2018-10-25, 16:34
(This post was last modified: 2018-10-25, 16:48 by Celox.)
i just got the chance to test the 1018y (4.19-rc8) build!
WoL from S5 works!
also tested WoL from S3.
both work flawless!
can the patch be inculded in the upcoming 4.19 builds?
thanks!
Hi Milhouse.
This may seem like a silly question but what does “Additional commits/pull requestschanges not merged upstream” actually mean?
Are these not yet in your current LibreElec Test build?
THX
Fuzzard
Team-Kodi Member
Means they are included in the build, but are not merged into the master branch of whatever project its for (Libreelec, Kodi, plugins, etc)
(2018-10-25, 15:42)posixx Wrote: (2018-10-23, 20:26)fritsch Wrote: Nobody is currently hunting. Custom offsets in calibration are NOT suggested at all, this entirely drives the 1:1 pixel mapping nuts. Please fix the root-cause with your TV and its Fixed / Just Scan / Whatever Setting.
Finally found the option! On LG it's called 'Just Scan' and found within the aspect ratio menu (had dutch language before so couldn't find it). It's on 'Automatic' by default, but you need to set it to 'On' to change the screen size to somewhat smaller. I can confirm with latest build (#1024) i don't have any artifacts on the screen borders. Looks like fritsch is right; it's a TV issue not a kodi issue.
I have a Sony Bravia 32'' LCD, is fairly old and has no settings like that. The only setting I have is to over scan even further.. Like (-1,-2)
So I guess your saying buy a new TV?..
2018-10-26, 16:30
(This post was last modified: 2018-10-26, 16:31 by basco.)
Ok, traced the WOL issue (for me)....
i'm unable to WOL in #1023 and #1024
it's working #1022
(still searching for the release that has a working JSON api)
