  • 147
  • 148
  • 149(current)
  • 150
  • 151
  • 355
v18 LibreELEC Testbuilds for x86_64 (Kodi 18.0)
Thx @Milhouse for your help.
Was indeed an UEFI Problem and could be solved.
But I could not find a solution for the deinterlacing problems.
I did save the settings for all media, but that has no effect.
My advanced settings only contain the mysql section hat points to my nas.
So nothing special.
Also I'm can not not set Kodi to use 4K @ HZ as resolution.
But I think this is a board / apollo lake problem.
As HDR is not working at the moment I think I send the board back and stay with my N3150 which is running fine with your builds.
New LibreELEC.tv Leia build #1207: Generic
(Supercedes previous build)
SHA256 Checksum: 5b92369afab13d64eaa58539979a29b075ece8ce155b0c09742db5323474c740 (Generic)
# uname -a
Linux NUC 4.14.4 #1 SMP Thu Dec 7 22:57:26 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171207225600-#1207-g587ddc6 [Build #1207]
# Kodi version
(18.0-ALPHA1 Git:a8c2c86). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (587ddc6, changelog) and tip of XBMC master (a8c2c86, changelog) with the following modifications: Build Highlights:
  1. [PVR] PVR manager: last PVR core component is now free from GUI code
  2. VideoPlayer: fix segfault
  3. Update kernel-firmware with Bluetooth fixes for Intel 8260/8265/9260/9560, adding Cypress CYW4373 SDIO/USB firmware (brcmfmac4373-sdio.bin and brcmfmac4373.bin)
Build Details:
  1. LibreELEC.tv:
    • librespot: fix default.py, move fifo to /var/run/librespot (PR:2293, 1 commit, 4 files changed)
    • kernel-firmware: update to kernel-firmware-7f93c9d (PR:2295, 1 commit, 1 file changed)
    • connman: add NTP startup patch for wider testing (PR:2296, 1 commit, 1 file changed)
  2. XBMC:
    • guilib: cleanup gfx context (PR:13137, 1 commit, 18 files changed)
    • [PVR] PVR manager: last PVR core component is now free from GUI code. (PR:13141, 2 commits, 10 files changed)
    • VideoPlayer: fix segfault (a8c2c86)
  3. vfs.libarchive:
    • added: multi-volume support (PR:11, 1 commit, 2 files changed)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:2298 (perma): Kodi updates for Jan 2018
    • Added: [env] PR:2299 (perma): /etc/shadow: fix file permissions
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2017-12-07, 17:30)Milhouse Wrote:
(2017-12-07, 15:18)spiff Wrote: waveform should now be fixed.
Thanks. I've uploaded new #1206 versions of visualization.waveform for RPi/RPi2/Generic.
http://milhouse.libreelec.tv/builds/addons
Generic version works oke, but RPi2 version starts and then stalls the RPi. Have to turn power off and on again. Debug log is not availible.
Hi, i got some problems with psx emulator, here are logs that i'm getting:
11:45:17.266 T:140717724312128   ERROR: CAddonCallbacksAddon - GetAddonSetting - couldn't get settings for add-on 'PlayStation (Beetle PSX)'
11:45:17.266 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Setting beetle_psx_enable_memcard1 not found by Kodi
11:45:17.266 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Setting beetle_psx_shared_memory_cards not found by Kodi
11:45:17.299 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Unknown setting ID: beetle_psx_renderer
11:45:17.299 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Unknown setting ID: beetle_psx_pgxp_mode
11:45:17.299 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Unknown setting ID: beetle_psx_pgxp_caching
11:45:17.299 T:140717724312128   ERROR: AddOnLog: PlayStation (Beetle PSX): Unknown setting ID: beetle_psx_pgxp_texture
11:45:17.481 T:140717724312128   ERROR: GAME: exception caught while trying to call 'LoadGame()' on add-on game.libretro.beetle-psx
11:45:17.481 T:140717724312128   ERROR: Please contact the developer of this add-on: Libretro
thank you
In my case this release, and 1205/1206 make WiFi do not work at all. There are no visible option to even try to connect. ifconfig do not show any wireless device.
