048: mesa: update to 17.2.1
New LibreELEC.tv Leia build #0930: Generic
# uname -a
Linux NUC 4.13.4 #1 SMP Sat Sep 30 21:05:20 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20170930210354-#0930-g5d02e52 [Build #0930]
# Kodi version
(18.0-ALPHA1 Git:1bca509). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (5d02e52, changelog) and tip of XBMC master (1bca509, changelog) with the following modifications:
  • Includes latest addons: inputstream.adaptive (dde3921), inputstream.rtmp (e094fa3), peripheral.joystick (cc14287), pvr.argustv (23cc0e8), pvr.demo (122dedd), pvr.dvblink (816f90c), pvr.dvbviewer (8741c8b), pvr.filmon (34dca04), pvr.hdhomerun (ace19fa), pvr.hts (53118d8), pvr.iptvsimple (ac4f4bd), pvr.mediaportal.tvserver (c86ab35), pvr.mythtv (8965048), pvr.nextpvr (03933e9), pvr.njoy (cc1cb56), pvr.octonet (e9b4c05, +1), pvr.pctv (549f690), pvr.stalker (e15edca), pvr.teleboy (94bb643, +4), pvr.vbox (ff01396), pvr.vdr.vnsi (f3f80d5), pvr.vuplus (5e154bc), pvr.wmc (7e2cb4b), pvr.zattoo (73009cd, +4)
Build Highlights:
  1. Minors
Build Details:
  1. XBMC:
    • [addons][fix] darwin & freebsd have to use struct stat (PR:12856, 1 commit, 1 file changed)
    • [PVR] Make PVR database threadsafe. (PR:12844, 4 commits, 9 files changed)
  2. pvr.teleboy:
    • Try to fix windows build (94bb643)
  3. pvr.zattoo:
New LibreELEC.tv Leia build #1001: Generic
# uname -a
Linux NUC 4.13.4 #1 SMP Sun Oct 1 21:06:44 BST 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171001210517-#1001-g5d02e52 [Build #1001]
# Kodi version
(18.0-ALPHA1 Git:f71989e). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (5d02e52, changelog) and tip of XBMC master (f71989e, changelog) with the following modifications: Build Highlights:
  1. Minors
Build Details:
  1. XBMC:
    • GBM: Fixup after Retroplayer texture changes (PR:12863, 1 commit, 1 file changed)
    • [depends][android] fix NDK split (#12662) (PR:12865, 1 commit, 1 file changed)
    • Linux: add missing wrapper functions to fix playing DVD folders over network (PR:12826, 1 commit, 1 file changed)
  2. inputstream.rtmp:
  • 124
  • 125
  • 126(current)
  • 127
  • 128
  • 355
LibreELEC Testbuilds for x86_64 (Kodi 18.0)24
