2018-04-05, 09:18
(2018-04-05, 08:22)fritsch Wrote:I would say that it actually made things worse. Now it was losing frames no matter if I had the bottom list open or not. After a restart, it went back.(2018-04-04, 23:02)BoKKeR Wrote: On the newest build, I am getting dropped frames on every 4K video where there are big changes in the image (landscapes etc.). I tried an older version (LibreELEC-Generic.x86_64-9.0-Milhouse-20180115210328-#0115-gcd45cd6.tar) and it worked fine there but the colors were worse. I tried switching changing up VAAPI but it did not help. The only thing that helps if I have the pause menu open on the bottom then the video plays back properly. The second I hide the play/stop panel it starts to judder.Can you try before starting the movie, from a shell:
NUC6CAYH
https://paste.ubuntu.com/p/DRFPZ9cxnj/
btw have HDR been implemented on this device and build? The colours look way better.
Code:echo 750 > /sys/kernel/debug/dri/0/i915_min_freq
Edit: Yes. Fernetmenta has implemented the very first step of proper tone-mapping. So colors are correctly transformed.
