2018-12-10, 16:14
OK. is it possible to downgrade?
(2018-12-10, 16:14)Freuli Wrote: OK. is it possible to downgrade?
(2018-12-10, 03:21)jmerrilljr Wrote:I also don't have a syslinux.cfg file(2018-12-10, 02:23)Matt Devo Wrote: ssh root@<ip address><enter password, default is 'libreelec'>
mount -o remount,rw /dev/sda1 /flash
nano /flash/syslinux.cfg<add ' pci=nomsi' after 'quiet'>
<save and quit: CTRL+O CTRL+X>
reboot
Thanks. I'm running an Asus Chromebox (Haswell) which was modded maybe four-five years ago. After running the mount command, nano still brings up an empty file. As an aside, I'm really interested in how all this will play out. A new stable release should be coming soon.
(2018-12-10, 21:39)J.L.C. Wrote:then the file is extlinux.conf (for legacy/non-UEFI installs)(2018-12-10, 03:21)jmerrilljr Wrote:I also don't have a syslinux.cfg file(2018-12-10, 02:23)Matt Devo Wrote: ssh root@<ip address><enter password, default is 'libreelec'>
reboot
2fa6516376d0150fd8e1b8dd66cd1005af3a62cc6a286170ee5e45102c11358a
(Generic)text:# uname -a
Linux NUC 4.19.8 #1 SMP Mon Dec 10 21:04:32 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181210210313-#1210-g6db1ac5 [Build #1210]
# Kodi version
(18.0-RC3 Git:10edcdb). Platform: Linux x86 64-bit
(2018-12-10, 23:57)hasenbolle Wrote: Hi Milhouse,
could it be that this change https://github.com/xbmc/xbmc/pull/12776 introduced this behaviour https://forum.kodi.tv/showthread.php?tid...pid2799097
@illiac4 in this thread, says build #907 from Sept. 2017 still works. This build is too old, so i can't test ist with this build. The change mentioned above, was added with #910 of Sept. 2017.
Maybe you can have a look on. Thanks
Regards hasenbolle
text:
iptables temporarily replaced with nftables due to build issues
xf86-video-nvidia may not be working (or show garbage characters)
(2018-12-11, 01:24)Milhouse Wrote: @hasenbolle Apologies for not finding those #0909/#0910 builds when you posted last week - it's pure luck I still have those builds lying around on that client.No problem. Thank you for the reupload. I will test those builds and report back.
(2018-12-10, 21:47)Matt Devo Wrote:That works. Thanks, Matt.(2018-12-10, 21:39)J.L.C. Wrote:then the file is extlinux.conf (for legacy/non-UEFI installs)(2018-12-10, 03:21)jmerrilljr Wrote: Thanks. I'm running an Asus Chromebox (Haswell) which was modded maybe four-five years ago. After running the mount command, nano still brings up an empty file. As an aside, I'm really interested in how all this will play out. A new stable release should be coming soon.I also don't have a syslinux.cfg file
e7eac1f5e0bbc760b4cb23d8d34d23184074f661ab244cf3786369b6717390e4
Linux NUC 4.19.8 #1 SMP Tue Dec 11 21:05:16 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181211210354-#1211-g6db1ac5 [Build #1211]
# Kodi version
(18.0-RC3 Git:b788e08). Platform: Linux x86 64-bit
1e4d238c28e586b8cdbd721a7b529ba74e6f6705981fdf8eb1f79cf4c5b5bd57
Linux NUC 4.19.8 #1 SMP Wed Dec 12 21:05:41 GMT 2018 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse): devel-20181212210416-#1212-g6db1ac5 [Build #1212]
# Kodi version
(18.0-RC3 Git:0665f06). Platform: Linux x86 64-bit
