2018-07-05, 13:42
(This post was last modified: 2018-07-05, 13:43 by coolie.)
I just want to confirm that I am observing the same issue as TheKraut (CIR stops working after a few keypresses under any Milhouse LE testbuild from #03xx until the latest ones, until a restart).
System: Intel NUC7CJYH (Gemini) with nothing connected but network, HDMI, power. Other control methods (USB keyboard, USB IR receiver, Yatse) work.
Are there any news or indications already besides this thread maybe, or something I missed? It's quite annoying and a showstopper tbh.
(2018-07-05, 13:42)coolie Wrote: [...]
Nothing I've heard of, except some people over
LE forums confirming the issue for the NUC7C/P series.
Best option is still something @
HiassofT suggested a few weeks ago: File a bug report with some major distro (e.g., Ubuntu), so that they can/will hopefully fix it and LE guys can then backport/merge it.
Jezze
Senior Member
With kodi leia iptv simple client wont start everytime at start. Need disable and enable addon and then it loads channels. Should i post debug log here or contact to addon developer?
Milhouse
Retired Team-Kodi Member
A debug log here should be OK.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
fritsch
Team-Kodi Developer
2018-07-06, 13:23
(This post was last modified: 2018-07-06, 13:36 by fritsch.)
Thx I sent a PR.
Edit: No crash here, also no error in log, but screen is entirely black in that method. Same btw. for BOB which takes the same path (sse4 copy + gl render).
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