LibreELEC on Intel NUC DC3217IYE (click to find my uname, lsb_release, lspci, lsusb and dmesg info).
(2017-12-08, 16:40)nicram Wrote: In my case this release, and 1205/1206 make WiFi do not work at all. There are no visible option to even try to connect. ifconfig do not show any wireless device.
Have you tried #1207 (is that what you mean by "this release" - I don't like guessing).
If #1207 isn't working please post pastebin links to your dmesg from #1204 (which I assume is working) and also #1207.
Well i wasn't sure if the problem started with #1204 because i was using ethernet cable, and was just checking 1205/1206/1207 if there is wireless signal (i read about some dependencies between wifi and BT when i was trying to find solution for my earlier problem).
So i checked few releases and there is no wifi card detected.
So i moved into the past... LibreELEC-Generic.x86_64-9.0-Milhouse-20170202210210-#0202-g8d14fdd - no wifi, and...
LibreELEC-Generic.x86_64-8.0-Milhouse-20161201042826-#1130-g0ad9cf6 also no wifi. I chkecked like 6 from many months and wifi wasn't working, so i think it is from the beginning.
BUT - in the stable release WiFi is working, and i can use it.
Here are logs between versions:
http://www.marcinwilk.eu/kodi/log-stable.txt - LibreELEC stable 8.2.0 (wifi working)
http://www.marcinwilk.eu/kodi/log-stable8.2.1.txt - LibreELEC stable 8.2.1 (wifi working)
http://www.marcinwilk.eu/kodi/log-20161201-1130.txt
http://www.marcinwilk.eu/kodi/log-20170202-0202.txt
http://www.marcinwilk.eu/kodi/log-20171207-1207.txt
(2017-12-09, 00:47)nicram Wrote: Well i wasn't sure if the problem started with #1204 because i was using ethernet cable, and was just checking 1205/1206/1207 if there is wireless signal (i read about some dependencies between wifi and BT when i was trying to find solution for my earlier problem).
Not sure at the moment. There's not much to go on in the logs.
I can see the 8.2.1 build is starting the WiFi device:
[    3.424984] wlan0: Broadcom BCM4359 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
but #1207 does not.
All the firmware for this device seems to be present in #1207.
Build #1130 (from 2016) is shortly after we branched LE8 for release so that really shouldn't be significantly different from 8.2.1.
Can you install 8.2.1 and upload the latest zip file from the Logfiles samba share to dropbox (or similar). Then do the same with #1207, and post both download links. Thanks.
New LibreELEC.tv Leia build #1208: Generic
SHA256 Checksum: 4f7162630a1f4ae0f90618b3c291931112d7ec2aef41e0d1ae482e488c5cdef3 (Generic)
# uname -a
Linux NUC 4.14.4 #1 SMP Fri Dec 8 23:39:12 GMT 2017 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20171208232721-#1208-g712987f [Build #1208]
# Kodi version
Based on tip of LibreELEC.tv master (712987f, changelog) and tip of XBMC master (588f127, changelog) with the following modifications: Build Highlights:
  1. Fix file permissions on shadow file, move to /storage/.cache
  2. Prevent weak/bad root passwords
  3. Openssl 1.0.2n and heimdal 7.5.0 security updates
  4. nss-mdns library and avahi socket fixes
  5. PVR database query fix
  6. Fontconfig fix for custom subtitle fonts
Build Details:
  1. LibreELEC.tv:
    • /etc/shadow: fix file permissions (PR:2299, 4 commits, 6 files changed)
    • busybox: prevent weak root passwords (PR:2300, 1 commit, 1 file changed)
    • linux: Update amlogic-3.10 kernel to amlogic-3.10-24a7272 (PR:2302, 3 commits, 5 files changed)
  2. XBMC:
    • [Windows] move libdvd to cmake build tree (PR:13140, 3 commits, 14 files changed)
  3. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:2301 (perma): fontconfig: add kodi font folder to a list of folders
    • Added: [env] PR:2303 (perma): nss-mdns: install all libraries, correct avahi socket path
    • Added: [env] PR:2304 (perma): openssl/heimdal: Security fixes
    • Added: [pkg] PR:13150 (perma): [PVR] PVR database: Fix error "Abort due to constraint violation. Query: INSERT INTO channels..."
(2017-12-09, 02:33)Milhouse Wrote: I can see the 8.2.1 build is starting the WiFi device:
but #1207 does not.
 Here are the files,
8.2.1: http://www.marcinwilk.eu/kodi/log-2017-1....19.21.zip
Debug log: http://www.marcinwilk.eu/kodi/kodi-8.2.1.log
1207: http://www.marcinwilk.eu/kodi/log-2017-1....51.12.zip
Debug log: http://www.marcinwilk.eu/kodi/kodi-1207.log
I just noticed a strange issue after I did a clean re-install.
I have screen tearing but not the way i've seen it before.
The screen "splits" into 2 triangles. Upper left and lower right.
In fast scenes or sudden changes of contrast in videos there's a diagonal line from the top right corner to the bottom left corner.
The "upper left" part of the image is behind about 1 or 2 frames resulting the mentiones triangles.
CPU is an AMD Athlon 5350 APU, the GPU is the build in R3 (HD 8400).
I checked it it's my TV but using the Amazon App on my Samsung didn't have this issue.
Also tested regular TV which also didn't have this issue.
Anyone else with this issue?
Any ideas on how to fix it?
Edit:
I did some testing and it seems that VDPAU causes this.
Turned off VDPAU and VAAPI and it's gone but now everything is software decode only so it's more a workaround than a fix :/
@UrushibaraRuka: Check if older builds have the same issue (including also LibreELEC 8.2.1). I can't believe this issue would be *caused* by a clean install - the problem will either have always been there (but you had/have settings which masked it) or it's a recently introduced issue that you haven't tested before (you failed to mention what version you were using prior to the clean install).
Oh, aorry, what I meant was that I did the clean re-install because of that issue.
I noticed this issue a while ago but ignored it until today.
The last build I remember to ne without the issue was around #1115, I'll try to do some testing to find the build that brought the issue with it.
Maybe I really just overlooked it all the time but then again, the issue is gone when i disable VDPAU, no issue with VAAPI (which seems like it's not used because the overlay says it's still software rendered)
Hi I need a little help, I tried the latest Millhouse and then had problems and decided to roll back to stable official 8.0.2. However when I did this i noticed that passthrough to my avr wasn't working properly web with the settings enabled.
I noticed many settings had been defaulted which was fine... But even with everything selected as before and perfectly I can't get passthrough of DTS HD Master to work perfectly like it did before. Has anyone else had this happen...I don't know what to do short of a fullv wipe and reinstall. I am using HDMI cable as before I have not altered anything physical on my audio setup. I know that it is something to do with the Kodi rolling back to stable official version which has given this problem to the ability to do passthrough. I did not do a backup, I know I was stupid! Is there a known situation technique I can do to force Kodi to do passthrough properly in these types of situations or do I have to do a wipe and reinstall?
(2017-12-10, 09:19)mwake Wrote: Hi I need a little help, I tried the latest Millhouse and then had problems and decided to roll back to stable official 8.0.2. However when I did this i noticed that passthrough to my avr wasn't working properly web with the settings enabled.
Toggle on passthrough and evt. restart. That helped with #1208.
KODI 20 - LibreELEC 11
Intel NUC 4250U (Haswell) in Abel H2 chassis, Philips 55OLED804
  • 147
  • 148
  • 149(current)
  • 150
  • 151
  • 355
LibreELEC Testbuilds for x86_64 (Kodi 18.0)24
